1. Offline
    scottf200 Member
    Start a Conversation
    Mar 22, 2011
    219
    61
    Chicagoland
    Your Vehicle Year:
    This sure seems like the best one out there.
    • Full Electric Mode=Y
    • Max Electric Speed=72 MPH
    • Range Per Charge=50 mi.
    • Battery Capacity=10 kW-hr
    Plug-In Supply | Plug-In Conversions for Prius and Escape
    Plug-In Prius — Gen 2 or Gen 3 (2004–2012)
    With a Plug-In Supply lithium iron phosphate add-on battery pack for your Gen 2 or Gen 3 Prius, you get the features of a 2012 OEM Toyota Prius Plug-In at a fraction of the cost — and with more than four times the electric range. Don't settle for low-power, unreliable conversion systems from Enginer, or cheap knock-off imitations. Plug in with Plug-In Supply.
  2. Offline
    Dec 29, 2007
    4,111
    264
    Your Vehicle Year:
    When you go and advert negative about other brands out there i think its arrogant and not a positive thing
    So i would not advise buying
    The trouble these guys have got into with other people there are always 2 side of a story
    -Htc Tapatalk ( sorry for auto spell correct )
  3. Offline
    bagwell Active Member
    Sep 14, 2005
    579
    the woodlands, tx
    Your Vehicle Year:
    hopefully they can backup their claims..............but at $6000 and up, they've priced themselves out of the game.
  4. Offline
    drinnovation EREV for EVER!
    Dec 10, 2011
    1,848
    493
    CO
    Your Vehicle Year:
    Good thread on the product Gen III Plug-In Supply Experiences | PriusChat
    I've had lots of conversations with friends about this as in CO there is a 75% tax credit making a upgrade of say a 2009 or 2010.. its a great deal for them.
    Don't know anyone that did this yet (know folks with the older 10kw pack, limited to 52mph) and the only real reviews are testimional's on their site.
    I have to wonder what the 72mph is doing to the motors, as they were not really designed for that speed and with the HSD, to get that speed without the ICE really meas pushing MG1 way past its normal range. MG1 rotates at more than 2.5x Mg2.. There are multiple threads here about the Plug-in-supply and I've stil not see that resolved, the conseensus seems to be you can do 72.. but its not really recommended to do it all the time. Its not a "new" 2012 OEM.. but it may be a good choice for someone that has an existing prius, in good shape -- especially in CO.
  5. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    11,328
    1,767
    Queens, NY
    Your Vehicle Year:
    Oversizing the battery pack would price itself out, like the Volt. At least this conversion would still provide ~46 MPG on regular gas which is much better than Volt's 37 MPG on premium.
    This conversion probably limit the battery power to 21 kW, unlike the 2012 Prius PHV 38 kW. I doubt it can match the official PHV's 10 years / 150k miles warranty as well.
    EREV has too many compromises. Blending the battery and gas engine in synergy eliminates them. We need to move forward, not backward.
  6. Offline
    Dec 10, 2011
    1,848
    493
    CO
    Your Vehicle Year:
    For some people, blending has too many compromises. The Engine should be for backup, not regular use. We've had PHEVs (via conversion kits) for 7 years.. This one is a bit more capable.
    The pricing does not make as much sense for those buying a 2012.. but if you have a 2010 or 2011, the price difference from tradein to 2012 PiP is going to be more than the upgrade kit. If you have a 2008 even more of a savings/option -- since the Totyota ICE will be good for 200K miles, if you are only at 100K, adding the kit will be like adding 8-10 years of life.
  7. Offline
    Jeff N Active Member
    Oct 23, 2010
    721
    246
    California, USA
    Your Vehicle Year:
    2001 Prius
    I talked to pEEf about his gen 2 Prius plugin conversion last year at an Electric Auto Association meeting in San Francisco. I think he told me that there was an ECU message he was able to send that would keep the engine off but apply enough back torque to mg1 to keep it from exceeding its maximum rpm. That results in the engine free spinning but without any gas or spark and with the valves configured for minimum pumping losses. I suspect this is what happens normally when you drive downhill faster than 62.
    This allowed him to drive on the freeway entirely on battery although he was limited by other power constraints that kept him from going much more than mid-60's mph on a flat road. I don't remember what those other constraints were (battery, inverter, etc.).
    Last edited by Jeff N, Jun 27, 2012. Reason: Fix description of engine valve control
  8. Offline
    austingreen Senior Member
    Nov 3, 2009
    6,834
    949
    Austin, TX, USA
    Your Vehicle Year:
    I remember reading that honda closed all the valves to reduce pumping losses while free spinning the ice, I wonder why toyota leaves them open instead of closed, that seems like it would still use more energy to pump air. Maybe the valves can't stay closed all the time. I would expect that the torque characteristics of mg2 along with limitations on the inverter would set that max electric speed.
    drinnovation likes this.
  9. Offline
    Dec 10, 2011
    1,848
    493
    CO
    Your Vehicle Year:
    Interesting did he say anything about the impact on fuel efficency.
    While I can see open-engine cycling to keep MG1 in rev spec, but what does that do for the engine reliabiity. Doing every nwo and then on a hill is not a problem. Are they pumping/circulating oil?
    What does moist (and maybe salty some areas) air circulating though a non-running engine do to its reliability?
  10. Offline
    Oct 23, 2010
    721
    246
    California, USA
    Your Vehicle Year:
    2001 Prius
    Ignore my comment about the valves. I don't really know how that part works. The idea was that the valves can be controlled in such a way that they just allow the engine to free spin with minimum losses.
    austingreen likes this.
  11. Offline
    usnavystgc Die Hard DIYer
    Jul 29, 2011
    1,333
    368
    Bowling Green, KY
    Your Vehicle Year:
  12. Offline
    Oct 23, 2010
    721
    246
    California, USA
    Your Vehicle Year:
    2001 Prius
    He didn't seem concerned about this causing engine reliability problems. I assume the engine would be pumping oil and maintaining its lubrication properly. I don't know what impact this had on overall fuel economy. He said acceleration was weak at highway speeds but it was fine for maintaining a steady speed for extended driving.
  13. Offline
    dbcassidy 52.5 MPG gas, 100 MPG electric
    May 13, 2008
    819
    138
    Middlesex County, MA
    Your Vehicle Year:
    Yea, Scott put out a cheap shot, maybe reaching for a new low. But thats' his choice. Starting @ 6k on up, and offering a measly 3 yr warranty - whose kidding who here? I would buy a new 2012 PIP ang get the 10 year, 150,000 mile warranty.
    DBCassidy
  14. Offline
    May 13, 2008
    819
    138
    Your Vehicle Year:
    If this Plug in Supply is so certain of their product reliability, they need to meet or exceed Toyotas' 10 year/ 150000 mile warranty.
    Blending, not EREV, is the way to go.
    DBCassidy
  15. Offline
    john1701a Prius Guru
    Jan 6, 2004
    6,761
    1,441
    Your Vehicle Year:
    Having the choice is great to blend is great... which is what the plug-in Prius offers. I've been taking advantage of that lately too. Cruising at 65 mph to & from work results in great MPG when depleting from the pack in EV-boost mode (default for high speeds) rather than switching to HV.
    Think about what happens once efficiency has climbed to about 150 MPG. Any gain beyond that suffers from diminishing returns (not much more gas saved and much higher cost). Then think about times when the Heater or A/C is needed. Do you really want to sacrifice EV range for that?
  16. Offline
    scottf200 Member
    Mar 22, 2011
    219
    61
    Chicagoland
    Your Vehicle Year:
    Someone that had one of these had a post and talked about their MPGs on a Volt related thread. I thought the company doing this was impressive because their competition could not -- as well as the manufacturer "could not" (in quotes).
    I thought from looking at the idea/specs that it made the older/cheap Prius much more like an EREV for an reasonable price. EREV is unique in that the Volt works under heavy acceleration and at common highway speeds (65+).
    Often people point out that instead of buying a brand new car that you could just drive an old one. Take a lot of energy and supplies to build a new car is their point. Or in this case an old one plus a new battery+mgmt.
    Volt: Running mainly on electricity extends the life on my ICE and it parts as well (ie. spark plugs, oil, etc.
  17. Offline
    May 13, 2008
    819
    138
    Your Vehicle Year:
    My bad, I didn't realize that the oil and spark plugs were very expensive on the volt.
    DBCassidy
  18. Offline
    May 13, 2008
    819
    138
    Your Vehicle Year:
    I totally agree, if their claims are backed up AND the overall price is lowered, then Plug in Supply has a chance.
    DBCassidy
  19. Offline
    Jan 6, 2004
    6,761
    1,441
    Your Vehicle Year:
    Blending does too. Unless you drop the pedal to the floor in PHV, even acceleration onto the highway only results in a RPM of 1500. That's pretty darn easy on the engine.
  20. Offline
    scottf200 Member
    Mar 22, 2011
    219
    61
    Chicagoland
    Your Vehicle Year:
    The Volt's ICE runs at pretty low RPM as well (1600-1700 at moderate highway speeds). For many it just is not actually running that much and what could be easier on an ICE than not running. Even GM realized that and after several weeks will run it to do diagnoistics as well as lube it. I'll do an oil change early 2013 ... when my 2 years is up. My oil life is at 56% currently after 16 months.
Share This Page
