Valve Stem Core Replacement?
Discussion in 'Gen 3 Prius Main Forum' started by crellion, Nov 28, 2012.
  1. crellion
    crellion Junior Member
    48
    Does anyone know how easy is it to replace the Valve Stem Core of a tire? I got a hunch one of my Gen 3 Prius' valve stem core pin is slightly depressed and might be leaking air.
    Is it expensive and do I need to worry about the TPM or is that a separate component?
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    288
    66
    Phoenix
    It appears to be all in one...here's a diagram:
    James Powers likes this.
  3. crellion
    48
    Oh man - that looks expensive...
    Hmm - I wonder if there is anyway to correct the pin depressing? Can I just take a small plier and see if I slightly adjust the central pin to a more center position (which can hopefully prevent the depression)? Has anyone done something like this before?
  4. phoenixgreg
    1,157
    288
    66
    Phoenix
    Hard to say but I also wonder how much these valve stems/TPMS senders cost. Also, it brings up the issue as to how long the battery life in the sender will last and if the battery itself can be replaced. My diagram doesn't show any way to do that...sorry.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Let Toyota warranty it.
    mad-dog-one likes this.
  6. crellion
    48
    I'm actually surprised that these pin could be damaged like this (could it be a factory-defect)? I mean - normally these valve stem pins are pretty rugged since a lot of people forget to leave the plastic caps on them and drive them around all the time with the pin exposed...
  7. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    I had a Camry that came like that. For whatever reason the one pin had more friction than the rest and did not always reseat well after being depressed.
  8. crellion
    48
    Even with this TPM all-in-one-module - it is considered a "Schrader Valve" right?
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Yes. Certain parts can be replaced. Discount Tire usually rebuild them when you buy tires.
    The kit is like $5.
    TPMS Rebuild Kits
  10. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    775
    359
    They are very easy to change. Your local auto parts store should have replacements as well as the tool to remove and replace them.
    Threej likes this.
  11. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    In addition to the cost of the TPS, there is an additional charge to have your car programed to recognize the new TPS. If you're still under warranty, it might be best to give this problem to Toyota.
  12. phoenixgreg
    1,157
    288
    66
    Phoenix
    So it looks like most of the TPMS sender can be salvaged? I checked your link for the rebuild kit but could not see the battery (unless it's that tiny cylinder inside the stem). Good to know though for older G3s going out of warranty.
  13. Avi's Advanced Automotive
    775
    359
    The battery is not replaceable, however, I haven't seen one die yet. Usually a flat tire takes them out.
  14. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Batteries are NOT designed to be replaced. They are encased in pot metal. That said, I have seen someone on the Corvette forum hacking it to replace the battery and reseal the case with silicone. It is a dirty job and the guy said 1/5 TPMS gets ruined in the process.
  15. phoenixgreg
    1,157
    288
    66
    Phoenix
    I was afraid of that...I wonder what the expected life of a TPMS sender battery is and how much each is to replace? There's also a recoding process as each one has a unique transmission ID - add that to the cost.
  16. Avi's Advanced Automotive
    775
    359
    Prii got them in 2006, I see many of those going strong. The replacement cost depends on where you go. I know I replace them for much less then the dealers around me are charging, maybe even half.
  17. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Bingo. But if the valve stem is aluminum be sure to use a valve stem core that is made to work in an aluminum stem or there will be corrosion.
  18. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Yea the problem is you have to reprogram the ECU with the new IDs with TechStream. That's might be a dealer deal, unless you use aftermarket TPMS that can clone the original IDs.
  19. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    I know someone with a 10 year old GM product that is still on the original TPMS batteries. That's on the long side for battery life but 6 or 7 years seems to be pretty common.
  20. RobH
    RobH Senior Member
    2,369
    978
    70
    Sunnyvale, California
    The little part with the pin and spring can be unscrewed with one of the valve caps that has the slot in it. Just buy a set of valve stems ($5?) and a set of the caps. Let all of the air out of the tire by pressing the pin, unscrew the old stem using the new cap, screw in a new stem, and reinflate the tire. The TPMS unit should be fine.
    Threej and Tande like this.
