used steering rack installed -- now dealer says it needs ECU
Discussion in 'Generation 1 Prius Discussion' started by bjustin, Apr 5, 2010.
  1. bjustin
    bjustin New Member
    27
    seattle
    2002 Prius
    (I'm not sure when to start a new thread...hope I'm not going overboard.)
    After the used rack was installed last week, violent shudder disappeared, but now I have no power steering. The shop reported:
    after the gear was replaced the technician noted the same C1513 for power steering torque converter and a C1515 code fault code. he was able to clear C1513 and noted C1515 calibration of torque sensor zero point not performed. Recommend customer go to Toyota and have calibration performed.
    The dealer said recalibration is tricky since my car is an 02' Prius and the rack that was installed is from an 03.' Apparently the software got updated for the 03' ECU. How does he know recalibration wont' work?
    He suggests I get a used ECU, perferrably from the same salvaged vehicle the rack came from. (a new ECU plus installation is $1000)
    Do you think this is a good next move? If so, what is the part number I need? The salvage guy who pulled the rack from the vehicle says he needs it. Is it 89661-47054?
    thanks folks!
    Brad
  2. bwilson4web
    15,407
    Did they hook up the steering gear motor power connector?
    I'll check the manual for the calibration protocol this evening and post a synopsis.
  3. bjustin
    bjustin New Member
    27
    seattle
    2002 Prius
    shop receptionist left me a voicemail saying they hooked up everything and that there were only 2 plugs and a ground. i used the phrase "steering gear motor power connector" but receptionist wasn't certain what that meant and may have garbled phrase when communicating it to tech.
    thanks Bob for checking on calibration protocol, although at this point girlfriend is telling me "all this research is taking forever -- just do what the dealer instructs."
    she may be right. I'm not sure all the time I've invested in this has been worth the money I've saved...
  4. bjustin
    bjustin New Member
    27
    seattle
    2002 Prius
    quick additional question: the junkyard guy needs to know which ECU to pull. Is it the one located on right side dash or is it the one which is part of the battery pack?
    I've got a mixture of part numbers and with all the cross-referencing it's got me confused A9650-47190, 89661-47054, etc...
  5. bwilson4web
    15,407
    • right side, behind to right of glove box - engine ECU, not what you want
    • right side, above the engine ECU - that should be the EMPS ECU
    • battery ECU - not what you want
    I'm not having any more luck finding details about how to access and remove it.
  6. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    144
    Fort Worth, TX
    My toyota tech friend had mentioned to me before that the standard toyota procedure for the power steering rack was to replace the rack and the ECU together. He never knew or asked why. But I guess there must be a reason, by the sound of it.
  7. Patrick Wong
    18,199
    6,464
    Maybe this is true if the customer is bearing the expense.
    The power steering gear on my 2001 was replaced at 15K miles and 3 years of age, under warranty. Here are the replaced parts per the repair invoice:
    44200-47060 Link Assy, Electric
    95381-03028 Pin, Cotter
    Then the front wheel alignment was checked.
    (BTW, the four tires were also replaced at that time at no charge, under the customer goodwill policy.)
    Back to Brad's OP, maybe he should buy the salvage 89661-47054 engine ECU anyway, since he may have engine no-start problems in the cold Seattle winter if that ECU revision is not already installed.
  8. bjustin
    bjustin New Member
    27
    seattle
    2002 Prius
    Hey Bob,
    We are getting the ECU tomorrow, do you think installing it requires the dealer?
    Thank you for all the help you've provided! We would like to give you our old rack if you want it.
    thanks,
    Brad & Melissa
  9. bwilson4web
    15,407
    I've got one I need to do forensics on already but thanks for the offer.
  10. tochatihu
    tochatihu Senior Member
    8,995
    3,507
    Kunming Yunnan China
    2001 Prius
    Perhaps this image will be helpful - taken from the prius parts list which is in files of one of the yahoo groups. For DIY installation I think that a lot of dash removal would be required.
    I don't believe that when the PS in my 2001 Prius was replaced (7/2001 mfr date), the ECU was replaced.
  11. bwilson4web
    15,407
    Interesting, my "Electrical Wiring Diagram" shows that as the "Body ECU:"
    "Prius Electrical Wiring Diagram 2003 Model", Toyota, Pub. No. EWD493U, pp. 20.
  12. bjustin
    bjustin New Member
    27
    seattle
    2002 Prius
    Thanks guys -- you're awesome.
    I was able to explain which ECU i needed and where it is located to the junkyard guy thanks to the information Bob gave me. He pulled it from the same 2003 salvaged Prius we got the rack from. The salvage guy said the part number is 89650-47190. This is the same part number the dealer told me I needed, which is a good sign.
    total cost plus shipping: $125.
  13. tochatihu
    8,995
    3,507
    2001 Prius
    I can only confuse the issue further :( having never actually been inside that part of the dash. Actually, your 89650- number looks good (to me) with 47190 suggesting that it is a newer version than the ones in my first picture.
    Put it wherever it fits. Kidding. Put it in to replace your 89650-xxxxx.
  14. bjustin
    bjustin New Member
    27
    seattle
    2002 Prius
    We received the emps ecu and it looks like it would be easy to install, only question is it safe? anyone know if there are any precautions to take while installing it? I want to try just plugging in the new one to see if it works before doing the complete installation.:confused:
  15. w2co
    w2co Member
    366
    81
    Longmont, CO.
    I would disconnect the 12V battery, wait at least 10 minutes before pulling any connectors, and wear an anti-static wrist strap connected to the body before handling it.
  16. bwilson4web
    15,407
    You are at the bleeding edge of our knowledge. I didn't see an ECU replacement set of instructions and don't know if it can be done via the glovebox access or if the dash needs to be removed. Perhaps ask the guy who pulled the unit?
    But then for a "sanity check," perhaps put the unit in so the connectors can be moved over and a quick drive to see if it solves the problem. That makes the task of full replacement make a lot of sense.
    If you are really paranoid, pull the ground wire off of the 12 V battery and that will ensure no power. Then make sure there is a good ground wire to the case.
  17. bwilson4web
    15,407
    Perhaps it makes sense to understand the connectors and signals:
    Column 1 Column 2 Column 3
    0 connector pin signal
    1 A (E3) 1 white TRQV steering shaft torque sensor
    2 A (E3) 2 green TRQ2 steering shaft torque sensor
    3 A (E3) 3 black TRQG steering shaft torque sensor
    4 A (E3) 4 red TRQ1 steering shaft torque sensor
    sensors
    1 B (E4) 1 yellow M1 DC motor drive
    2 B (E4) 2 yellow-black M2 DC motor drive
    heavy current drive
    1 C (E5) 1 black PIG power input
    2 C (E5) 2 black-white PGND power ground
    heavy current input
    1 D (E6) 1 white-lavender SIL data link connector
    2 D (E6) 2 gray RLY power relay signal
    3 D (E6) 3 pink-blue TC data link connector
    4 D (E6) 4 black WRR brake ECU
    5 D (E6) 5 black-yellow IG ignition switch signal
    6 D (E6) 7 yellow WL combination meter signal
    7 D (E6) 9 gray-green TB data link connector
    8 D (E6) 10 white WRL brake ECU
    signals and controls
    I'm thinking one way to improve 'road feel' might be to put a load resistor in the motor drive circuit. Just measure the motor resistance and then add enough to reduce the motor power to a fractional value.
  18. bjustin
    bjustin New Member
    27
    seattle
    2002 Prius
    Hi All,
    I ended up taking a road trip with my vehicle which is why I haven't reported back in so long. Even though i had no power steering, the car drove fine: all 1800 miles.
    I ended up having the dealer install the ECU. It didn't solve the problem. There is still a warning code and "PS" displayed, (power steering.) All they could recommend next is to install a brand new steering rack.
    They do not know why it doesn't work but suggested that when you start mixing parts the software is not compatible with the other computer parts in your car. He said it's safe to go with purely mechanical used parts, but anytime there are electronics involved, it is uncertain whether they will work.
    The dealer said the only way to get some answers about what used parts might work is to talk to someone who specializes in the parts.
    Now I'm not sure what to try next. Maybe I'll take Patrick's suggestion and just buy a new rack.
  19. bwilson4web
    15,407
    For a favor, could you pull the ECU connector B4, the one with the yellow and yellow-black wire and measure the motor resistance?
    Thanks,
  20. bjustin
    bjustin New Member
    27
    seattle
    2002 Prius
    sorry it took a while to reply. I will try to find and pull that plug for you and measure the motor resistance, but as my skills are limited, may have to get my mechanic to do it.
    Brad
