1. Offline
    robertp New Member
    Aug 20, 2009
    Message Count:
    28
    Indianapolis
    Your Vehicle Year:
    For the 2010 Prius
    European:
    Combined city / highway: 3.9 ltr/100 km = 25.6 km/ltr = 60.3 mpg
    US:
    Combined city / highway: 50.0 mpg = 21.3 km/ltr = 4.7 ltr/100 km
    In Europe they are using fuels with 95 octane (they do not have less than that). Here in the US 87 octane fuels. Would that be the reason for the 10 mpg difference?
  2. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Umm... no because you're not comparing the same Octane. Actually, I think 95 might be our 91 for that matter. If it isn't, then that's our 87. They're using a different calculated number than we are (It's always amusing to see people exclaim how other countries get 100 Octane).
    Testing methods are different too. In Canada, our combined city/highway number is 3.8L/100km which is close to the European number.
  3. Online
    Apr 14, 2009
    Message Count:
    3,988
    937
    Greenwood MS USA
    Your Vehicle Year:
    Not your numbers, but another problem with 'European numbers' is that they may use an imperial gallon, 5/4 of a US Gallon. There was a 88.5 MPG micro-car diesel blurb the other day that used imperial gallons and the European test. Very impressive, until you realize that a Prius using the European Test and imperial gallons gets 73.3 MPG in a midsized car.
  4. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    He converted it correctly. 3.9L/100km = 60mpg US.
  5. Offline
    spinkao New Member
    Jul 27, 2009
    Message Count:
    316
    69
    Czech Republic, EU
    Your Vehicle Year:
    You are correct. Our 95 octane Basic corresponds to the 91 octane U.S. Premium. Details can be found here:
    [ame=http://en.wikipedia.org/wiki/Octane_rating]Octane rating - Wikipedia, the free encyclopedia[/ame]
    There are also other threads on this topic around.
    2 people like this.
  6. Offline
    spinkao New Member
    Jul 27, 2009
    Message Count:
    316
    69
    Czech Republic, EU
    Your Vehicle Year:
    No, it is not because of the higher octane fuel. On the contrary, you usually get *worse* mileage when using higher octane fuel, as it has lower energy density (you can find other threads on this here). It is because of different testing cycle (I would say :)).
  7. Offline
    Mike Dimmick New Member
    Aug 8, 2008
    Message Count:
    959
    226
    Reading, UK
    Your Vehicle Year:
    Entirely because of the different testing cycle and parameters. Our numbers come straight off the dyno while the US EPA discounts their numbers a bit; in addition, the US test cycles were always stricter anyway, and now include sustained high speed/high acceleration driving, use of air conditioning, and cold temperature running.
    You can find out more about the EU tests at VCAcarfueldata.org.uk - Fuel Consumption Testing Scheme, and about the EPA tests at Fuel Economy Test Schedules.
    The numbers for the Prius on the UK test, from Gen 2 to Gen 3, improved 10% in the 'extra-urban' part of the cycle and 28% in the 'urban' part. I believe this is down to the exhaust heat capture system on the new car - we didn't get the coolant thermos on Gen 2.
    1 people like this.
  8. Offline
    RoyalBlue New Member
    May 22, 2009
    Message Count:
    66
    Groningen - Netherlands
    Your Vehicle Year:
    Earlier European test cycles had figures for city traffic, country road traffic (80 km/h) and highway traffic (120 km/h). The present highway figures are not very realistic in my view, an average speed of 63 km/h on the highway is not highway speed in my view. When I drive home form our head office, I will drive at appr. 130 km/h for 2 hours, and then you will have a very different fuel consumption. In fact many modern European petrol or diesel cars of the same size will have a better fuel consumption than the Prius in these conditions. The Prius really excells in city traffic, there the hybrid drive has a real advantage, not in constant speed situations on country roads or highways.
  9. Online
    Apr 14, 2009
    Message Count:
    3,988
    937
    Greenwood MS USA
    Your Vehicle Year:
    I did start my post with "Not your numbers" as he had them correct, I was merely pointing out additional dangers comparing the two sets of mileage.
  10. Offline
    Airbalancer New Member
    Aug 6, 2009
    Message Count:
    890
    69
    Cobourg, On, Canada
    Your Vehicle Year:
    Which country do they use km/l rating?
    last night on a 80 km trip with the cruise set at 104 km/hr the OBC read out was 3.9 l /100km
    Is there many threads on the forum about how much better metric is for units measurements :boink:
  11. Offline
    bwilson4web 03 and 10 Prius
    Message Count:
    7,495
    1,394
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    The revised, USA EPA and existing Euro testing profiles have different speed profiles. For example, the Euro speed profile on goes above 45 mph for a brief period of time, less than a minute. The Ford Focus hybrid has a hybrid transition speed of 47 mph and the 2010 Prius, 46 mph. Neither hybrid has to run in engine-only mode during the Euro test except for about one minute out off a nearly 20 minute test. In contrast, the revised USA EPA test has extensive high speed, cold weather and air conditioning phases added.
  12. Offline
    spinkao New Member
    Jul 27, 2009
    Message Count:
    316
    69
    Czech Republic, EU
    Your Vehicle Year:
    Japan, the home of the Prius ;).
  13. Offline
    spinkao New Member
    Jul 27, 2009
    Message Count:
    316
    69
    Czech Republic, EU
    Your Vehicle Year:
    The U.S. rating is much more realistic. Here in Europe, a lot of people struggle to get the advertised numbers (in any car) and are disappointed in result :tinfoil3:. In contrast, the EPA rating is relatively easy to achieve.
  14. Offline
    Message Count:
    7,495
    1,394
    Your Vehicle Year:
    I've never been a great fan of any of these mileage tests because they don't give the driver enough information to drive the performance of their car. In contrast, if we had a graph showing 'mpg vs MPG', it would be trivial for owners to drive within the optimum, performance window of their vehicles. For example, here is the 55, 65, and 75 mph (88, 104, and 120 km/h) curve for six vehicles:
    [IMG]
    This chart tells drivers different things:
    • 1.5L Prius owners - 65 mph is the knee in the curve, above this speed, mileage falls off
    • 1.8L Prius and Jetta TDI owners - 75 mph is fine, we don't know if there is a knee (my charts indicate 75 mph is the 1.8L Prius knee)
    • 1.3L Honda owners - 55 mph is probably the fastest you really want to run at for excellent mileage, it falls off rapidly.
    • 1.5L Yaris owners - it doesn't matter, bring cash for gas
    This type of information not only lets buyers make informed decisions but having bought their ride, get the most they can. It helps them after the purchase.
    1 people like this.
  15. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    And I managed to miss that. Sorry!
    Thanks for the confirmation.
  16. Offline
    spinkao New Member
    Jul 27, 2009
    Message Count:
    316
    69
    Czech Republic, EU
    Your Vehicle Year:
    Yes, I totally agree that this type of information is much more useful. However, you still need some simple numbers for the "Joe Public" to enable him to make a simple comparison, I think. Anyway, thanks for that chart, it is very useful!
  17. Offline
    Aug 6, 2009
    Message Count:
    890
    69
    Cobourg, On, Canada
    Your Vehicle Year:
    Which models are NHW11, NHW 20 and ZVW 30:confused:
  18. Offline
    spinkao New Member
    Jul 27, 2009
    Message Count:
    316
    69
    Czech Republic, EU
    Your Vehicle Year:
    Gen I, gen II and gen III Priuses :)
    1 people like this.
  19. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    NHW11 would the the Gen 1.5. The NHW10 is the Gen 1.
    What's the difference? 1.5 is the updated one that was sold around the world in 2001. The NHW10 is the JDM-only model from Dec 1997 to 2000. (Different wheels, different bumpers, no touchscreen etc etc)
  20. Offline
    spinkao New Member
    Jul 27, 2009
    Message Count:
    316
    69
    Czech Republic, EU
    Your Vehicle Year:
    You are right, I am aware of that. But because NHW10 was sold in the Japan only and NHW11 is commonly reffered to as the "gen I" in the US, i put it in this simplified way ;).
Share This Page
