1. Offline
    joerdie New Member
    Jan 23, 2008
    Message Count:
    61
    Cincinnati Ohio
    Your Vehicle Year:
    Hello all. Got my Prius last week, so far I am loving it. The only issue I have is warming it up in the morning. I live in Cincinnati, OH and the window frost is in full swing now. With any other car, I would start the defrost and go inside for 5 min. Whenever I try this in the Prius, it doesnt do anything. Anyone else with this issue?
  2. Offline
    mkiefer83 New Member
    Apr 15, 2007
    Message Count:
    40
    Canton, MI
    Your Vehicle Year:
    The climate control in the Prius won't blow any air until the block gets warmed up enough to generate some usable heat. I'm thinking 5 minutes might just not be enough time to generate said heat to defrost your windshield.
  3. Offline
    joerdie New Member
    Jan 23, 2008
    Message Count:
    61
    Cincinnati Ohio
    Your Vehicle Year:
    So should hit start 2x and wait longer? Like 10 min?
  4. Offline
    joerdie New Member
    Jan 23, 2008
    Message Count:
    61
    Cincinnati Ohio
    Your Vehicle Year:
    I have also been reading about blocking the grill to increase MPG. I would think that this would also help.
  5. Offline
    seasalsa New Member
    Feb 29, 2004
    Message Count:
    1,277
    Kent, WA
    Your Vehicle Year:
    Grill blocking will help.
    You did not mention what setting you are using on the climate control.
    I leave it on AUTO/AC set at 74 degrees and hit the front and rear defrost on the wheel. It should clear the windows and mirrrors in 5 minutes depending on how thick the ice is. There are electric resistance heaters that will produce heat until the ICE warms up.
  6. Offline
    icarus New Member
    Apr 12, 2007
    Message Count:
    4,543
    839
    earth
    Your Vehicle Year:
    The answer is to get in and drive. The car will warm up way faster with the grill blocked however. You can "trick" the car into running the ICE by putting the car in drive and drive for a few feet. The engine will start and continue to run until it is warm. If you don't move the car it may not start.
    Icarus
    PS Also, an engine block heater will keep the coolant warm so that it warms up that much faster. (Remember, the heater will not get warm until the engine generates enough heat to heat the coolant. If you want to get warm faster, leave the heat OFF until the engine gets warm. Turning the heat full on will only delay getting warm!)
  7. Offline
    nerfer A young senior member
    Mar 1, 2006
    Message Count:
    2,417
    166
    Chicagoland, IL USA, Earth
    Your Vehicle Year:
    Grill blocking will help only when the car is moving. If it's sitting idle in the driveway, it does almost nothing (unless it's facing into the wind).
    You do need to hit the defrost button, but it should take care of it within 5 minutes. Also keep in mind, if you have the auto climate control set for defrost/feet, then turn it off and back on, it goes to the feet/face setting, which won't blow any air until the engine is warm. The defrost setting will blow air right away because it can use the A/C to dry the air which helps even before the heater is ready (at least that's my understanding of why it blows right away). Have you tried running the defroster with a lower temperature before turning off the car, to make sure the interior isn't humid as it cools off overnight?
    That said, if the windows are fine, there's no reason to let the car warm up. Just get in and drive, and you'll improve the mpg considerably.
  8. Offline
    Danny Hamilton New Member
    Apr 30, 2007
    Message Count:
    926
    84
    Greater Chicagoland Area
    Your Vehicle Year:
    You are holding the brake down when you press the power button, right?
    There should be no need to press the power button 2X.
    If you aren't holding the brake when you press the power button, then that is your problem. The car can't start up the gas engine unless it is in "Ready" mode. If it can't start the engine, then it can't generate any heat to defrost your window.
    Make sure the "Ready" light is lit on the dash, and then make sure the windshield defrost light is lit on the dash. If both those lights are lit, 5 minutes should be long enough. If it is exceptionally cold out, you might need to wait a bit longer for the window to completely defrost.
  9. Offline
    joerdie New Member
    Jan 23, 2008
    Message Count:
    61
    Cincinnati Ohio
    Your Vehicle Year:
    Thanks for the quick response.
    Come to think of it, I have not been pressing the break when turning the car on during cold mornings. Will start that tomorrow.
    I do have the auto A/C set at 70 but have tried it both ways with no outward difference.
    I will most likley be blocking at least the bottom of my grill tonight if not both.
    Thanks!
  10. Offline
    jayman New Member
    Oct 21, 2004
    Message Count:
    13,430
    581
    Winnipeg Manitoba
    Your Vehicle Year:
    That is *not* the correct way to "start" the Prius! You may even end up severely discharging the battery, requiring a tow to a Toyota dealer
    The correct way to "start" the Prius is to get in, step on the brake pedal, then poke the power button. The car will "boot up" and in cold temps, the gasoline motor should start
    If you need to "trick" the gasoline motor to run, just floor the gas pedal and release. The gas motor will instantly start
  11. Offline
    Apr 30, 2007
    Message Count:
    926
    84
    Your Vehicle Year:
    A ha! That is exactly what your problem is.
    If the car isn't in "ready" mode (foot on the brake when you turn it on), then the gas engine will not turn on and it won't generate any heat. Additionally, the A/C compressor won't run, so moisture won't be condensed out of the incoming air.
    All you are doing is running the fan and blowing ambient air at the window. That would be the same ambient air that created the frost in the first place. At best you are changing nothing on the window, worst case you might actually be adding additional frost!
    Please come back and let us know if this fixes the problem.
  12. Offline
    morpheusx Professor Chaos
    Mar 6, 2007
    Message Count:
    1,514
    Akron, OH
    Your Vehicle Year:
    The ICE will start up almost immediately from a cold start (going into Ready) if the Front Defrost is on, as long as the temp isn't on Lo.
  13. Offline
    Mar 27, 2004
    Message Count:
    7,384
    760
    United States
    Your Vehicle Year:
    Time to re-read the owner's manual.
  14. Offline
    joerdie New Member
    Jan 23, 2008
    Message Count:
    61
    Cincinnati Ohio
    Your Vehicle Year:
    I paid attention this morning and had my foot on the brak as I hit start. The car did behave the way I wanted it so all is well. I have read the entire manual, (something i swore i would never do,) but sometimes people arent perfect. I was most likely just excited every morning.
    as an aside, I have been very happy with my milage. I understand that winter and break in period can keep milage extremly low. So far, I have used a tank and a half of gas and am averaging 49.3mpg.
    Thanks for the help everyone!
  15. Offline
    Apr 15, 2007
    Message Count:
    40
    Canton, MI
    Your Vehicle Year:
    That's pretty solid mileage for being in the 'Natti in the winter. I'm up by Detroit and have been re-learning to keep the MPGs up (second Prius, sold the first and bought the second) and I've been managing only around 42-ish.
  16. Offline
    Mar 27, 2004
    Message Count:
    7,384
    760
    United States
    Your Vehicle Year:
    Keep in mind that the fastest way to warm up the Prius (just like any car) is to drive it, gently for the first minute or two. Warming it up by sitting and idling is (1) slow, and (2) kills your MPGs (you get zero MPG while idling).
    If the *inside* of your windshield is chronically frosted then you should get into the habit of using defrost and external air during the last few minutes of the previous drive. That should dry out the cabin enough to prevent interior frosting. If the outside of the windshield is frosted, then you need a scraper :_>
  17. Offline
    Sandra Murphy New Member
    Sep 30, 2007
    Message Count:
    Oshkosh, WI
    Your Vehicle Year:
    I guess I would consider myself a 'newbie' - I've had my Prius for 9 months. This is my first winter with it. I was really happy to see someone asking about 'warming the Prius up' in the winter. I don't have any problem with frost on the inside of my windshield because I know how to start it up. What is an issue with me, is how long it takes for it to warm up on the inside. I have a 13 mile ride to work every morning, and last week when it was below zero degrees, I just barely felt heat from the vents when I reached my destination. Is this normal?
  18. Offline
    SpartanScott Michigan Member
    Mar 22, 2007
    Message Count:
    60
    Howell, Michigan
    Your Vehicle Year:
    For a 13 mile drive I would say it can be normal for temps below -5F. My drive is also exactly 13 miles so I've been testing out different heating vs. MPG methods. It turns out the best way to heat the car also helps with MPG compared to "auto" or full blast. It's best to leave the heat off for the first 2-4 minutes(or miles) to allow the engine to warm up quicker. Then you can turn the heat on. If you had the heat on the first couple minutes all you would be geeting is cold air anyway. I keep the fan speed below Medium, which guarantees me hot air the rest of the ride. If using a higher fan speed, than you have the option of lowering it to get hotter air (and better mileage). Also a personal preferance is that I favor using the upper vents so the air blows on me rather than heating the whole car.
    On a side note I have also tested NO heat or AC for the 13 mile drive at sub 10F temp and it consistantly increases the trip mileage by 4-5mpg. (helps the engine shut off while coasting and at lights/stop signs). I've slowly been able to increase my winter mileage from 47 to 50mpg.
    Hope this helps anyone trying to stay warm.
  19. Offline
    TeamWenz New Member
    Jan 12, 2008
    Message Count:
    34
    Madison, WI
    Your Vehicle Year:
    How can you stay warm when it's freezy pop cold outside brrrr. I have also found once the car is warm to decrease the fan speed. This allows the car to shut off or run on electric motor only. Hard to believe small things like turning down the fan make a difference in mileage.
  20. Offline
    JimN P719 of ???
    Nov 26, 2006
    Message Count:
    4,487
    229
    South Jersey
    Your Vehicle Year:
    I've used a de-icer spray (alcohol) on the windshield and lowered the driver's window a bit for ventilation to keep me from fogging the inside of the windshield. With the grill blocked the ICE turns off at the second or third stop. At this point, close the window, temp set to 73, fan low, auto off. "Cold" here is usually in the 30's. It's been in the 20's a couple of times. I don't know how well this works farther north.
Share This Page
