1. Offline
    hotbrass New Member
    Sep 3, 2009
    Message Count:
    312
    26
    Cowtown
    Your Vehicle Year:
    I noticed last night that the tray beneath the gear shift console is not lighted.
    What is the best avenue to install a small light under the console to be on at night when the driving lights are turned on?
  2. Offline
    • Moderator
    Sep 22, 2005
    Message Count:
    5,905
    1,081
    NY
    Your Vehicle Year:
    Why not try to find something that is made to plug into the cigarette lighter there that lights up? I know they make air fresheners that heat up by plugging them in and they light up as well. Flashlights are also made to fit in there to keep their charge, maybe they make one that lights up dimly and has a pivot-able head on it...
  3. Offline
    Guy in WNY New Member
    Dec 27, 2007
    Message Count:
    75
    Western New York
    Your Vehicle Year:
    Install a couple of LED's like in the glove box and just have them on all the time just like the glove box. No problem o.
    Or do a search - there are a number of threads here that show you how to add extra lighting.
  4. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    been thinking the same, but not thinking about taking that console apart. I have some 10mm leds with the mounting ring that could install
  5. Offline
    hotbrass New Member
    Sep 3, 2009
    Message Count:
    312
    26
    Cowtown
    Your Vehicle Year:
    I did a quick install with a blue LED in the console using the hole directly under the gear shifter and connected it to the 12v outlet connector in the console.
    Taking the top off the console and removing the rear console was quite easy with the correct tools
    It is too bright so I am going to put a yellow difuser over it and make it green to match the rest of the LCD's, and dimmer.
    2 people like this.
  6. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
  7. Offline
    HI MPG New Member
    Aug 25, 2009
    Message Count:
    758
    115
    Orange County, CA
    Your Vehicle Year:
    Thanks Hotbrass. Out of curiosity, is the LED a direct plug into the 12v outlet or did you tap into the wires? I don't use the 12v outlet much, but at the same time, I would like to keep the area clean and not have a wire in the way.
  8. Offline
    hotbrass New Member
    Sep 3, 2009
    Message Count:
    312
    26
    Cowtown
    Your Vehicle Year:
    I tapped into the connector for the 12v outlet in the console with a brass spade made from a computer connector from Radio Shack. They are used to populate female connectors like DB9 and DB25. Radio Shack sells them in packs of 25+/- for about $3.00.
    You take the brass connector and remove one of the two leaves. Then you crimp it on your wire and shove it in the back of the connector against the wire you want to tap into. One small wrap of tape and you are done. Works great.
    Got the LED from Pepboys. I think it was three for $7. They are too bright but dont produce any heat so I just put a piece of tape with yellow paper over mine and it is just about right. I could put a resistor in line but... maybe someday.
Share This Page
