Toyota Recalls 1.9 Million Prius Hybrids Over Software Flaw (Feb. 2014)
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Montex, Aug 6, 2014.
  1. Montex
    Montex Junior Member
    Portland, OR
    Toyota Recalls 1.9 Million Prius Hybrids Over Software Flaw - IEEE Spectrum
    Faulty software in Toyota's popular Prius hybrids has forced the Japanese automaker to recall 1.9 million of such vehicles worldwide. The huge recall—representing more than half of all Prius cars ever sold—shows how Toyota has adopted an increasingly cautious stance as major automakers struggle with the rise of software-related car problems.
    The flawed Prius software can cause overheating and damage in transistors within the electronic system controlling the hybrid's gasoline-electric hybrid motor, according to The Wall Street Journal. That scenario can trigger warning lights on the dashboard and force the vehicle into a failsafe mode known as "limp home mode" that slows vehicle performance to a crawl. In "rare circumstances," Toyota warned that the hybrid system might shut down and bring the vehicle to a halt while it's being driven....
  2. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Old news but I still wonder what they actually changed. Did they change the dead time between the top and bottom FETs to reduce the risk of shoot-through? Are the IGBTs too high in gate capacitance?
    Who knows.
    48,862
    and, it's causing many to lose mpg's and some to gain.
  4. mrbigh
    3,686
    699
    Long Island, NY
    more likely they drop the switching timing in order to avoid overheating under no load
  5. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    If there is no load, then little current is flowing through the switch, and the RDSON is usually negligible. They could put it into burst mode I suppose... But that seems more like an efficiency "feature", not a recall worthy firmware update.
  6. Alicia Soto
    Alicia Soto New Member
    Stockton, Ca
    What do I do if my warning lights are going on & the car is sluggish.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,795
    Undisclosed Location
    This IS old news.
    So why if no new information in this arena, why post this "alert" again?
    It's August and that announcement is from February.
  8. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    You read the codes... The car is telling you "problem exists", so now you need to interrogate it to find out what problem. A CAN reader is needed for that, a dealership is easiest and generally also the priciest.
  9. mikefocke
    3,626
    1,623
    Sanford, NC
    CAN or OBDII? The CAN bus was an earlier diagnostic access version but don't all cars have OBDII ports today?
  10. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    OBDII is a standard port with a standardized pinout. But the communications protocol and implementation varies. In the Prius, the OBDII connector provides a standard interface to the CAN Bus. All cars sold in the US after the mid 90's (1996?) are required to have an OBDII port and it even specifies how far from the steering wheel and within drivers' reach.
    CAN was not OBDII compliant by itself until 2003 but by 2008 it was required in all new vehicles.
    The Prius uses fully compliant CAN protocol through the OBDII connector. Any modern shop with an OBDII scanner will support reading Prius codes. There are subcodes that sometimes require interrogation on the network and not all places can do that. But dealerships can, or you can with things like a Scangauge, or a Techstream (or an eBay ripoff of one).
  11. Trollbait
    11,213
    Some auto parts stores will pull the codes for free, and you can find the meaning for most online. The OBDII standard also included standardizing the codes. There are still some manufacturer specific ones, though. Which will likely include things specific to the hybrid system.
