1. Offline
    Andyprius # 1 Member since 2005
    Start a Conversation
    May 30, 2012
    1,012
    88
    Sacramento
    Your Vehicle Year:
    The tire pressure on the side wall is for the tire installer, warning not to go beyond that pressure! However, all installer MUST exceed that pressure in order for the tire to seat on the rim. Somewhere around 44-50 is a good pressure if you want economy and longlife. Keeping the tire at the rec. door specs will give you a nice soft ride and premature wear.
  2. Offline
    2,725
    395
    Greater Vancouver, BC, Canada
    Your Vehicle Year:
    Sorry, but I don't see that "implied implication" either. Guess we'll agree to disagree?
  3. Offline
    Apr 13, 2004
    15,051
    578
    South Puget Sound, WA
    Your Vehicle Year:
    actually its normal to go up to 100 PSI to seat the tire bead but that is in a shop for a few minutes and has no bearing on what is recommended when driving down the road.
    unfortunately my tire expert is no longer with us but as a tire store manager, it was his recommendation that the max tire pressure printed on the sidewall is as i have stated on this thread.
    the reasoning for the wording "maximum recommended pressure" instead of "recommended pressure" is that the latter implies that there is an "optimum pressure" that might be more which can be untrue in certain climates and thus the wording is more a legal thing than a safety or performance thing. therefore the 44 PSI COLD pressure rating is there for the hottest weather you can expect to see so this pressure is completely safe if you are cruising Death Valley in July. for all others, it is more than safe and is the recommended tire pressure for best life and safety and handling
    Andyprius # 1 likes this.
  4. Offline
    May 30, 2012
    1,012
    88
    Sacramento
    Your Vehicle Year:
    I'll go along with that.
  5. Offline
    Jonny Zero Giggidy
    Jun 22, 2012
    861
    166
    Austin, TX
    Your Vehicle Year:
    One more thought - would higher pressures affect the operations of VSC, ABS, TRAC, etc?
  6. Offline
    Apr 13, 2004
    15,051
    578
    Your Vehicle Year:
    not really. some feel higher pressures makes TRAC more sensitive. i don t see that. inversely, if stuck somewhere i have seen the recommendation to remove some air from tires to get better traction which is something I DO NOT recommend unless you have a way to reinflate the tires after you get out of your predicament
  7. Online
    Aug 14, 2006
    18,146
    3,449
    Sacramento, CA.
    Your Vehicle Year:
    In theory it could but generally at higher speeds and rough surfaces. It is well established that tires can skip across imperfections in the road when tire pressure is so high that the tire cannot conform to those imperfections. Cold temperatures can cause the same problem. The design and compound will have a large effect on how much a tire skips.
  8. Offline
    xs650 Senior Member
    Jul 2, 2010
    4,419
    1,304
    Northern California
    Your Vehicle Year:
    Higher pressures will cause the tires to bounce a bit more on rough surfaces. I'm running in the low 40 psi range and hardly notice it, but the effect is there. If you did a before and after test at sticker pressure and 45 psi and tried braking hard as you cross some rough railroad tracks you would feel a little difference in the ABS. The difference isn't big and I wouldn't hesitate to run 45 psi if I felt like it.
  9. Offline
    Jonny Zero Giggidy
    Jun 22, 2012
    861
    166
    Austin, TX
    Your Vehicle Year:
    So what I am hearing is ABS and TRAC may be more trigger happy due to tire skipping. Anything with the VSC? Would it affect the yaw rate reading and render the system less effective? (assumming the braking wheel still gets sufficient traction at the higher pressure, to make the yaw correction.)
  10. Online
    Aug 14, 2006
    18,146
    3,449
    Sacramento, CA.
    Your Vehicle Year:
    Yes but different tires can cause the same effect because of differences in traction and tread suppleness. So a cheap tire or one with so so traction can cause the effect at lower pressures than say a tire with much better traction at higher pressures.
  11. Offline
    jrb451 Junior Member
    Nov 2, 2010
    53
    Conway, AR
    Your Vehicle Year:
    Sounds like you had a good experience with the Michelins. Just curious why you would switch tires if this were the case. I didn't get that much wear out of my Bridgestones and am having these Michelins installed on my Prius tomorrow.
Share This Page
