Trouble Code P0AFA ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by balancedms, Sep 17, 2014.
  1. balancedms
    balancedms New Member
    22
    AVL, NC
    Anyone seen or know about this code? Can't find any info on it anywhere? Saw it come up multiple times with my own eyes. 2007 Touring
    Thanks-
  2. exstudent
    exstudent Senior Member
    2,212
    900
    Torrance, CA
    Did you pull these codes w/ an OBD2 reader or mini VCI Techstream Cable?
    Haynes book says:
    P0AFA = Hybrid Battery System Voltage Low
    Troubleshoot these areas:
    • Junction block assembly (busbar module)
    • No. 2 frame wire (busbar and wire harness)
    • Battery ECU
  3. Patrick Wong
    18,200
    6,464
    Toyota issued a T-SB-0166-09 where they recommend that the traction battery ECU and hybrid vehicle ECU need to be replaced if that DTC appears, if the battery block voltages read 0V per Techstream and the DTC cannot be reset. This is covered under the 8 year/100K mile hybrid system warranty.
    priuschat.com/attachments/t-sb-0166-09-pdf.32383/
    RonMc5 likes this.
  4. balancedms
    22
    AVL, NC
    Thank you - Very helpful
  5. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    #5 nh7o, Sep 17, 2014
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    There are no letter O's in the DTC structure.
  7. Patrick Wong
    18,200
    6,464
    Correct.
    The first character will be a letter, typically P for power train, C for chassis, and B for body are the most common. The last four characters are hexadecimal so that means the possible range is 0 - 9 and A - F.
    jdcollins5 likes this.
  8. Jack Seisman
    Jack Seisman New Member
    Annapolis MD
    We've seen this code on two vehicles. Both were Camrys. Discovered the sensor tab under the ground wire broken. Replaced the Wire Frame on both vehicles and fixed the problem. By the way, both cars ran well with all the lights on but the code will not reset.
    SFO and JC91006 like this.
  9. Tolik412
    Tolik412 New Member
    Asheville, NC
    Which ground wire are you talking about? I'm having this issue as well.
  10. Cornel
    Cornel Junior Member
    Maryland
  11. Patrick Wong
    18,200
    6,464
    I don't have pictures, but the traction battery ECU is in the battery case and the hybrid vehicle ECU is behind the glove compartment next to the engine ECU. I suggest that you should find those items and determine their part numbers so that you can buy the correct used parts to replace those.
