Very Strange Lexus Crash
Discussion in 'Fred's House of Pancakes' started by Tickwood, Aug 29, 2009.
  1. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    Notice: this is based on TV news reports. But in a suburb of San Diego last night a man driving a Lexus (year and model unknown) called 911 from a freeway to report her accelerator was jammed and the car was doing 120 mph. Shortly afterward the car ran off an exit, through a red light hit a small SUV and then and ran on a couple of hundred yards into the Brush, catching on fire and killing four all four passengers.
    If you have time to call 911 why cannot you turn the key off or shift to neutral?
    Fatal crash sparks brush fire in Santee; 4 killed - San Diego, California News Station - KFMB Channel 8 - cbs8.com
    "Stuck" Accelerator Blamed for Four Deaths | NBC San Diego
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    She had time to call 911 but didn't have time to turn off the car? Either she is blond or this is an urban myth.
    Tom
  3. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Wouldn't shifting into Neutral do the same thing without losing power to the electronics?
  4. fuzzy1
    10,045
    That's what I'd think, better to let the engine overspin itself to death in neutral than to ride it out. Not being an auto transmission guy, I must ask if there is anything blocking a shift to neutral under full load?
    And I also had enough long-ago experience with engines stalling while in motion, to not fear loss of power assist for steering and brakes. The car is still controllable without assist.
  5. RobH
    RobH Senior Member
    2,369
    978
    70
    Sunnyvale, California
    Things to try:
    1. Step on brake. The car will at least slow down.
    2. Turn off ignition. On the Prius, press and hold the Power button (5 seconds?)
    3. Shift to neutral.
    4. Check for something stuck under the gas pedal. Maybe the floor mat has jammed it.
    5. Controlled crash. Rub the freeway crash barrier. Rolling the car is better than hitting a fixed object (put your seatbelt on?).
    6. Dial 911 after the car is stopped. There are more important things to do than talk on the phone.
    7. Maybe you don't need a car capable of 120 mph.
  6. 71Corolla
    71Corolla New Member
    17
    You can never under estimate what some people will or won't do when panic sets in. Any modern autos brakes will overpower the engine and stop the car.
    I wonder what someone calling 911 expects the emergency response to do exactly? Next time I'm driving in icy roads and feel the car slipping, I guess I better call 9-1-1.
  7. Jabber
    Jabber Chicagoland Prius Guy
    703
    213
    Chicago
    wow. Easy fix. Throw it in neutral. Let engine redline until death. Better it than the people around you.
    BTW, if the engine is racing, and you apply the brakes, you will boil the fluid which will cause you to lose all braking power eventually. Better to just turn the car off and use regular brakes.
  8. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    So, like +90% of all new cars, did this Lexus have by-wire throttle control? Was a floor mat causing the pedal to remain full on?
    Reminds me of that news story a few years ago where a lady drove into a canal. Rather than escape, she called 911 but the area she was in, wasn't equipped for precise location determination
    She remained vague on the phone, until the car shifted underwater and she drowned
    Miami Drowning Incident
    There was a time when the average human was expected to think quick, on their feet, or face the consequences. It appears we have become so fuzzy, so brain dead, than we even need warnings on aviation deicing agents "warning do not drink!"
  9. 71Corolla
    17
    The fluid will not boil, unless it is old and has not been changed for a long period of time, then it will contain moisture. Unless you purposely drag the brakes with the engine at full power, stomping hard on the brake will stop the car, even if the accelerator is floored. Braking capacity of a modern auto is far greater than engine power, unless like I said, you purposely drag the brakes which will create tremendous heat.
    But either way, just PUT THE CAR IN NEUTRAL. The engine won't blow up it has a rev limiter.
  10. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    It would be interesting to hear the 911 tapes to see what he was saying, had done, etc.
  11. Tickwood
    334
    101
    San Diego
    2020 Prius Prime
    Re: Very Strange Lexus Crash gets stranger
    Now, again acccording to TV nes, the driver was an off-duty CHP Officer drivng a loner car. Supposedly his wife called 911 to say the brakes didn't work and he couldn't slow down.
    So it was an experienced driver.
  12. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    So he wasn't a bright cop. Any confirmation on the hair color?
  13. fuzzy1
    10,045
    Any history of domestic violence in that family? Or job-related enemies who had access to the car?
  14. jayman
    13,439
    639
    Winnipeg Manitoba
    The story keeps changing and getting weirder
  15. Hybridtheory
    Hybridtheory New Member
    New York City
    A very sad accident.
  16. Tickwood
    334
    101
    San Diego
    2020 Prius Prime
    Re: Very Strange Lexus Crash -the latest
    The car was a loaner from a local (El Cajon) Lexus dealer. the dealer is not releasing any further information.
  17. Tickwood
    334
    101
    San Diego
    2020 Prius Prime
    The car was a 2009 ES350
  18. liverbomb88
    liverbomb88 Push the Button!
    130
    16
    In a galaxy far far away...
    The news story notes the accident occurred at the T intersection with Mission Gorge. Northbound SR125 becomes SR52 at a 90-degree left curve here, so the driver must have realized he was going too fast for the turn. He went straight off the off-ramp. Even if the driver remembered how to turn a "push to start" car off, perhaps the steering wheel would have locked and he would not have been able to make the turn anyway.
    This is tragic. I hope the investigation will figure out what went wrong.
  19. qbee42
    18,058
    3,073
    Northern Michigan
    The steering wheel wouldn't lock. Most likely the driver panicked, which wouldn't be too surprising having this happen in a loner car. Clear thinking in a crisis is a difficult thing.
    Tom
  20. 71Corolla
    17
    One thing about turning off the engine is you will lose power steering, so I personally would not do that unless it was a last resort. I found this article @edmunds.com.
    How To Survive the Top 10 Driving Emergencies
    A couple things of note:
    Emergency #3: Stuck Throttle
    Thanks to things like loose floor mats and a poorly placed racecar throttle cable, I have experienced stuck throttles. Although this will be a rare occurrence for most drivers, if your engine starts racing away uncontrollably, it must be stopped immediately.
    Take these actions:
    • If the engine started racing when you pushed the brake, release the brake. If the engine stops racing, you were actually pushing the gas by mistake.
    • Put the transmission in Neutral (and/or push in the clutch). Don't worry about the engine when you shift into Neutral: Engine speed limiters on modern cars will prevent damage. And it's OK if you get Reverse: The engine will either stall or act as if it were in Neutral.
    • If you can't get Neutral, switch off the ignition as a last resort. Today's cars don't allow the key to turn to the locked position if the car is not in Park, and the car will be much harder to steer once the engine is off since the power-assist will not be working. Fortunately, with the engine off, there's still plenty of reserve braking power to stop the car. Of course, if the car is equipped with a newfangled keyless ignition, getting Neutral may be your only hope
    Emergency #4: Sudden Acceleration
    Also called "unintended acceleration," this is identical to a stuck throttle...except it's not a mechanical failure but rather the driver accidentally pressing on the gas. As an instructor, I have had numerous panicked students push the gas in the mistaken, but unshakable, belief they were on the brakes. (Left-foot brakers more familiar with automatics frequently push the clutch.)
    Know this: In every well-maintained modern car, the brakes will easily overpower the engine. If you're truly pushing the brakes as hard as you can, the car will stop even with the engine going full speed.
    _________________________________________
    It's a tragic story honestly, but IMO the driver simply panicked. And anyone can test to see if a full throttle car can be stopped by braking power. Find a lonely stretch of road, get up to highway speed, floor it, and try to stop the car. It will easily stop. Disclaimer: I don't recommend trying this on a public road!
    For the car to race out of control and be impossible to stop regardless of driver action, the off button would have to fail, the brakes would have to be defective, and the transmission selector would have to fail and not allow putting the car in any other position besides drive.
