1. Offline
    tweetybird New Member
    Start a Conversation
    Jul 12, 2012
    Your Vehicle Year:
    My 2005 Prius has a frozen touch screen: just on the climate page. At first it would go to HIGH when I pressed low, etc...but now it is just frozen on AC auto (thank goodness the ac works).
    My dealer told me the the whole system must be replaced at a cost of $1600! I have less than 50K
    on the car and am greatly disappointed.
    Any ideas out there?
  2. Offline
    joedirte Member
    Apr 19, 2012
    279
    49
    ohio
    Your Vehicle Year:
    2003 Prius
    I
    Could it be a button is stuck like you are holding it in?
    Did you try disconnecting the 12V ground connection for like an hour>?
  3. Online
    cwerdna Senior Member
    Sep 4, 2005
    11,666
    1,660
    SF Bay Area, CA
    Your Vehicle Year:
    Perhaps you're hitting MFD issues on '04/'05 Prius | PriusChat Prius MFD is a possible fix. IIRC, there are a folks here who'd be willing to perform the repair for WAY less than $1600.
    IIRC, you might be able get a remanufactured/refurb for ~$500.
    Side question: Although I don't know of this being a symptom, are you still on the original 12 volt? If so, it's toast. It needs replacement.
    Weird stuff happening? MPGs dropping? Test The Battery | PriusChat is a way to check your 12 volt after the car has sat MANY hours or overnight. Let us know the voltages at each step.
  4. Offline
    Jul 12, 2012
    Your Vehicle Year:
    Thank you, I will try that. I was too shocked at the dealers to ask many questions!
  5. Offline
    Jul 12, 2012
    Your Vehicle Year:
    Thank you for the info. The 12V was replaced last year.
  6. Online
    Sep 4, 2005
    11,666
    1,660
    SF Bay Area, CA
    Your Vehicle Year:
    Again, if you're on the original 12 volt. It's toast. Replace it.
    edit: Whoops... our posts crossed paths.
    BTW, where are you located? Help! MFD gone BLANK! | PriusChat lists a couple repair choices.
  7. Offline
    joedirte Member
    Apr 19, 2012
    279
    49
    ohio
    Your Vehicle Year:
    2003 Prius
    I
    Well if you have a multimeter and you are disconnecting it anyways, you might want to measure the voltage. And then measure it with the headlights on in ACC mode. It would rule out one more thing, but is likely a bad board.
  8. Offline
    Jul 12, 2012
    Your Vehicle Year:
    I am in South Carolina. The car is garaged and not left out in the sun. Also, no accidents or other damage. Thanks for the repair choices link.
Share This Page
