1. Offline
    charlotteprius New Member
    Jun 8, 2009
    Message Count:
    Charlotte, NC
    Your Vehicle Year:
    I just checked the air pressure in the tires after a couple of weeks on my 2010 II. Needed some, but found the standard air chuck(s) on my compressor would not fill. Seems the valve stem is smaller and the release pin in recessed further not allowing it to release. Had to push the tire gage very hard to register the pressure. Anyone else having problems or have recommendations?
  2. Offline
    john1701a New Member
    Jan 6, 2004
    Message Count:
    5,511
    968
    Your Vehicle Year:
    Nope, the same old pump as with my two previous Prius works as is.
    Sorry, I'm not sure why yours would be different.
  3. Offline
    DeanFL 2010 owner - 1st Prius
    Apr 13, 2009
    Message Count:
    986
    321
    Leesburg Florida USA
    Your Vehicle Year:
    Checked with my standard digital gauge and added air with standard air compressor fitting - 17" tires.
    The wheel's valve stem appears to be a bit slimmer/smaller diameter but I had zero issues working on mine. Perhaps stop at a tire store nearby and have them check it out...
  4. Offline
    fuzzy1 New Member
    Message Count:
    4,363
    716
    Your Vehicle Year:
    No problems with my gauge. But the dual Schrader / Presta head on my floor pump doesn't work well with the wheel covers. The only angle it fits leaves the hose nearly pinched.
  5. Offline
    a priori Canonus Curiosus
    Aug 14, 2007
    Message Count:
    2,668
    313
    Chicagoland (West)
    Your Vehicle Year:
    No problems with mine. I use a portable pump powered by the 12V plug in the car, and I noticed only that it was slightly easier to lock/unlock without letting air out of the tire.
  6. Offline
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,975
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    I had problems w/ the air compressor nozzle as well - the 60°+ angle versions are hard to seat w/o possibly scratching up the wheel covers.
    I was also surprised to see a lack of green caps - I thought that was an indicator of TPMS, or am I mistaken?
  7. Offline
    equake New Member
    Apr 7, 2009
    Message Count:
    155
    Los Angeles
    Your Vehicle Year:
    I think the green caps indicate Nitrogen inflation if I'm not mistaken.
  8. Offline
    fuzzy1 New Member
    Message Count:
    4,363
    716
    Your Vehicle Year:
    My past green caps were for Nitrogen, from Costco, on a car without TPMS.
  9. Offline
    bestmapman "Dream" Prius
    Apr 8, 2007
    Message Count:
    1,107
    127
    Kentucky near Cincinnati, OH
    Your Vehicle Year:
    No problems here.
  10. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    Green caps are for "Nitronized" tires. Obviously most tires are filled with mostly nitrogen.
    Tom
  11. Offline
    NYPrius1 New Member
    Jul 7, 2007
    Message Count:
    1,062
    88
    Middletown, NY
    Your Vehicle Year:
    I also Found it a bit harder.
Share This Page
