waterpump leak? Just replace the gasket!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by stay_thirsty, Oct 22, 2014.
  1. stay_thirsty
    stay_thirsty New Member
    jax, florida
    Why are people replacing the pump when it is the gasket that is leaking?
    Like others, I also see some pink fluid dried on the outside of the pump and am researching what I need to do.
    Is it acceptable to just replace the gasket? or are there issues with the pump itself as well?
    Thanks
  2. JC91006
    16,468
    8,383
    It's not a gasket leak
    48,930
  4. exstudent
    exstudent Senior Member
    2,210
    899
    Torrance, CA
    You could be the first to just replace the gasket, reuse the old pump, then report back after a few months as to the status.
    If the gasket had gone bad, you would be loosing coolant regularly and (most likely) at a much greater volume. Gaskets rarely go bad, fortunately.
    Luscious Garage Gen 2 water pump, weep hole leakage. LINK
    Illustration of water pump and weep hole.
  5. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    On mine coolant did come from weep holes. Gasket was perfect could have reused that with no problem.
  6. stay_thirsty
    jax, florida
    Ohh, OK.
    I didn't understand where, exactly, the leak was coming from. I feel a little stupid now, I didn't look close enough at it.
    Thank you all for your reply's.
