Upgrading Base Model PIP; hybrid apps on base
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jermedic, Mar 22, 2012.
  1. jermedic
    jermedic New Member
    Syracuse NY
    I was wondering if anyone has some input as to upgrading some features on the base model PIP...
    1) I understand you may be able to obtain an aftermarket autodimming mirror with homelink
    2) Leather upholstery
    3) Aftermarket LED headlights to replace energy hungry halogens?
    4) Ability to use hybrid apps on base model at some point in the future?
    Thanks,
    Jer
  2. conorearly
    conorearly New Member
    San Jose, CA
    I'd also be curious to know if anyone has any plans to upgrade the audio in their base models. I had a 2009 package 5 before I got my PiP and can definitely hear a difference between the base's speakers and the 5's JBL system. Does anyone have an idea of how hard it would be to get the base's speakers up to the advance's specs (which means + 2 speakers and an amp, I believe)?
  3. CharlesH
    2,785
    1,152
    Roseville, CA
    No way, since the hybrid apps use the Safety Connect hardware (including a built-in cell phone). Unless Safety Connect can be installed later.
  4. H2OSkier
    H2OSkier Member
    276
    16
    I'm going to look to upgrade the audio system. I'm looking at new speakers, JBL MS-8, amp, and maybe a sub.
  5. jermedic
    jermedic New Member
    Syracuse NY
    Anyone think Safety Connect can be added on?
  6. iRun26.2
    iRun26.2 New Member
    683
    111
    United States
    I might be I interested in doing the same. Please report back what you find out when you check into the audio upgrades you mentioned.
  7. stu lb
    stu lb Junior Member
    59
    Long Beach
    If you go to Mitocorp's website, you can order an autodimming w/ Homelink mirror: I haven't yet checked with the company to see if they are compatible with the PIP. I'll call tomorrow and find out, then post the answer.
  8. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Dianne at Carson Toyota arranged to have a Homelink mirror installed in my base PiP by the same folks who installed the leather.
  9. vine
    vine New Member
    Sacramento
    Hey... would it be possible for you to post a picture of the homelink mirror installed on the car? I just got mine yesterday and would really like to have homelink. I see that the mirror that I have is standalone on the car (ie there are no wires going into it). Is your autodimming as well? Is the leateher Katzkin? How much did the 2 cost you? These are the 2 items that I would like to add to the car.
  10. Captain PIP
    Captain PIP Piloti di Hybridi
    17
    Planet 951
    We added leather to the bad interior. Our dealer was able to find an aftermarket installer that did truly beautiful work.
  11. ronlprius2
    ronlprius2 Junior Member
    56
    San Francisco
    Is there a special Homelink mirror for the PiP or does any 2010-2012 version work? The wire channel from headliner to mirror looks a LOT different on the PiP than on the other models I saw in the showroom.
  12. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Here's the homelink mirror I used:
    http://www.amazon.com/Gentex-GENK41A-Auto-Dimming-Mirror-Homelink/dp/B002Z63H5M
    You dont have to buy it from the dealer. You can also find used ones (or junkyard ones) on eBay. The wire channel is separate. Some vendors include it, some do not. But it can be purchased separately as well. If you do need to buy the wire channel separately, get the short one (the one that only goes up to 6", I think). Something to keep in mind re: the wire channel, I helped a friend install one on his 2011 Gen3 and his mirror needed the "skinny" wire channel (maybe 3/8-1/2" wide?). The mirror I got had a totally different wire channel that was maybe 3/4" wide and didnt look anything like any Gentex wire channel I've seen before. But my mirror came from a Hyundai Sonata, so maybe it was Hyundai specific, not sure.
    There are installation instructions posted all over PC (but here it is anyway: http://toyotapart.com/PT374-47100.pdf
    I followed the instructions on where to find the wires to tap for power (accessory power was from the side view mirror switch, constant 12V and ground were from the front map lights). Total install time was maybe 30 minutes. Others on the forum took it to a car stereo shop and had it done. You can also take a mirror to the dealer and ask them to install it, but the price would be much higher, from what I've read here.
  13. RolfS
    RolfS Junior Member
    45
    I made the homelink mirror as part of the deal for no additional charge. As far as I am concerned it should be a standard item for the base.
    As far as I know it is the same one the advanced model comes with. The dealer said they ordered the Toyota part. Looks and functions exactly as described in my Prius manual.
  14. goblue
    goblue New Member
    Los Angeles County
    How much for the Homelink mirror and install at Carson? Thanks.
  15. FM_SC
    FM_SC Junior Member
    SoCal
    For those folks in the Los Angeles area, where can I get Katzkin leather installed on my base PIP? What is the best price you have seen?
