1. Offline
    syscon Member
    Start a Conversation
    Jan 14, 2012
    231
    Edm. Alberta
    Your Vehicle Year:
    Is it possible to get Prius "Traction Battery" serial number that was installed from the factory?
  2. Offline
    Cactus Hybrid Member
    Apr 1, 2007
    131
    Paradise Valley, Arizona
    Your Vehicle Year:
    Not sure what you are asking?
  3. Offline
    jdenenberg EE Professor
    Nov 21, 2005
    2,058
    508
    Trumbull, CT
    Your Vehicle Year:
    There is a serial number on the top of the HV (traction) battery case (as well as serial numbers on each module and ECU, but that requires disassembling the battery to see). In my Gen2 Prius you can see the battery serial number it if you remove the panel above the spare.
    JeffD
  4. Offline
    syscon Member
    Jan 14, 2012
    231
    Edm. Alberta
    Your Vehicle Year:
    That is one of the most expensive parts in the car.
    If I will take to a service shop after warranty expire in few years; it will not hurt to know the serial number of the battery just to make sure it will not get swap for an older units :-/
    (no this is not a paranoia) just a precaution.
  5. Offline
    Flyman New Member
    Nov 2, 2011
    63
    Packwood, Washington
    Your Vehicle Year:
    A wise precaution. I don't know how to find the serial number, but there are few things you can totally trust in life anymore and a Car Dealer sure as heck isn't one of them.
  6. Offline
    syscon Member
    Jan 14, 2012
    231
    Edm. Alberta
    Your Vehicle Year:
    Simple solution is to drill a hole in a box where the buttery is and put a padlock :-/ (simple and effective).
Share This Page
