Tire inflation.
Discussion in 'Prius v Technical Discussion' started by danbob, Feb 11, 2012.
  1. danbob
    danbob
    Expand Collapse
    Junior Member
    36
    Westchester NY
    What should my cold tire pressure be in order to achieve maximum gas milage on the stock 16 inch wheels that come with the v2 and 3? I want to be safe with this...thanks in advance!
  2. xs650
    xs650
    Expand Collapse
    Senior Member
    4,524
    1,388
    Northern California
    Maximum gas mileage and safe tire pressure are mutually exclusive.
    For a safe maximum, use the maximum pressure on the tire sidewall for your cold inflation pressure. You might decide you want to use a bit less because of the ride,
  3. danbob
    danbob
    Expand Collapse
    Junior Member
    36
    Westchester NY
    Okay thanks, because I have seen some who inflate to like 48 PSI - To me that is kind of playing with fire because we have a baby and I would never want to put anyone in danger of blowing out a tire just for better fuel economy.
  4. xs650
    xs650
    Expand Collapse
    Senior Member
    4,524
    1,388
    Northern California
    The pressure on the sidewall includes a BIG safety margin, but if you are that worried you should stick with the owners manual recommendation.
  5. JACoH
    JACoH
    Expand Collapse
    Enjoying the mileage
    193
    36
    Oregon
    I run 39 front, 38 rear in mine, watching wear patterns, but only have 2000 miles on my v2.
    Hey, XS650, do you still have one?(XS650, I mean)
  6. xs650
    xs650
    Expand Collapse
    Senior Member
    4,524
    1,388
    Northern California
    Nope, got rid of my last one 10 years ago when I quit riding.
  7. Cactus Hybrid
    Cactus Hybrid
    Expand Collapse
    Member
    129
    43
    Paradise Valley, Arizona
    I run all at 40 psi on my v. I think it's a great balance between ride and Gas mileage..
  8. F8L
    F8L
    Expand Collapse
    Protecting Habitat & AG Lands
    19,149
    4,028
    50
    Sacramento, CA.
    2013 Chevy Volt
    You're more likely to have a blowout due to under inflation than overinflation. Lower pressure creates more tire flex which creates more heat and causes blow outs. :)
  9. syscon
    syscon
    Expand Collapse
    Member
    291
    Edm. Alberta
    Do you folks use standard air in your tires or go to a tire shop to up pressure with nitrogen?
  10. M8s
    M8s
    Expand Collapse
    Retired and Lovin' It
    607
    103
    33
    Colorado and Arizona
    Same here, both on our 2009 and our vee. I go to Discount Tire once each month and ask them to fill to 41 all the way around. They set their machine to 41 and, invariably, it fills the tires to 40 psi.
  11. F8L
    F8L
    Expand Collapse
    19,149
    4,028
    50
    Sacramento, CA.
    2013 Chevy Volt
    I used a blend with 78% nitrogen. :D
    Yeah, standard air. It's not worth my time to find a place with so-called 100% nitrogen since it is difficult to get all of the oxygen and other trace molecules (argon, carbon dioxide etc.) out of the tire when refilling. Nitrogen filling is not a bad thing. It's fine if you don't have to waste money or effort to obtain it.
  12. RichardAK
    RichardAK
    Expand Collapse
    Member
    121
    Fairbanks, AK
    I believe that the main benefit of using N2 is that it's dry. No moisture buildup in the tire. I've had ice in the valve but it's not a big problem.
