Walking away from heat-pump water heater
Discussion in 'Environmental Discussion' started by bwilson4web, Jul 8, 2014.
  1. bwilson4web
    15,400
    Our existing electric water heater failed on the outlet pipe . . . corrosion. But I've been planning to replace or relocate it anyway. But now is sooner than expected.
    I looked hard at the GE heat-pump water heater but near as I can tell it is really designed to go in a basement. The external temperature range makes me question whether I can keep it in a shed butted up to an exterior wall, south east facing. So I'm thinking going a two-stage, solar setup:
    • main heater - electric similar in size to the existing one
    • solar pre-heater tank - using collectors to pre-heat the water feeding the cold-water line of the electric
    Any experience or thoughts about this approach?
    The previous water heater is in an unheaded 'auxilary room that I have hated for years. Now that water has throughly soaked the framing, I have a good excuse for replacing it with a proper, built, two-car garage and work area. The water heater will go to an exterior wall on the old air conditioner platform, possibly built-up, with water taps midway between the two bathrooms and kitchen.
    Thanks,
  2. fuzzy1
    10,045
    I believe this is a reasonably common and efficient approach. But the double tankage doesn't work in some homes, that is why various other solutions try to fit into a single tank. I had thought about solar DHW since the turn of this century, but local installation costs are high and the layout of my home puts the storage tanks quite far from the good collector locations, making winter freeze protection more difficult.
    I finally went the HPWH route a year ago, installed in the garage (moved away from the kitchen closet). Most of the units had ambient low temperature cutouts right in the middle of my typical winter garage temperature range, so I went with the ($$) Airgenerate both for its lower ambient cutout, and for its external venting, keeping the garage from chilling as much. It has worked quite well.
    Too bad you must decide quickly, before a new generation of very high efficiency R-744 (CO2) heat pump water heaters reaches American shores. Here is a lab report on an R-744 mini-split system acquired in Australia and tested locally:
    Lab Test Report on Sanden Split System CO2 Refrigerant Heat Pump Water Heater
    https://conduitnw.org/Pages/File.aspx?RID=1901 (Sorry, I can't embed the link today.)
    The Lab Test Report contains the performance test results for this CO2 refrigerant, split system heat pump water heater. The results include the tests required for all heat pump water heaters for ranking according to the Northern Climate Specification. The tested Northern Climate Specification Energy Factor is 3.2 and its Delivery Rating is 7.5. This report is posted in order to share it with the Heat Pump Water Heater Collaborative and the Advanced Heat Pump Research Advisory Task Force. The date of this report is 9/18/2013 and its author is Ben Larson. It was produced under contract with Washington State University Energy Program which is funded by BPA to do this research.
    For reference, all the other HPWHs on the American market have Northern Climate Spec EFs of just 1.8 to 2.2. The 3.2 rating of this unit would be a game changer, if the price is affordable. Apparently the R-744 systems can hit COPs of 4 to 5 in warmer climates for water heating alone, or 8 when integrated into AC systems. See discussion at:
    CO2 Heat Pump Water Heaters
    https://conduitnw.org/Pages/Article.aspx?rid=425
    PS. Here is a graph of our daily water heater energy use, as measured on a standard watt-hour meter installed in its branch circuit.[​IMG]
    The first month, upper left corner, is the previous regular electric heater, not fully insulated after a temporary move. The rest is an AirGenerate ATI66. The first gap is due to the watt-hour meter being temporarily moved to the new solar PV system while awaiting the official production meter. Other apparent gaps represent trip shutdowns, not actual averages over long spans. Blue line is for the quasi- daily reading, red line is a moving average (N=5).
    #2 fuzzy1, Jul 8, 2014
  3. Trollbait
    11,327
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I was thinking along similar lines, particularly in the Southern US. If the heat pump was placed in a well insulated room with fixed South facing windows it could conceivably operate in a 90+ F ambient environment year round. The COP would be fantastic.
    I would also think about a way to pump the cool, dehumidified exhaust air into the home for free cooling during the warm season (is that year round in AL ?)
    Regarding 'classic' passive DHW: it seems (and can be) very attractive in cost and eco profile, but long runs of copper become expensive, and forget about it if you have to pay a plumber.
    fuzzy1 likes this.
  5. fuzzy1
    10,045
    If planning this route, do check out the max ambient temperatures of the intended HPWH, compared to the conditions in the intended space. My Airtap/Airgenerate has a default max ambient temperature of 110F. It can be reprogrammed to up to 130F, but I don't know just what problems that could lead in to.
    This is where a ducted unit will help. The Airtap was always available with outlet ducting, but I believe the GE Geospring, and the A.O. Smith-Voltex (and its many rebranded versions) can now be ducted too. Probably even retrofitted to existing installations.
    I see some other units (Bosch, Nyle) with ducting available. But as they are not on the Northern Climate approval list, I am not familiar them.
    #5 fuzzy1, Jul 9, 2014
  6. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    Bob, can you unscrew the outlet pipe from the HWH with a pipe wrench and replace it with a nipple to stretch it's use while you decide what to go to for better efficiency?
    I switched to an Ariston water heater from Lowe's, under $200. and the energy side of my power bill is now under a buck a day...convection oven, induction cooktop and LED lights are helping too, and I'm no longer dumping waste heat into my home for the AC to wrestle with. Good luck! R.
    bwilson4web likes this.
  7. bwilson4web
    15,400
    I'll give it a try but it looked like the water was coming from the hot-water outlet at the top of the unit. But you have given me an idea to try:
    • Remove the hot plumbing.
    • Investigate the exposed outlet to see how bad the corrosion is.
    • See if I can ream to good metal; insert a tapered, high-temperature PVC coupling and/or tap the remaining good metal (if any.)
    • Pressure test and monitor.
    In engineering: GOOD, FAST, CHEAP . . . pick two. If I can buy some time, I'll have options to do the replace heater right and include options for a solar preheater tank. This could work IF I can kludge the temporary repair.
    What I'd really like would be a pipe repair that could be inserted and expanded to grip inside the original, hot water, outlet pipe. But Mr. Google found a water-activated, fiberglass, wrap that might work . . . long enough. I only need about 60 days to buy time to do the job right.
    Those are attractive fut we have power issues to the kitchen. I don't like to tap the range or oven power circuits but the existing 110 VAC lines already have a 1 kW microwave and .8 kW toaster. Use one at a time or trip the circuit breaker. If I were to go with one of those, I would want a circuit that turn off the water heater when the other loads are running. Not that hard of a problem but still.
    #7 bwilson4web, Jul 15, 2014
  8. hill
    8,070
    Hey Bob, a passive solar system hooked up to an instant flash water heater (ours is natural gas) might be a good way to go.
  9. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    Bob you want a plastic insert for the hot outlet nipple? you may be in luck..it already exists...your cold side already has a "dip tube", a white plastic pipe with a small flange on the upper end that just slides inside the cold water inlet nipple and makes the incoming cold water go all the way to the bottom of the tank to avoid mixing with and warming the hot water that is in the top of the tank. I see it as a replacement part on Home Depot site, "water heater dip tube", $4.00 you would need to cut it short, about 3" long, and clean and dry the inside of the offending fitting, and glue your new liner-tube inside with your favorite snake oil. R.
