1. Offline
    orange4boy New Member
    Oct 20, 2009
    Message Count:
    218
    23
    Vancouver BC
    Your Vehicle Year:
    2003 Prius
    Anyone here heard of this? Got it from PruisOnline
  2. Offline
    bwilson4web 03 and 10 Prius
    Message Count:
    7,495
    1,394
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    My 03 Prius had gone over 120k miles when my letter came in. <grumble>
    Regardless, one fix is to keep the throttle valve area clean. That fixed my problem a couple of years ago.
  3. Offline
    Mar 8, 2008
    Message Count:
    9,152
    1,793
    Your Vehicle Year:
    Or, if your car is not covered by this extended warranty and cleaning the throttle body / replacing the iridium spark plugs does not help, then you can buy the current revision engine ECU (with part number suffix 47054) from a salvage yard for ~$300 and replace it yourself.
  4. Offline
    sdfgsdfg New Member
    Dec 30, 2008
    Message Count:
    Your Vehicle Year:
    2001 Prius
    Thanks, my car just showed P3190 & P3101. The dealership cleared the check engine light but I haven't driven it since. Is it ok to drive the car? I am hearing and reading different opinions about what I should do. Does anyone have any further information on this? I have a 2001 Prius with just under 120k miles.
  5. Offline
    Mar 8, 2008
    Message Count:
    9,152
    1,793
    Your Vehicle Year:
    The latest Toyota TSB on this subject suggests that the throttle body interior and throttle plate should be cleaned. That TSB is posted in this forum.
    If the iridium spark plugs are older than 60K miles then they also should be replaced.
Share This Page
