1. Offline
    hybridtwins New Member
    Feb 28, 2009
    Message Count:
    181
    Van Nuys, CA
    Your Vehicle Year:
    2002 Prius
    Does TPMS show actual tire pressure, or does it only use an 'idiot light' approach?
  2. Offline
    stream New Member
    May 12, 2008
    Message Count:
    2,526
    394
    Long Island, NY
    Your Vehicle Year:
  3. Offline
    Feb 28, 2009
    Message Count:
    181
    Van Nuys, CA
    Your Vehicle Year:
    2002 Prius
    Too bad. Any idea what the threshold is?
  4. Offline
    jay_man2 jay_man_also
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
    8 psi below the current setting, according to what I read in a thread about the TPMS reset switch.
    My Highlander Hybrid TPMS would display the pressures, and it drove me nuts because, being OCD, I could never get all 5 (yes, even the full size spare) to be the same pressure cold or hot. The Prius approach is more my style. :p
  5. Offline
    stream New Member
    May 12, 2008
    Message Count:
    2,526
    394
    Long Island, NY
    Your Vehicle Year:
    I believe I read in another thread it's 8 psi, although I'm not sure what the source was. The owner's manual doesn't specify.
  6. Offline
    The Electric Me Go Speed Go!
    May 22, 2009
    Message Count:
    2,987
    578
    Undisclosed Location
    Your Vehicle Year:
    The threshold before the lack of tire pressure turns on the light? Or The threshold before someone is an idiot?
    Because the idiot threshold is around 34 PSI and throwing a match into your gas tank to see if it's empty.
  7. Offline
    Feb 28, 2009
    Message Count:
    181
    Van Nuys, CA
    Your Vehicle Year:
    2002 Prius
    Understood.
    it would be great if you could have the idiot light, plus the pressure display buried somewhere in a maintenance screen where it wouldn't be so intrusive.
    in any case, 8 psi seems like quite a bit of latitude. On our 2002's I try to never let the pressure drop more than 5 psi at most below the 42/40 we use.
  8. Offline
    Blind Guy New Member
    May 17, 2009
    Message Count:
    354
    190
    Springfield Missouri
    Your Vehicle Year:
    The 8 PSI threshold is movable, for example, tire pressure for the model V is 33lbs. Front and 32lbs. Rear, lets say you want to increase your pressures to 38lbs Front and 37lbs. Rear, you MUST Initialize the TPMS to recognize the new settings. Otherwise the TPMS would maintain the -8lbs. threshold for the original settings of 33/32lbs, and they would not indicate Low Pressure until 25/24lbs., rather than the desired WARNING at 30/29lbs. for the new tire pressure settings.
    To "Initialize" for new tire pressure settings, do the following:
    1. Set your tire pressure settings to their new values.
    2. With tire pressures COLD and set to their NEW values, turn the Hybrid System OFF.
    3. Turn the Hybrid System ON.
    4. Press and HOLD the "Initialize" button (located under the dash, inline with the steering column), hold the "initialize" button until the TPMS light blinks SLOWLY, and release.
    5. Wait until the TPMS light goes OUT.
    6. Turn OFF the Hybrid System.
    The 8lbs. threshold is now recalibrated to be 8lbs. below the newly established tire pressure values.
    David (aka Blind Guy)
    2 people like this.
Share This Page
