TRD Rear sway bar for Prius v?
Discussion in 'Prius v Accessories and Modifications' started by rolling, May 4, 2015.
  1. rolling
    rolling Junior Member
    2015 Prius v wagon
    Does anyone know if the TRD rear swaybar for the Gen 3 fits a 2015 prius v?
  2. Eric "v"
    Eric "v" Member
    229
    44
    'Vegas, NV, Baby
    2013 Prius v wagon
    Cusco makes a pricey one that I may install. I already have a Tanabe sway bar i front. It does help flatten the body in cornering.
  3. Bmr4life
    Bmr4life Member
    131
    56
    Atlanta, GA
    2014 Prius v wagon
    Is Cusco the only option?
  4. Kepik
    Kepik Junior Member
    56
    36
    Bay Area, CA
    2013 Prius v wagon
    Seems like it...
    The seller on this Amazon listing confirmed it won't fit the v
  5. Joele3
    Joele3 Active Member
    118
    189
    Bay Area
    I can confirm the TRD Prius plus sway bar fits 2014 Prius V. I just took mine off 2010 Prius regular. Bolted right up I used the new Moog links K90340 and K90341. Since my originals were torn.
    MVPLRJohnson likes this.
  6. Air_Boss
    Air_Boss Senior Member
    3,908
    1,064
    New Yawk
    The TRD bar (PTR11-47010) makes a great road car greater!
    VoltecSynergy likes this.
  7. Centerpunch
    Centerpunch Active Member
    147
    136
    OH / NC
    2017 Prius v wagon
    After reading this, I decided to add the TRD sway bar to my car.
    The bar comes with everything you need, including instructions. I also looked at the photos this guy posted:
    DIY: How to install Prius PLUS rear sway bar by TRD » Balancing Act
    The instructions say you need to unbolt the shock absorbers for access, but you don’t.
    I backed my car onto ramps, which made the job very easy- probably 30 minutes total. Just need 14mm and 13mm wrenches. It comes white, but I painted the ends gray so there wouldn’t be white parts hanging below my car.
    BA850924-8823-43E2-B47D-1DD9A814AD8C.jpeg C491F04B-3426-41D4-A0B3-4720D4E2914C.jpeg 24BAC2C0-BD61-4711-8CB3-9063D4CCAF1D.jpeg 323EF156-F353-4010-BCA9-890E725B2935.jpeg B00DC3B3-A2ED-40C0-9F5F-ABB944F3E3F7.jpeg
    #7 Centerpunch, Oct 27, 2019
  8. Air_Boss
    3,908
    1,064
    New Yawk
    I likewise used Rhino Ramps. Nor did I loosen the shocks. Starting a couple of the nuts required “full commitment”, but was doable, even with meaty fingers. Left the bar white. Don’t mind the attention.
    What’s your take on handling, before and after?
  9. Centerpunch
    147
    136
    OH / NC
    2017 Prius v wagon
    Haven’t really driven it hard either before or after, but I knew a little less understeer couldn’t be a bad thing!
    Air_Boss likes this.
  10. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    276
    Redwood City, California
    I really like the use of office floor mats in this application. I thought I was smart in using the 2'-square interlocking foam pads scattered about as needed. But this wins. (y)I'll try to get some of those and use the 2' squares on top.
  11. Centerpunch
    147
    136
    OH / NC
    2017 Prius v wagon
    I have 5 or 6 of the 30x60 mats. Normally they're lined up along my workbench, but it's easy to "borrow" as many as needed for an under-car or driveway job.
  12. toy4speed
    toy4speed Junior Member
    23
    Fremont, CA
    Nice info! Will be doing the TRD rear sway bar on my 2012 Prius v, model 5. Now I just need to hunt down some good upgrades for struts!
    Centerpunch likes this.
  13. toy4speed
    23
    Fremont, CA
    Installed the TRD rear sway bar on my 2012 Prius v, model 5 today. Perfect fit, comes with everything. Just to make it easier for me, I disconnected the lower shock mount bolts (17mm), pushed the shock out of the way, they are gas filled so they extended, but not hard to compress by hand to reattach later. I believe the bar endlinks can be installed onto the lower shock mount area without the lower shock loosening, but it was so much easier with the shock out of the way. As for the ride, the car seemed more controlled (the rear at least), the ride was not any more harsh. Good upgrade. The front however still floats like a boat. A front sway bar would be nice, but better shocks might be fine, if they existed. For now, seems my only option left to improve front suspension is with one of the coilover kits. Looking at the Megan Racing kit. For decent struts/shocks, all there is are the KYB Excel-G units. Will drive the car a bit as currently set up, maybe it will be ok.
    icyrius, nssdiver and VoltecSynergy like this.
  14. rice247
    rice247 Junior Member
    Here
    I'm installing some new shocks and lowering springs soon. I might need to add this to the list.
  15. Centerpunch
    147
    136
    OH / NC
    2017 Prius v wagon
    I'll be interested to see pics of your car with the lowering springs. The Tanabes, I assume?
  16. rice247
    Here
    My wife wanted to drop it a little lower than the Tanabes. I ended up getting the RS-R Superdown springs. I'll post up some pix when I get a chance to install them.
  17. Centerpunch
    147
    136
    OH / NC
    2017 Prius v wagon
    Just wanted to update this thread with real-world driving experience with the sway bar.
    Last week a buddy and I drove from Ohio to our small place in NC, taking some twisty roads through TN and NC.
    Although the Prius is the least sporty and lowest performance car I own, it was still a fun ride, and the car is now very neutral on twisty roads. (I used to be an instructor at BMW and Porsche club track events, and have a lot of track experience in lots of different cars.)
    Also, got 40mpg on the trip, not bad. There were a few long uphill stretches, and I must admit, the motor drone does get old quickly on hills.
    But in any case, I'd recommend the TRD sway bar for anyone who occasionally drives their V enthusiastically.
  18. flexthatdx
    flexthatdx Junior Member
    22
    I want to get new shocks when I get lowering springs too and looked at the KYB Excel-G but then I found Tein Endurapro shocks/struts. Tein EnduraPro Shocks for 12-16 Prius V Hybrid (Front & Rear Set) | eBay
    Joele3 likes this.
  19. Erickunkel09
    Erickunkel09 Junior Member
    Chico
    This is why I love this community. A wealth of good information!
