Under hood battery jump point
Discussion in 'Gen 3 Prius Main Forum' started by LNG724, Jun 20, 2010.
  1. LNG724
    LNG724
    Expand Collapse
    Junior Member
    38
    GREENSBURG,PA
    Can I connect my battery tender to the + jump point in the fusebox and
    ground point for a 2 week period instead of going to the battery to hook up my battery tender leads?
  2. derkraut
    derkraut
    Expand Collapse
    Member
    299
    26
    SAN
  3. David Beale
    David Beale
    Expand Collapse
    Senior Member
    4,998
    936
    Edmonton Alberta
    In fact you can even take the pigtail the battery tender comes with and install it under-hood so you don't have to open the fuse box.
  4. LNG724
    LNG724
    Expand Collapse
    Junior Member
    38
    GREENSBURG,PA
    Where does the pigtail get hooked up to under the hood without opening the fusebox?
  5. David Beale
    David Beale
    Expand Collapse
    Senior Member
    4,998
    936
    Edmonton Alberta
    You install the pigtail on the fusebox jump terminal (positive lead) and the chassis (negative lead). -THEN- you put the fusebox cover on and leave it on. You plug the Battery Tender lead into the pigtail. You can even route it so you don't have to open the hood, but that's just getting silly. ;)
    You'll notice the jump terminal has a nut and bolt. Remove the nut, place pigtail positive ring terminal over bolt, replace nut. Ditto for the negative lead, on a bolt on the firewall. Route the lead under and out of the fuse box. Replace fusebox lid.
    I'd remove the battery -ve terminal before doing all this, of course. When you reconnect you will have to reprogram your radio and the door window auto-down/auto-up.
    The Battery Tender comes with the pigtail lead so you can easily and quickly connect it to the vehicle of your choice, -without- having to dig to find the battery.
  6. LNG724
    LNG724
    Expand Collapse
    Junior Member
    38
    GREENSBURG,PA
    On the 2010, the jump terminal in the fusebox does not have a nut and bolt on which to put a pigtail ring. Am I missing something? Neg lead...no problem.
  7. mkyang
    mkyang
    Expand Collapse
    Junior Member
    Vancouver, BC
    Me too, I cannot see a place to put the pigtail ring under the hood. The best way I can see is to install directly on the battery terminal and run the pigtail through the auxiliary storage bin. Anyone got a better idea?
