1. Offline
    Happs New Member
    Mar 22, 2008
    Message Count:
    16
    Phoenix, AZ
    Your Vehicle Year:
    I'm thinking about purchasing a used Toyota Prius for use as a daily driver. I work, shop and do all activities that require an automobile in a 5 mile radius. I make a lot of short trips throughout the day (lot of starting and stopping the car at different places) so I don't have a steady cruising speed for a long period of time. I was wondering what kind of gas mileage a Prius might get under these cirumstances? What is the Prius like as far as torque/pep in concerned? I'm not a leadfoot, but I like the feeling I get from lightweight cars with wide gear ratios that have a V6 under the hood. The late 80's Buick LeSabre and Pontiac 6000 come to mind. They were peppy and didn't seem to labor when you hit the accelerator. I now drive a Subaru Forester and it's a dog when it comes to acceleration from a dead stop or when slowing down--you can feel the gas being sucked up but the car isn't going anywhere. Also, another big consideration for me is the coldness and effectiveness of the air conditioning system since I live in Phoenix, AZ and it's used pretty much 24/7 from May-October. I know in general, nothing can beat the coldness of the old R12 refrigerant. I've read that R134 isn't as cold as R12 and is more failure prone because it runs at a higher pressure. Consequently, I see a lot of advertisements for late model used cars (primarly American makes) that say a/c needs repair or new a/c compressor than in the past (1980's). What is the reliability and coldness of the Prius a/c? I'm a value shopper and have always purchased an original owner with records used car, so the Prius would be the same. What would you all say is the "sweet spot" as far as year and mileage for a used Prius?
  2. Offline
    Bill Merchant absit invidia
    May 3, 2005
    Message Count:
    4,096
    Your Vehicle Year:
    Hi Happs, welcome to PriusChat! You're kind of usage is not ideal for high milage (mpg) in any car. The Prius takes at least 5 to 10 minutes to warm the engine and exhaust system for maximum emissions reduction (maybe less there in AZ), and it uses more fuel in warming up than it does later. It still produces less pollution than other cars and I can't imagine you getting less than 35 mpg.
    The AC unit in a Prius is electric and not mechanically powered by the engine, so no seal leaks. It's a sealed unit, like you might find in a room air conditioner. It will keep you comfortably cool, even when the engine isn't running. It has cabin temperature/humidity and solar sensors and will adjust itself automatically to the temperature you set.
    The electric motors give the Prius a lot of pep from stopped, and there is no problem with merging on the highway at speed. Top speed is a scary 100+ mph. The Prius is drive by wire in that there isn't a throttle cable running from the pedal to the engine. Stepping on the go pedal tells the car you want to go and how much. The computer decides on electric motor or gas engine, or both, for best efficiency, and controls the speed of the engine, so sometimes it sounds like it's racing. You should rent one for a day for a test drive, perhaps from a dealer.
    A 2005 or 2006 model year Prius is probably your best value. Earlier had less advanced technology or new model bugs. The display screen was improved in 2006.
  3. Offline
    ken1784 SuperMID designer
    Dec 18, 2003
    Message Count:
    2,858
    1,106
    Yokohama, JAPAN
    Your Vehicle Year:
    Welcome to PriusChat!
    I do short trips too. My 2004 Prius mileage is about 15km/L(35MPG) in winter(10C:50F), however my previous car was 1994 Honda Accord Wagon 2.2L and got only 6km/L(14MPG) on the same situation.
    I see 2.5 times improvement with Prius and am very happy about that.
    What is your Forester's mileage now?
    Ken@Japan
  4. Offline
    Happs New Member
    Mar 22, 2008
    Message Count:
    16
    Phoenix, AZ
    Your Vehicle Year:
    Bill--Thank you very much for the helpful reply. Interesting that you mention "drive by wire" because when I was shopping for an SUV five years ago, I was considering the Toyota Highlander but decided against it because a lot of people didn't like the "electronic" acceleration and it's delayed response. Something about a computer or ciruit board responding to the accelerator vs a throttle cable, and hence causing delayed responses when making a quick left turn with oncoming traffic creating a scary situation. Is this basically the same thing in the Prius? Good to hear about the sealed and cold A/C unit though.
    Ken-My Forester was built in Japan and has about 50k miles on it now. I only get about 19mpg in my short trips around town.
  5. Offline
    May 3, 2005
    Message Count:
    4,096
    Your Vehicle Year:
    I don't usually jump in front of oncoming traffic, so the very slight hesitation doesn't bother me. There is lots of power, as I said. You really need to take a nice long test drive to make sure you and the Prius are compatible. You may notice several threads about the non-adjustable seat height and seat rail extensions. Some long-legged people simply aren't comfortable.
  6. Offline
    Dec 18, 2003
    Message Count:
    2,858
    1,106
    Yokohama, JAPAN
    Your Vehicle Year:
    I believe you'll see more than 40mpg on Prius in your short trips. you'll be happy with Prius.
    I know Phoenix very well. Your winter is very mild and a lot of people are traveling there, then hotel fee is going up in winter.
    In summer, it's hell. :D
    Ken@Japan
  7. Offline
    Wes Tausend New Member
    Apr 10, 2008
    Message Count:
    Bismarck ND
    Your Vehicle Year:
    My wife knows more about her Prius ...but I have observed that the car still seems to get excellent mileage while stop-and-go shopping. I would guess that the features of the design allow the engine to nearly instantly re-achieve operating temp and act as though the car never made a stop and/or was shut off. For one point, I know it has a built in thermos for the coolant and that may be why. I've heard the thermos retains some heat for days, all for restart efficiency sake.
    The car has plenty of pep in my opinion. I once had a '90 5.0 V8 Mustang that was rated at 300 ft/lbs of torque and it would kick butt. I note that the main electric motor in the Prius has 295 ft/lbs. I've heard, somewhere, that Toyota moderates some off-the-line torque to reduce torque steer and save the axles. If they didn't, it would literally fry the tires IMO. My wife had a 2000 Impala with the small 3.4 V6 (rated 180 hp) and this Prius is equivalent, or better, for zip. I haven't noted any delay in throttle by wire. My wifes other car is a 300 HP '95 Corvette and she is more than happy with her nimble Prius.
    In her 7 mile commute to work, her old Impala got about 25 mpg summer and about 18-20 winter. The Prius is doing 36w to 44 summer. FYI, the 2000's were some of the best until GM inevitably boosted power and added weight to newer Impalas. The Impala (I inherited) was good enough, and more pleasant to drive, that I retired my crude stick '94 Escort which consistantly got 31 mpg city in the summer. This model Impala was the first V6 to beat 30 mpg EPA, a record. We got up to 34 mpg with 4 adults touring. Besides far better mpg for 4-adult touring, the Prius has more rear footroom than the Impala or most other cars, including the Camry. If I live long enough, I'll inherit it.
    I'm with you in normally preferring a good used car to new, but the Prius is chronically in a catagory of its own, at least around here. When my wife became serious about buying a Prius, she couldn't ever conveniently test drive one. New or used, they never stayed on the lots very long (just hours) and it was like when she was trying to buy her Wii (Nintendo game) for Christmas. She got lucky.
    When we finally called the dealer, prepared to order on excellent reviews alone, he just got a new Prius in. She test drove, fell in love and bought on the spot. In spite of it not being her original preferred color or package. The other customer, that watched it get unloaded from the truck and test drove minutes earlier had gone home to think it over. Too bad for them. At least they finally got to test drive one.
    New/used has very little to do with smart-buying this extraordinary popular model. Either all the spots are sweet or it doesn't apply. New makes just as much sense as used. They are all reliable. If it's a used hi-miler, sell it sooner and get another; you'll get your money back.
    As far as saving, the dealer did knock about 800 bucks off sticker when I made a lower offer, which surprised me. Apparently it never hurts to ask. But, I've never paid anywheres near sticker or asking price before, the times I bought new (very few) or used.
    Test drive one if you can.
  8. Offline
    Happs New Member
    Mar 22, 2008
    Message Count:
    16
    Phoenix, AZ
    Your Vehicle Year:
    Wes,
    Thanks for the insights. What great torque the Prius has! Too many auto makers have been focusing on horsepower instead of torque. This trend will reverse itself in the era of urbanization and high fuel prices. European city drivers have enjoyed the good torque for many years.
  9. Offline
    Mead5.0 New Member
    Apr 15, 2008
    Message Count:
    Meadview Az U.S.A.
    Your Vehicle Year:
    I haven't had my Prius long enough to know about the summer heat. I bought mine from a dealer in Kingman Az with 6200 miles on it. The dealer said Toyota is very fussy about how the dealers handle used cars. He said they are to be kept seperate from the regular cars and have an extensive check sheet which can be viewed at any time by a Toyota rep. The one thing you might check if you buy a used one through a dealer, is they gave me a better warranty than a new one,through Toyota, eg 7 years- 100,000 miles.
    I also bought the touring model as I live 60 miles from the nearest town and it rides and handles much better than the regular model. I just love this car. You will too. Have fun. Nick.
  10. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,757
    2,806
    Northern Michigan
    Your Vehicle Year:
    The "pep" of a Prius is deceptive. The hybrid system gives the Prius what amounts to a CVT, so there is no shift shock. The first time you drive one you are going to think it doesn't accelerate very well, and then you look at the speedometer and start slowing down before you get a ticket.
    Tom
Share This Page
