1. Offline
    angelajf07 New Member
    Sep 3, 2009
    Message Count:
    Your Vehicle Year:
    When I purchased my 2010 yesterday, the dealer mentioned using "b" mode when in steep grades but also mentioned using it when coming to a stop. He said it would help charge the battery at a higher rate and would "save" the brakes. DID I GET SOME BAD ADVICE?
  2. Offline
    nparker13 New Member
    Jun 6, 2009
    Message Count:
    112
    CT
    Your Vehicle Year:
    Yes, I believe its actually worse for fuel economy to use it when its not needed, it uses the engine/transmission more than regen motor. Someone who knows better should verify this though. Note that going down a steep grade is what B is made for (as riding the brakes is not good either).
  3. Offline
    rachaelseven New Member
    Jul 7, 2009
    Message Count:
    618
    205
    Adams, MA
    Your Vehicle Year:
    Yup. Bad advice. The B mode wastes energy by using the compression of the engine to stop the car. You're much better off leaving it in D, unless it is a VERY LONG downhill grade... we're talking mountain descent here. The B mode is just to save you riding the brakes after the battery has already fully charged. Plenty of posts on the subject here if you use the search function, so lot's more information available.
  4. Offline
    JimboK One owner, low mileage
    May 1, 2006
    Message Count:
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    Technically the dealer is correct about B mode both saving the brakes on a long downgrade and charging the battery at a higher rate. The latter should be considered a byproduct of it and not a goal. The advice of the others is sound.
    See this for an in-depth discussion of B mode.
    1 people like this.
  5. Online
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    Use B mode only on steep downgrades. Otherwise it simply wastes energy.
    Tom
  6. Offline
    bwilson4web 03 and 10 Prius
    Message Count:
    7,495
    1,394
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    Sometimes you want to waste that energy instead of heat stressing the traction battery. The reason is battery charging is a heat generating, chemical reaction. For example, here is chart that shows what happened to my traction battery temperature when I force charged it:
    [IMG]
    Ordinary driving around town was warming up the battery on a cool night but I stopped at the bottom of the hill to put on a maximum battery charge. A 9C temperature rise came from the forced charge.
    This is a well established characteristic of NiMH battery chemistry as this chart from a paper titled "Thermal Behavior of Small Nickel/Metal Hydride Battery during Rapid Charge and Discharge Cycles" Takuto Araki, Masato Nakayama, Kenichi Fukuda, and Kazuo Onda" has figure 10 charts showing temperature response of an AA sized battery under charge and discharge shows:
    [IMG]
    So just to make sure, I did a hill descent test with and without "B" and though there was not a dramatic increase in temperature, it did go up by 1C for this 525 ft. hill:
    [IMG]
    Now the reason for concern is 'heat is the enemy' of our NiMH batteries. If someone were going up and down a bunch of hills where the car was cycling between charge and discharge ... say foothills near mountains ... they could 'heat pump' their traction batteries to some impressive temperatures. If you'd like more details including what happens when NiMH batteries are overcharged, here is my report: Prius Battery Photos
    Ultimately, the choice is yours but my rule of thumb is to use "B" when I'm looking at say a mile or more of downgrade at high speed. But I'm trying to get maximum life out of my 2003 Prius with 121,000 miles.
  7. Offline
    Sep 3, 2009
    Message Count:
    Your Vehicle Year:
    Thanks! Great info!! I LOVE MY NEW PRIUS!
  8. Offline
    a priori Canonus Curiosus
    Aug 14, 2007
    Message Count:
    2,668
    313
    Chicagoland (West)
    Your Vehicle Year:
    You really don't need mountain passes to take advantage of B mode, though I will suggest to you there are not many places in Minnesota where the B mode would be advantageous. The city streets in Duluth may be steep enough, but not long enough. There are sections of roads in the river bluff country and far SE MN where B would work well, but it really wouldn't be necessary unless you were already fully charged (HV battery) going into a long descent.
    One nice thing about the B mode, though, is it will keep your car at a fairly steady speed. So, if you start a long, steep descent, you could put it in B mode while moving at 60 mph, and the car should maintain about 60 mph so long as gravity allows.
    If you really want to learn more, please follow the earlier link to a great description of B mode.
    (AND: Welcome to PriusChat and Congrats on your new 2010!!!)
  9. Offline
    yardman 49 New Member
    Mar 26, 2009
    Message Count:
    606
    68
    Northern Kentucky
    Your Vehicle Year:
    Hello Angela:
    I live in a hilly, but not mountanous, area. On some of the steeper local hills, I love using B mode when descending. It helps me from not having to ride the brakes going down these hills.
    The Prius is constantly monitoring the traction battery temperature, and in most cases won't allow the car to overcharge (or overheat) the battery. There's even a cooling system for the traction battery, with a fan that can run at three speeds (four if you count "off" as a speed). So either manual regenerative braking or using B mode for going down hills won't usually cause a problem.
    However, you did get bad advice about using B mode for stopping. I can see where some may like the feel that a manual transmission gives them from "downshifting". and how they might like using B mode for this purpose, as it makes it feel like they are "doing something useful", akin to what downshifting would do. However, this will actually limit your braking regeneration somewhat on level areas, so it should not be done.
  10. Offline
    MaggieMay New Member
    Apr 6, 2009
    Message Count:
    528
    67
    Gloucester, MA
    Your Vehicle Year:
    Bob - this makes me wonder if there's a relationship between the temp of the battery and the mysterious red top line of the the battery indicator. (see http://priuschat.com/forums/gen-iii-2010-prius-main-forum/67994-all-bars-battery-indicator.html) only a few of us have seen this, but Red usually means Warning or Hot - like - "Be careful you dope, the battery's overheating!!"
    Could that be possible?
  11. Offline
    Message Count:
    7,495
    1,394
    Your Vehicle Year:
    I don't know. BTW, I was headed to square dancing last night and had a large hill to descend at a high speed. The "B" worked perfectly but the hill was not tall enough to light the last bar ... darn it. Next week, I'll try it with "D" and light brake pedal to see if it will 'do the trick.'
  12. Offline
    Jul 7, 2009
    Message Count:
    618
    205
    Adams, MA
    Your Vehicle Year:
    If you'd prefer not to light the brake lights while you're maximizing your downhill regeneration in "D", just set the cruise control. The CC will activate regeneration to keep your speed from climbing, up to the maximum regen the battery can handle, without lighting the brake lights. That's what I do on the long descents around here and I get a lot more charge back into the battery that way than when I am forced to use "B" mode. You can "ride the brakes" to get the exact same effect - as long as the pressure is light, you won't actually be using the friction brakes. But it is nice not to have the lights lit up so that if you actually plan to stop, people will know.
  13. Offline
    ken1784 SuperMID designer
    Dec 18, 2003
    Message Count:
    2,858
    1,106
    Yokohama, JAPAN
    Your Vehicle Year:
    From the link, you can read "Under 20 mph, if the engine is not already running and your foot comes off the accelerator, B mode simply regenerates reasonably heavily [30A or so] into the battery".
    Please note that the 20 mph threshold is for the Gen2, and it is now approx 24 mph on the Gen3.
    Ken@Japan
  14. Offline
    May 1, 2006
    Message Count:
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    Ahh, thanks for updating our Gen3 body of knowledge. I hadn't seen that reported previously.
Share This Page
