Tow Hitch
Discussion in 'Gen 2 Prius Accessories & Modifications' started by el diablo, Apr 14, 2010.
  1. el diablo
    el diablo Team "ME"
    Houston, TX
    Does anyone have a tow hitch installed on the prius? I've seen the one stigma auto sells and was curious. I want to tow my little ruckus around to meets/rides that are farther then I want to ride in my little ruckus. :)
  2. TomKahn
    TomKahn Junior Member
    Indianapolis, IN
    Yes, I put a tow kit on my Prius. Here is a well documented Hitch installation from someone else, but it is better than anything I could do.
    http://www.evnut.com/prius_hitch.htm
    Also, the light kit is really hard. This is one way to do it without anyting to boost the amps. If you use this kit alone, make sure your trailer is using very low amp LED lights.
    http://www.evnut.com/prius_trailer_wiring.htm
    Otherwise, use something to boost the amps to the trailer in conjunction with the above kit. The Curt Circuit Protected Powered Converter w/ SMT worked for me, and can be found at: http://www.etrailer.com/p-56146.html
    There is more good info here:
    http://priuschat.com/forums/gen-ii-prius-main-forum/37707-prius-towing-capability.html
    I am currently trying to hook up a 7 pin RV hookup with an electric brake controler so I can pull a 1500 lb trailer. I am looking at a Serro Scotty Pup. It has a full size bed, AC, kitchen with fridge, and a john, what more could you want.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    +1 on the Curt Hitch. That's what I have.
    Tom
  4. el diablo
    el diablo Team "ME"
    Houston, TX
    Very informative post. Thank you! I just wanted a hitch but it won't be tow a trailer. Its going to be a tilt rack where I can slide the scooter on and off. Thanks again!:rockon:
  5. darelldd
    6,057
    388
    Northern CA
    The "someone else" says, "You're welcome" too. ;)
  6. mtskier
    mtskier New Member
    24
    missoula, mt
    i love my curt hitch! i use it for a hitch bike rack. no wiring.
  7. adept
    adept the prius novice
    Grantsville, UT
    Please let me know how that goes. Our trailer doesn't have brakes but I'd like one that does, the current trailer builds into a canvas tent and is pretty light. What kind of brake controller are you going to try? I have an extra tekonsha prodigy I may wire up if I buy a wiring harness for it.
    And that's a yakima loadwarrior on (old, used) thule bars on top.
    I want the calcars.org rear spring replacement they do to hold more battery weight, you can see the rear of that car is weighted down.
  8. Parker
    Parker New Member
    16
    Oregon, USA
    There is an easier trailer wiring kit out now that includes "plug and play" passthroughs for the tail light connections (no need for wire cutting/splicing/tapping.) It also has the isolated/powered module appropriate for the Prius, so the amperage for the trailer lights is not pulled from the Prius tail light circuits. It's all neatly put together with wiring of the right length.
    I just installed one on my 2006. It's pretty easy if you're comfortable getting at your spare tire, 12V battery and the back of the tail lights. The only complication I had was the ring terminal to connect to the 12V battery didn't quite fit, so I had to trim a bit of it off with tin snips. That may be because my 12V battery isn't stock--it's an Optima that I put in after the original battery wore out prematurely.
    I put a similar kit on my old '93 Civic long ago. On the Prius it's easier because the 12V battery is right there so you don't have to route a 12V line to the front of the car to draw power for the trailer light module.
    The Prius wiring kit is a Tow Ready T-One Connector number 118505. The package also has the logos of DrawTite, Hidden Hitch and Reese on it (but I'm confident it will work OK with my Curt hitch ;)).
    Apparently it is not very widely distributed yet; for example, I didn't find it on etrailer.com when I looked there. I found mine at an outfit called Hitch Republic through eBay, $70.52 with shipping: listing here, if it's not expired yet when you read this.
