what are these damage wires??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ramirezja, Sep 3, 2015.
  1. Ramirezja
    Ramirezja Junior Member
    I found these frayed wires while I was changing the transmission fluid the other day. Does anybody know what they lead to? And maybe a part number to where I can order a new wiring harness.
  2. hachislowku
    hachislowku New Member
    Central Texas
    Looks like you found yourself an o2 sensor !!!
    Ramirezja likes this.
  3. xliderider
    xliderider Senior Member
    7,842
    3,099
    Honolulu, HI
    Wow, that's pretty messed up. No codes, or warning lights?
  4. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    agreed it looks like an O2 sensor, you can use electrical tape on the wires, just wrap them individually
  5. Air_Boss
    Air_Boss Senior Member
    3,902
    1,064
    New Yawk
    Yep. Looks like it snagged on something. As suggested, wrap each lead individually, then cover with a piece of split wire loom.
    Ramirezja and hachislowku like this.
  6. Ramirezja
    That's what I thought they were so I wrap them individually and just took them away. No codes or any other indications that they were damaged I just found them when I was underneath the car. Was thinking about just ordering a new harness all together but we'll see.
  7. hachislowku
    Central Texas
    If your not throwing 02 sensor related codes I wouldnt worry about it. Anything else that snags those wires while the car is in motion is going to rip them out easily no matter what you try, they are just wires after all. If you wrapped them up they are as protected as they will ever be. Good catch
