Wet brakes grabbing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nad6211, Mar 20, 2005.
  1. nad6211
    nad6211 New Member
    Has anyone else experienced a serious case of brakes grabbing, usually after coasting down to a stopping point and applying the brakes at about 6 mph and in cold, wet weather? I have a 2004 with 23,000 miles. Toyota service staff indicate no similar complaints and, of course, I have never been able to replicate the experience while a technician is riding or driving the car. The experience occurs very intermittently.
  2. rick57
    rick57 Member
    572
    Circleville, Ohio
    I have not run into this at work. No warning lights on? Braking ok the rest of the time? Nothing else unusual? :roll:
  3. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    17
    By “cold†do you mean below freezing?
    By “wet†do you mean you just drove through standing water?
    Wet brakes can cause a grabbing sensation until the rotor and pads are dry. After washing my Prius, I drive around the block and apply the brakes to dry them off. The Prius brakes are very grabby when wet from my car washes! Unfortunately since we have regenerative braking, this method of drying the brakes is not as easy as with standard brake systems, because the Prius mechanical brakes only engage at low speeds . . . so it takes more applications to heat the brakes in order to dry them.
    If you got your brakes wet and then the weather turned freezing, you may have had ice on the brakes . . . even more dangerous . . . and difficult to fix.
  4. m1j1tc0rn
    m1j1tc0rn New Member
    92
    I have the exact issue you are talking about here.
    Sometimes, it even "pops" in reverse when I start it in the morning (like i'm running over a small rock or something).
    Anyway, my brakes grab in cold/wet weather, as you mention, and I was debating bringing it in. I actually think they don't always needs cold wet weather, but it hasn't happened in a couple of weeks.
    I'm in a 2004 with 18k miles on it and the grabbing didn't start until about 4months ago.
    -r
  5. Brian
    Brian Member
    480
    Bakersfield
    Dido, I washed my car Friday then it rained Saturday. During the rain, it would do the exact same thing. At about 6mph it would just "grab" and stop too abruptly. I thought I must have left soap on the front disc brakes or something.
  6. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    From what has been described, I wonder if it really is the pad material grabbing on the rotor? Or if it isn't the caliper itself actually sticking on the slide rails. This car has full floating caliper, right?
    It's really important to take the caliper off once a year and clean/lubricate the slide points. I do it twice a year - every fall and every spring - but we have a lot of road salt to deal with here.
  7. Tideland Prius
    16,065
    Aside from grabby brakes (which I haven't experienced yet), does anyone's front disc brakes squeak when wet?(usually occurs when doing a full lock turn)
  8. Dion
    Dion New Member
    128
    Jersey City, NJ
    My brakes started grabbing after I coasted down a long hill on a rainy day about 6 months ago. Now they grab always when it rains.
  9. nad6211
    nad6211 New Member
    Thanks to all for the various descriptions related to "grabbing" brakes. In fact the brakes do also "sqeal" or sqeak when the grabbing sensation happens. I also notice that backing out of the garage and applying the brakes as I roll backwards down my driveway the brakes have a grinding kind of sound. I am not aware that I have had the brake issues during any weather but wet, cold and wet, cold and slushy, and heavy morning fog and cool out weather conditions. The temperature has been 35-40 degrees, not necessarily freezing, for the brakes to act this way. Never have any warning lights come on and, as I indicated, when the technicians run all the diagnostics they find no problems.
    Most of the time what I am describing is not dangerous . . . just a bit surprising and annoying for what is otherwise a comfortable ride. Every once in a while the experience is dangerous in terms of the sudden stop with someone tailgating too closely and, at least as I imagine the possibility, in very slick conditions one could momentarily lose control. I did have one situation with three passengers and the brakes grabbed and the jolt was both a surprise and pretty uncomfortable for one of the passengers who was leaning forward already and had a bit of a whiplash effect.
  10. jayman
    13,439
    639
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Tideland Prius\";p=\"74305)</div>
    If by "wet" you mean damp and not saturated, I think most disk brake systems make noise when wet. They also can be grabby if damp. My 2000 GMC Sierra had four wheel disk brakes, and the only time they semed to work well was when the pads were damp, say after I washed it.
  11. Tideland Prius
    16,065
    well, I guess damp then :)
    Hmm, well I didn't notice this noise in the Camry. Perhaps... wait.... hmmm.... The Camry's brakes get used all the time while the Prius doesn't. Could that be a factor?
  12. jayman
    13,439
    639
    Winnipeg Manitoba
    Since the disk brakes in a conventional vehicle like a Camry are used all the time while braking, they generate more heat and dry off faster. Good point.
  13. sparkymarvin
    sparkymarvin Member
    144
    At the airport.
    Your first post nad6211, made my ears perk up a bit. I have had the same sort of situation and brought it to the dealer, but was never able to replicate it for them.
    It does occur intermittently, but I also found that grabbing is conjoined with the "putt-putt" sound that the brakes make when slowly taking one's foot off the brake (the pressure relief system in the right front of the car) when at a complete stop.
    It's a strange quirk, but I treat it as just another part of my car's personality. Even my girlfriend has a few quirks, but I still love her too.
    ~Andrew
  14. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    it has been relatively dry here so i have never heard or flet anything resembling squeal rattle or vibration.
    i just rotated my tires last week and i noticed that both front and rear wheels spin freely without the hint of drag on them and the discs on the front show slight signs of rust on the rotor which tells me that i must be doing something right as it seems that they are not being used very often.
