1. Offline
    Sundog105 Sundog105
    Nov 19, 2008
    Message Count:
    Roswell NM
    Your Vehicle Year:
    I'm a Newbie, with a 2008 "Option 6." What noticable visible differences are there, to distinguish a "Base" 2008 from an "Option 6" 2008 (other than the wheels, Base has six spokes, Option 6 has seven, but that's really hard to tell when the vehicle is moving)?
    Same question but about distinguishing different years?
    Sundog105
  2. Offline
    gak27 Cured but not Healed Edition
    Jun 18, 2008
    Message Count:
    96
    Akron, OH
    Your Vehicle Year:
    Externally, virtually nothing except fog lights (pkg 4 and above)... (btw, if you have 7 spoke wheels you have a Touring, even Option 6 'standard' models have the 6 spoke wheels)...
  3. Offline
    morpheusx Professor Chaos
    Mar 6, 2007
    Message Count:
    1,514
    Akron, OH
    Your Vehicle Year:
    above poster is exactly right.
  4. Offline
    rigormortis New Member
    Feb 14, 2007
    Message Count:
    1,318
    san jose, ca
    Your Vehicle Year:
    u can tell a base and any other package by looking for the rear view camera
    u can tell a package 2 from its lock buttons
    3,5, & 6 do not have any external clues that i can think of
    if u see fog lights then its at least a package 4, or a touring (any package)
    if you see a prius driving by and you stick your head out of the window
    you can tell the package from the number of buttons on the display screen too
  5. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    backup camera, SKS buttons, fogs, HIDs (unless it's a base Touring which has HIDs as standard equipment)....
    so basically what the others have said so far.
  6. Offline
    Sundog105 Sundog105
    Nov 19, 2008
    Message Count:
    Roswell NM
    Your Vehicle Year:
    Hey guys/gals, thanks for the info!
    I read somewhere that the rear Wing was different on some models; anyone have info on that?
    Also noticed that some antennas are different, but don't know how to correlate that either.
    Sundog105
  7. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    The Touring Edition had a longer rear spoiler. The antenna is the same (unless they changed it to a sharkfin but that is not a Toyota option)
  8. Offline
    mingoglia New Member
    Oct 25, 2007
    Message Count:
    841
    Gilbert, AZ
    Your Vehicle Year:
    x2, so your (referring to the poster) spoiler is actually slightly larger (by less than a half inch I believe) than a base model. You really have to look closely to tell. It's easiest to tell when a touring and non-touring are parked side by side. It's almost laughable that Toyota has separate spoilers since they're so close in size.
  9. Offline
    Rokeby Member
    Jan 21, 2008
    Message Count:
    2,890
    591
    Ballamer, Merlin
    Your Vehicle Year:
    The wing/spoiler on the Touring is maybe 2 inches longer that the Standard
    one. Don't know how much, if at all, it helps the aero.
    The length does make it much easier to break/crack the Touring spoiler/wing,
    especially if someone uses it as a handle to close the lift gate...
    a very big NO-NO.
  10. Offline
    JimN P719 of ???
    Nov 26, 2006
    Message Count:
    4,487
    229
    South Jersey
    Your Vehicle Year:
    2006 & later have side badges & clear tail lights. 2005 & earlier the top third of the tail light is dark. Color can also be a clue. Magnetic Gray is 2006-, Spectra Blue Mica is 2007-. The red changed from Salsa Red to Barcelona Red 2006-.
  11. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    My friend almost did that. I yelled at him to stop before he could apply any pressure.
  12. Offline
    KAR IDEA New Member
    Dec 7, 2007
    Message Count:
    438
    Yonkers, NY USA
    Your Vehicle Year:
    Sundog, the most obvious difference between a Generation 2 Touring Prius and a Generation 2 Prius are the wheels: 7 spoke with a plastic cover vs 6 spoke with a trim ring.
  13. Offline
    KAR IDEA New Member
    Dec 7, 2007
    Message Count:
    438
    Yonkers, NY USA
    Your Vehicle Year:
    I did that! It didn't crack though, it creaked. Then my wife looked at me and said "Dave, we've only had the car for a week, please don't break it!" :( Now I use the built in leverage handle...
  14. Offline
    van-island New Member
    Aug 24, 2008
    Message Count:
    17
    Vancouver
    Your Vehicle Year:
    I am going to take possession of my Base 2009 next weekend, but I went and took a peek at it on the lot and I am pretty sure it has the longer spoiler. It also has the roof antenna... although I don't know if this is standard...?
    When I actually get the thing I will confirm!
  15. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    You can use the Toyota emblem for leverage if you must use the outside of the car to close the hatch.
  16. Offline
    Boo Boola Boola Member
    Feb 13, 2007
    Message Count:
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
  17. Offline
    cycledrum I like Prius
    Apr 9, 2008
    Message Count:
    5,266
    432
    NorCal
    Your Vehicle Year:
    I use the Toyota emblem on the hood to close - I set the hood down, make a fist and give a push.
  18. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    sounds good to me. I just "hit" the centre of any hood once I lower it down. I don't like dropping it from a height and letting it slam itself close.
  19. Offline
    B. Roberts New Member
    Mar 11, 2005
    Message Count:
    293
    36
    Glacial Maine
    Your Vehicle Year:
    That's why there are so many rumply hoods out there. Lower your hood to 6 to 12 inches above closure and then just drop it. No huge impact or damage will result. I've seen a lot of dented hoods and hatches from that little push to close.
  20. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    The touring spoiler is 1 inch longer than standard. I measured it.
Share This Page
