Toyota Prius 2006 Lost Power! Help Please!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Friendlyx, Jun 26, 2016.
Tags:
  1. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    I have a toyota prius 2006 with about 105k miles on it, i bought it when it had 95k about a year ago. During a drive of about 35 MPH the car seemed to loose power. I pushed the peddle and it seemed like it wanted to push in but it couldn't.. It felt like i was jolting back while i was trying to push and it tried to move forward. However, for the last couple days i've noticed that maybe twice or three times the fan in the back of the car has been on. It's been trying to suck in air and it was so loud and i've never heard it before this. The weird part is that while it lost power no lights came on the dashboard.. I don't know what could be the issue and am really worried. I could use some help, thank you.
  2. S Keith
    S Keith Senior Member
    799
    327
    AZ
    2003 Prius
    The reduced power and loud fan in the back almost certainly means you need a new Hybrid battery. Typically you would have the red triangle of death and other dash indicators to suggest a problem.
    Check codes to make sure. Code reading options in my signature below.
    As a california resident, you typically get 10yr/150k mi warranty on battery; however, there are conditions.
    Good luck,
    Steve
  3. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    All this with no warning lights?
    If no warning lights, then the battery is just very very hot. It then acts just like a bad hybrid battery which means you essentially have a squirrel for an engine. It will work, but not well.
    Since you are in CA, and this is summer, this is possible. And since you bought it used, you don't know how the previous owner abused it. If you know the previous owner was a dog person, then you should really clean out the HV fan area.
    S Keith likes this.
  4. S Keith
    799
    327
    AZ
    2003 Prius
    +1 to the above.
    You'd think I'd be more inclined to go there living in Phoenix and such... :)
    The complete gutlessness of it steered me to failing battery as even when I'm at 1 bar with the fan on 6 in 110°F+, it's not as bad as he describes.
    OP, if you're not using your A/C, USE IT. Keep you comfortable, and your battery should be comfortable. Run without A/C, and you're going to cook the battery.
    WilDavis likes this.
  5. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    This is my first summer with the Prius. I did buy it used and i don't think they had any dogs but how could i clean the fan?
  6. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    i am currently using the AC at full so is there anything else i could do other than clean the fan?
  7. bisco
    48,861
    get sunshades for the windows. you can find fan cleaning directions with pics on youtube.
  8. Niomi Luna
    Niomi Luna New Member
    Belize
    Did you ever found the problem on your Prius? I been experiencing exactly the same issue you were having with an exact vehicle, almost same mileage. I have tried all the suggestions and still having the problem. Don't know what else to do.
  9. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    I don't think I ever did, I've had the car for a couple more months now and it hasn't happened since. That day was very hot and i'm guessing it added to the issue. I did clean the hybrid fan that weekend so that might have helped. Have you cleaned your hybrid fan?
