Unplugged Power Button, Now Getting Check Hybrid System Warning! PLEASE HELP
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by San Diego Prius, Mar 15, 2014.
  1. San Diego Prius
    San Diego Prius New Member
    Hey Guys
    Installing my nav unit, and i went a step to far following the great write up DylanJones did.
    I unplugged the power button before reading this writeup! Now my car keeps saying "Check Hybrid System"
    Car is in pieces now an i am stuck! Please help! :(
    Thanks
  2. BZzap!
    BZzap! Senior Member
    1,607
    877
    Hmmm. Did you disconnect you battery ? You might try that after you have reconnected the power button. Do it at your own risk because this is just a guess on my part. You might wait until someone comes up with a more difinitive answer for you.
  3. San Diego Prius
    Ok.. Panic over.. No, didnt disconnect battery or anything..
    Just turned it on and off a few times and warning is gone and all is running fine!
    Got the Nav unit in, but the ipod controls arent working. Bummed, but that is the least of my worries right now! :)
    Thanks
    Kevin
    Dylan Doxey likes this.
  4. BZzap!
    1,607
    877
    Great! What kind of HU did you install ?
  5. San Diego Prius
    The Ottonavi Unit..
    Great functions, radio is great, nav is great, bluetooth is great, just need to get ipod working! :)
  6. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Check hybrid system message is pretty generic and is caused by an unexpected short to ground detected by the ECU.
    It can be caused by probing circuits with a multimeter, etc.
    As you've discovered, you can reset it by power cycling a few times, as long as the fault condition originally detected is gone.
    SCH-I535
    phoenixgreg likes this.
  7. BZzap!
    1,607
    877
  8. rkalbo
    rkalbo 2024 XLE
    79
    Huntingburg,IN 47542
    2023 Prius Prime
    You have to plug in your Ipod before starting it on the nav unit
