1. Offline
    BerkshirePrius New Member
    Apr 16, 2007
    121
    Berkshire, NY
    Your Vehicle Year:
    OK, I'm comprising a list of parts needed to convert my '05 to Touring suspension, so I've been doing some research into what exactly the differences are between the Touring and Non-Touring suspension.
    According to the Toyota e-brochure for '07:
    Non-Touring: Front Suspension- Independent MacPherson strut with stabilizer bar.
    Rear Suspension- Torsion beam with stabilizer bar.
    Touring: Front Suspension- Independent MacPherson strut with tuned
    stabilizer bar.
    Rear Suspension- Torsion beam with tuned shock absorbers, springs
    and stabilizer bar.
    So basically, the only difference with the front suspension is the stabilizer bar. The rear suspension has the most differences with shocks (struts), springs, and stabilizer bar.
    I have confirmed this data while pricing out parts at Toyota Parts - Toyota Auto Parts at a discount
    Collision Catalog - 2007 - Toyota - Prius
    Front suspension, Stabilizer bar and components, Stabilizer bar, W/touring, W/touring (1) $74.63
    Rear suspension, Stabilizer bar and components, Stabilizer bar, W/touring, W/touring (1) $48.77
    Rear suspension, Suspension components, Spring, W/touring, W/touring Back (2)$37.66=$75.32
    Rear suspension, Suspension components, Strut, W/touring, W/touring Back (2)$92.96=$185.92
    Total= $384.64 (plus shipping)
    The rear struts appear to be the most expensive component. Of course, I will have to re-use certain hardware and such off my old pieces. But overall, I don't think the price is too bad...
  2. Offline
    Boo Boola Boola Member
    Feb 13, 2007
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
    Thanks for the info.
    I thought there were Touring Edition springs in the front too?
    Anyway, I've emailed my Toyota dealer's parts department and posed the same general question to them, i.e.:
    Exactly what parts do I need to change my standard Prius suspension to the Touring Edition suspension, how much $, and how much would the dealer charge me to install them?
    But I must say, I have ZERO confidence in my Toyota dealer's sales or service departments, and no knowledge of its parts department.
  3. Offline
    Apr 16, 2007
    121
    Berkshire, NY
    Your Vehicle Year:
    Well according to the parts listings, no. There are no separate parts listed (w/ touring, w/o touring) for the front suspension, except the stabilizer bar, check it out.
  4. Offline
    Feb 13, 2007
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
    Yeah, I'm getting confused. I had also thought the Touring Edition's front struts were different.
    I know that when Touring Edition guys upgrade their suspension to TRD Sportivo they swap out their Touring Edition front and rear struts and springs for TRD Sportivo struts and springs. But that doesn't answer the question about the differences between the standard Prius' and Touring Edition Prius' suspensions. Wonder what my Toyota dealer will say if and when they answer my email.
  5. Offline
    omgitsroy326 New Member
    Nov 3, 2007
    267
    Los Angeles
    Your Vehicle Year:
    so it cost $384.64 for me to make my car touring???? that's pretty cheap~
  6. Offline
    Apr 16, 2007
    121
    Berkshire, NY
    Your Vehicle Year:
    Of course that would be doing all of the work on your own, and reusing alot of the hardware and small pieces such as the strut tops, etc.
    To complete the package though, you would need the larger rear spoiler, the 16" rims, and the touring badges...
  7. Offline
    rigormortis New Member
    Feb 14, 2007
    1,318
    san jose, ca
    Your Vehicle Year:
    wasn't it efusco??? that posted pics on here concerning the rear suspension parts? so all i know is the rear's a totally different part
    and it's color coded differently
  8. Offline
    ken1784 SuperMID designer
    Dec 18, 2003
    2,858
    1,106
    Yokohama, JAPAN
    Your Vehicle Year:
    You'll be surprised, but the spring rate on the Turing is softer than the normal.
    Turing front=24N, rear=28.5N
    Normal front=24N, rear=30N
    A suspention setting is total thing including tire stiffness.
    Ken@Japan
  9. Offline
    Jul 12, 2007
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    But what is the sway bar rate? A stiffer sway bar can add stiffness to either side by taking part of the load of a single wheel bump and transfering it across the car. Are the struts stiffer?
  10. Offline
    Feb 13, 2007
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
    Hi Ken,
    Interesting that the front springs are the same in the standard and Touring Prius.
    Do you know if the front struts are also the same in the Standard and Touring Prius as Berkshire Prius concludes?
  11. Offline
    Dec 18, 2003
    2,858
    1,106
    Yokohama, JAPAN
    Your Vehicle Year:
    Sorry, but I don't have specs for dumpers and stabilizers.
    Ken@Japan
  12. Offline
    apriusfan New Member
    Apr 8, 2007
    6,050
    202
    S.F. Bay Area
    Your Vehicle Year:
    What touring badges? The 2007 Touring editions didn't come with badges.
  13. Offline
    drees New Member
    Oct 31, 2007
    1,767
    237
    Your Vehicle Year:
    Getting part numbers for the following components (Touring/Non-Touring) would help clarify things:
    Front Left Strut
    Front Left Spring
    Front Right Strut
    Front Right Spring
    Front Stabilizer bar
    Rear Left Shock
    Rear Left Spring
    Rear Right Shock
    Rear Right Spring
    Rear Stabilizer bar
    If the stabilizer bars are different diameters, we will very likely need different bushings to mount them. Most of the rest of the hardware can be reused, but often they will recommend replacing strut-top nuts and strut mounting hardware to be on the safe side.
  14. Offline
    pr4424 New Member
    Jan 27, 2008
    53
    Hershey, Pa
    Your Vehicle Year:
    So has anybody done this yet? I'm surprised this thread just sort of died out!
  15. Offline
    Feb 13, 2007
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
    Me too. I was going to ask Berkshire Prius if he did it.
    On my end, I have yet to get a decent answer from my dealer as to exactly what suspension parts are different on the Touring Edition (no surprise ... my dealer is terrible).
  16. Offline
    Gadgetdad New Member
    Feb 10, 2007
    462
    47
    Modesto, California
    Your Vehicle Year:
    :twitch: I'm curious what "tuned" means. Perhaps it is a matched pair of struts with same tension specs. For me, the 16 inch wheels and tires must be the biggest difference. The longer tail fin is a bit of class distinction too!
    Unless the new ones come with a "touring" badge, it is a DIY feature. Mine comes from the Solara Touring model.
    Lee
  17. Offline
    Feb 13, 2007
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
  18. Offline
    Feb 26, 2007
    7,432
    984
    Carmichael, CA
    Your Vehicle Year:
    Badges? Badges?
    We don't need no stinking badges! :D
  19. Offline
    Feb 10, 2007
    462
    47
    Modesto, California
    Your Vehicle Year:
  20. Offline
    Apr 16, 2007
    121
    Berkshire, NY
    Your Vehicle Year:
    Sorry, been very busy... I still plan on doing this as soon as my tax return comes in. Will keep you posted.
Share This Page
