Tire Rack pits Integrity against Energy Saver, Ecopia and Fuel Max
Discussion in 'Gen 2 Prius Fuel Economy' started by krousdb, Sep 11, 2009.
  1. krousdb
    krousdb NX-74205
    578
    483
    47
    Raleigh, NC
    Holy Cow! I just found this at Tire Rack. Tests run with 2009 Prius.
    Michelin Energy Saver 4.74% better FE than Integrity. Ecopia, 4.12% Better.
    Sorry if this has already been posted.
    When Round and Black Becomes Lean and Green=
    23 people like this.
  2. Celtic Blue
    Celtic Blue New Member
    2,224
    131
    Midwest
    Thanks for posting this. Correct me if I'm wrong, but isn't the replacement Integrity available here different than the true OEM? I seem to remember some threads about how the Japanese Integrity was different (higher mpg.)
    It's quite possible that they used the actual OEM tire from a new car (in which the point would be moot), but they might also have used one from stock.
    At any rate, that really doesn' alter the conclusions of the replacement tire comparison.
  3. jayman
    jayman Senior Member
    13,440
    599
    Winnipeg Manitoba
    Thank you for posting the report.
    I've always purchased tires when 50% worn, as I insist on having safe tires driving down rutted highways in a rainstorm. It's apparent that for a difference of - possibly - 2-3 mpg, one is better off choosing a tire that performs well and is safe
    When my 2004 Prius was still new, the Integrities were so awful on rain soaked roads I ditched them - before they ditched ME - for a set of Michelin Harmony. Day and night difference in the rain
  4. Boo
    Boo Boola Boola Member
    5,051
    454
    97
    Flushing, NY
    Thanks krousdb for letting everyone know.
    Apples to apples road tests of tires are rare (Consumer Reports and TireRack seem to do the most). And this test not only tests a lot of tires that Prius owners are considering, but it's done on a Prius. Great stuff.
    Below are the MPG results from the test and article (you should read the article for, among other things, braking and handling results):
    Tire LineTest MPG*% vs. O.E.
    Michelin Energy Saver A/S: 53.8 MPG +4.74%
    Bridgestone Ecopia EP100: 53.5 MPG +4.12%
    Yokohama dB Super E-Spec: 52.8 MPG +2.81%
    Goodyear Assurance Fuel Max: 51.6 MPG +0.37%
    Goodyear Integrity (O.E.): 51.4 MPG --
    Michelin HydroEdge with Green X: 51.1 MPG -0.59%
    Goodyear Assurance ComforTred: 50.0 MPG -2.64%
    *Calculated based on GPS distances and ScanGage II recorded consumption (offset 6% for Prius Summer E10 regular grade fuel).
    2 people like this.
  5. uart
    uart Senior Member
    4,040
    941
    Australia
    Interesting report.
    I'm a little bit puzzled with the note they made about E10 summer grade fuel can anyone help me understand this point. Are they saying that they actually inflated their real MPG figures by 6% to compensate for the use of summer E10 (or did they reduced their raw figures by 6% or does this mean something else entirely)?
  6. krousdb
    krousdb NX-74205
    578
    483
    47
    Raleigh, NC
    Something else entirely. The 6% offset refers to the ScanGauge offset for proper calibration. Most Gen II's need a 5-6% offset so that fuel use indicated on the ScanGauge equals fuel used at the pump.
  7. uart
    uart Senior Member
    4,040
    941
    Australia
    Ok that's good to know. Otherwise I was starting to wonder if their figures were suspect.
  8. 9G-man
    9G-man Senior Member
    1,256
    168
    Atlanta, GA
    I just put a set of Michelin Energy Saver A/S tires, 185/65/15, on my Gen II Prius. I got 60K out of the original Integretys.
    I purchased the Energy Saver A/S tires at Costco, just a few days ago, and got $70.00 off with one of their coupons.
    It's a great tire and I already see an increase in MPG. (For the last year my tank averages have been about 58MPG. Down a couple MPG or so since the original tires had become greatly worn.)
    Currently, my tank average is 62 MPG over 600 miles traveled.
    Michelin advertises as much as an 8% increase in MPG over ordinary tires. 58 x .08 = 4.6 MPG. Which is about what I gained.
    There is no doubt these tire have a lower rolling resistence. I can glide further, and maintain higher speeds longer in glides, compared to the OEM Integritys. I drive about 100 miles a day r/t to work. These judgements are made over routinley traveled roads. Another indicator is when on cruise control, the car drops into warp stealth on the down hills sooner and stays there longer, on known stretches of interstate.
    The Energy Saver is noticable lighter, and has a more flexible sidewall, than a same size Michelin Primacy. Compared to the original Integretys, my impressions are the Energy Saver rides smoother, steers sharper, corners slightly better, and is a general improvement in handling. Road noise is equal, or maybe slightly quieter, than the Integretys. Road noise seems to be decreasing as they have worn in over the last few days.
    I am very happy, and the Energy Savers tire seems to be legitiment.
    I'm glad Michelin has finally offered them here in the US. A couple years ago when they came out in Europe, the word was US would not see them.
    I had been comtemplating what tire to go with, when the time came, and the timing for me was perfect.
    3 people like this.
  9. uart
    uart Senior Member
    4,040
    941
    Australia
    Hi 9G-man. Could you please tell us how much you paid for those tires (without the coupon). I was just wondering how many extra dollars they cost compared to a bog standard set of tires.
    BTW. This was a timely article for me. I just got a 2nd hand Prius II about a week ago and I've been wondering why I was getting a bit less then expected MPG out of it. It came with absolutely brand new tires (still have some knobbly bits on the tread). Unfortunately though I think they (previous owners) skimped on the quality, presumably because they were about to sell. It's got these relatively cheap "Hankook optimo H415" tires. I'm pretty sure they're bog standard tires without any low rolling resistance properties at all. Probably as bad or worse than the worst of those tires reviewed in the above link.
    Hmmm I don't really want to ditch a brand new set of tires but I'm contemplating seeing what my local tire place will give me for them as a trade-in on some decent low rolling resistance ones like the Michelin Energy’s.
  10. 9G-man
    1,256
    168
    Atlanta, GA
    Costco has them for $121.00/tire. It's the same price as TireRack, but without the shipping. Cheapest price I've seen for the tire, an not widely available . With the coupon I got the tires, balance, mounting & TPM seals for $484 + tax .
  11. uart
    uart Senior Member
    4,040
    941
    Australia
    Thanks for the info.
    BTW. If those fuel saving figures are true then you could save more than $200 fuel over the life of a set of tires, so that's not bad value. :)
  12. krousdb
    krousdb NX-74205
    578
    483
    47
    Raleigh, NC
    Doesn't the Gen III come with Ecopia EP 100's? So 4% of the 10% increase in fuel economy over the Gen II is due to the tires?
  13. Boo
    5,051
    454
    97
    Flushing, NY
    I believe that most of the 2010's with the 15" wheel that are being delivered in the US are being delivered with the Yokohama Avid S33, though a sizable minority are being delivered with the Bridgestone Ecopia EP20 (whatever that is ... some have said that it's the same as the Ecopia EP100):
    http://priuschat.com/forums/gen-iii...61926-what-tires-did-you-get-your-2010-a.html
    I have no idea what tires Toyota used in its EPA tests.
  14. pdxrose
    pdxrose New Member
    175
    25
    I have Bridgestone Ecopia - which tested best for wet braking - a good think in the PacNW. When the original survey came out for the Gen III, I responded that I was a happy woman because I love my Bridgestone Dueller HT tires on my CRV. I used to be a die hard Michelin fan but will not be purchasing that brand again after my Avalon (before CRV which was before P).
    I had Ms on several cars and never got the wear life each set was rated and then on the Avalon there were always getting leaks (a couple that nobody could "find" for months) so I had to put in air at least once a month (drag for most girls : ). I have 22,000 miles on the CRV and the tires have never needed air - except perhaps when I had the recommended oil changes at 7,500 and 15,000 miles. These are much smaller profile tires so time will tell :D
  15. jay_man2
    jay_man2 jay_man_also
    1,246
    141
    Manassas, VA
    They're EP20's (which mine has), so who knows compared to EP100's.
  16. SureValla
    SureValla Member
    590
    Shelton, CT
    Amazing, I wish this had come out 6 months ago when I was buying tires.
    I see though only the ecopia and the Yokohama come in the exact Touring size though.
    Good enough to sell me on the ecopia's when I hit 100k.
  17. pdxrose
    pdxrose New Member
    175
    25
    They should be the same. The EP20s are listed on Bridgestone's web site as OE and the EP100 aftermarket (they only go to 09). Bridgestone does the same with my Dueller HTs for my CRV :D.
    Their description of EP100: "...an environmentally friendly tire designed to improve rolling resistance, which may help passenger cars achieve better gas mileage without sacrificing the smooth, quiet ride or reliable wet handling you have come to expect from Bridgestone tires." Whereas the site has no description for the EP20 besides "OE tire on select vehicles. See Sizes and Specifications for Original Equipment fitments."
    Thus, for the testing it makes sense that they would have purchased EP100s....:)
  18. Boo
    5,051
    454
    97
    Flushing, NY
    Yes, but who knows for sure which tire they used for the EPA test.
  19. royrose
    royrose Member
    459
    86
    Manitou Springs, CO
    So, does anybody know much about the Avid S33? I have Googled, but can't find much about them except prices.
  20. KK6PD
    KK6PD _ . _ . / _ _ . _
    3,885
    802
    115
    Los Angeles
    2014 Nissan LEAF
    Great post. I think its clear to me what my new tires will be. Now to find some lightweight wheels to dress "Baby" up!!!
