Tire Pressure for the 215/45 17s -- Here We Go Again!
Discussion in 'Gen 3 Prius Main Forum' started by a priori, May 28, 2009.
  1. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    The manual and the label on the door jamb both tell me to inflate my new 215/45 R17 low-profile performance tires to 33 in the front and 32 in the rear (or 32/31, I forget which at the moment!).
    The maximum rated inflation for my Toyo Proxes A20s, as imprinted on the sidewall, is 51psi. I believe the tires are rated to 1,200 lbs. I think my 2010 Prius weighs in at about 3,000 lbs.
    What do I do?
    Someone at the dealership (I won't name names) suggested going midway between the numbers. That would get me to 42/41. I thought this sounded pretty reasonable, so I inflated to that pressure before I left the dealership.
    The tires were inflated to 38/37.5 psi when I first measured them at delivery.
    Questions? Comments? Suggestions?
  2. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    *shrug*
    I ran my 215/45/17s at 60 psi and they were showing a tiny bit more wear in the center so I backed them down to the sidewall pressure (50psi or 55psi I cannot remember) but I have not driven on them enough to know if that helped the center wear. I switched back to my 15s due to loss of MPG.
    Even at 60psi the wear was pretty minimal so going close to sidewall likely wouldn't produce much middle-wear. Now we can get into arguing about burst pressures..... :rolleyes: LOL
  3. a priori
    3,083
    407
    23
    Chicagoland (West)
    Thanks! I feel better knowing someone else has run these tires at sidewall max without difficulty.
    I found the ride to be great at 42/41. Perhaps I'll move it up a little bit later, but for now, I'm good . . . I think!
  4. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    33 psi is to low for any road tire, especially low profile. I would just do what you did with Gen II, maybe a bit more. Low profile soaks up alot more road vibration though, anything over 46 psi is probably to much. Go by the sidewall. The last Toyo's I had that where low profile..anything over 46-48 was to much.
  5. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    I like the 51 PSI max the sidewall says. But then I like higher pressures and my bottom is immune from NVH. Besides the higher you go, the easier to shoot for a 70 MPG tank.
    Wayne
  6. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Factory recommended tire pressures are a compromise between ride, handling and wear (as observed in the extensive testing Toyota does on the Prius). The max pressure number is the tire manufacturer's safe number based on testing, probably with a margin of safety thrown in. For autocrossing we usually ran considerably higher than the manufacturer's suggested numbers, but below the max rating on the sidewall to get maximum handling performance (too high and the tire tends to bulge to the point it is only riding on the center, reducing contact area). For maximum mileage I assume the smallest contact patch would be best, but this comes at the expense of ride and wear, and possibly safety (less contact patch = worse handling and braking). Everyone has to make their own decisions. I run the recommended numbers on my 2006 for best all around performance (but I'm certainly not a hypermiler).
  7. FireEngineer
    1,247
    124
    Not quite true. Modern steel belted radials don't bulge in the middle like the old bias-ply tires. The only thing that will change will be the shoulder tread lifting off the pavement, the wear of which happened to be a common complaint amongst Prius owners. Having seen many tires "overinflated" for there natural life, tread wear turns out to be very even across the tread unless there is an alignment problem.
    Wayne
  8. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Wayne, have you seen this generalization applied to wider tires? I'm curious because I noticed a tiny bit more wear in the center of my 215s (on the Prius) when I kept them overinflated as well as on the 275s and 315s I used to run on my Trans Am and my GMC truck. What else would cause the center to wear like that?
  9. FireEngineer
    1,247
    124
    I have not heard of abnormal center wear except for very wide tires. Did you measure the tread depth, center and sides?
    Wayne
  10. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I did not measure them when I noticed this problem because I was taking them off and storing them away. Next time I'm at my friends house, where they are stored, I will measure them. :)
  11. a priori
    3,083
    407
    23
    Chicagoland (West)
    Here is an update on tire pressure on my 17s.
    Originally, I set the pressure at 42/41, and I felt the handling and mileage were great. After about one week, I upped the pressure to 45/44. No difference in handling. It looks like I gained maybe 2MPG, though it is pretty difficult to tell, given the short time frame.
    One week ago, I upped the pressure, again. This time I went to 48/47. Once again, the handling appears to be unaffected. I don't know about changes in FE, yet, though I did have pretty good highway performance under some challenging circumstances. (See my report about this at This One Really Pushed the Prius – A Four-Day Family Getaway!)
  12. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Had my V 3 weeks now. Tires were 33/32 from the dealer at delivery. I asked the same air pressure question here weeks ago, and after advice (very good stuff from the great folks here) brought them up to 43/41. After a bit of driving I did notice a slightly harsher ride and perhaps a bit more tire noise. Subjective....
    I decided to bring them to 38/37. Seems to feel and sound fine. With such a low profile tire, I'm surprised the ride is not punishing. The car handles extremely well, and the steering ratio is great.
    Honestly, I'm not one to be super-concerned about squeezing an extra MPG or two for the sake of very high tire pressure or really babying the accelerator. I find myself driving much more conservatively with my Prius, but not super-duper hyper. 1st 850 miles of very mixed driving 48.3. A/C on all the time. I'm VERY OK with that number.
    Off topic, but IMO the Prius should have 3 tire/wheel combos - 15s for the I&II, 16s for the III&IV, and 17s for the V.
