Weathertech Window Visor (In Channel) Installation
Discussion in 'Gen 3 Prius Accessories and Modifications' started by merash, Sep 19, 2014.
  1. merash
    merash New Member
    I cannot for the life of my install these things. I got the front drivers side on but then window wouldn't close so I took them off. I followed instructions to a T. Does anyone have them installed and could take pictures.
    Edit: I haven't even attempted the read installation. I don't know how I feel about peeling back the weather stripping.
    P.S. 2014 Prius Two
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    You need to give the visors some time to bed in the channel. Just close the window slowly in manual until it will eventually close in auto. It took about a week before mine would close in auto every time.
    The back ones can be difficult. There is a website listed in the instructions that has a very good video with excellent installation procedure. The weatherstripping will pop right out and pop back in after installing the clips. I needed the video to understand the proper installation of the rear clips.
  3. mrbigh
    3,686
    699
    Long Island, NY
    I choose the easy way few Prii back, since early 2005 and went with the outside door frame installation, it does look awesome.
  4. jdcollins5
    5,131
    1,338
    Wilmington, NC
    The visors do look good on the Pri, whether inside or outside. They look OEM. I just prefer the inside channel. YMMV.
  5. TRUC NGUYEN
    TRUC NGUYEN Junior Member
    2014 Prius Plug-in
  6. merash
    merash New Member
    Almost... however the driver side deflector broke.
  7. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    No clips in rear mentioned in video I saw.
  8. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Are you sure you watched the correct video for your Prius ?
  9. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Pretty sure I did. I will recheck. Link from the ordering page of the 2014 model
  10. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
