1. Offline
    krishkal New Member
    Start a Conversation
    Nov 17, 2011
    Fremont, CA
    Your Vehicle Year:
    The plug at work is about 4-5 feet off the ground, and no provision to be able to hang the charger box. So, I have a conflict of instructions: Toyota says not to let it hang by the plug, and it also says not to use an extension cord. I am thinking that the best alternative is a short (6') heavy duty appliance extension cord. Does this sound reasonable, or should I just let it hang out there as I have been doing so far?
  2. Offline
    ukr2 Active Member
    Feb 5, 2007
    803
    136
    Victor, NY
    Your Vehicle Year:
    I also use the right-angle appliance cord. Works fine.
    Try to add a hook under the outlet or something to keep the EVSE's box off the ground.
  3. Offline
    12,390
    1,755
    Your Vehicle Year:
    or a stick with one end on the ground and a hoozie on the other end to prop up the charger box.
  4. Offline
    SCDrJ New Member
    Jun 18, 2006
    120
    Orange County, CA
    Your Vehicle Year:
    12/3 ga., 15 amp 25 foot extension cord is what I use. No issues so far.
  5. Offline
    krishkal New Member
    Nov 17, 2011
    Fremont, CA
    Your Vehicle Year:
    I got a 12 gauge 6' extension cord from Home Depot, and now I can comfortably rest the brick on the hood of my car with no problems. Problem solved! Thanks for the replies.
  6. Offline
    drinnovation EREV for EVER!
    Dec 10, 2011
    1,852
    496
    CO
    Your Vehicle Year:
    I have a rubber bungie that I carry with my EVSE and when in the garage at the Univ, I strap it to the column where there the plug is.. (since rain can enter on the level where I park.. I don't want the EVSe, but especially not an extension cord, lying on the ground).
  7. Offline
    DadofHedgehog Member
    Jun 17, 2012
    291
    96
    northern Virginia
    Your Vehicle Year:
    The Toyota EVSE brick has a li'l hole on one corner. I put a thick zip tie loop through that hole, and now I can hang the EVSE brick off the wall if there is anything I can use as a hanging point when I charge away from home (I have a L2 home charger).
Share This Page
