  1. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
  2. DrPepperholik
    DrPepperholik Active Member
    342
    108
    Spartanburg, South Carolina
  3. Todd36
    Todd36 Junior Member
    APG Maryland
    Threw on some Valenti taillights...
    Also tossed on some fogs and Kensun HID kits for both those and the headlights...
    Swapped out old tires for Michelin Primacy HP's, 46 MPG's, much more quiet ride.
    #4983 Todd36, Sep 2, 2014
  4. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    these just came in..... will be installing it when I have time.... ;)
    Agent J, RightOnTime and Burna J like this.
  5. Accordlayingkit
    1,616
    1,747
    377
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    It helps improve throttle response
  7. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    this.....
    and more details from Apexi:
    PRODUCT DESCRIPTION
    A’PEXi Original Accelerator Controller with 7-modes (3 ECO Modes, 2 Boost Modes, Lo-Throttle Mode, and Hi-Throttle Mode)
    >br/>
    FUNCTION
    The A’PEXi SMART Accel Controller offers instant and direct throttle response for vehicles equipped with Electronic Throttle Control (ETC) Systems.
    Throttle response that is delayed from ETC or better known as Drive-by-wire throttle is greatly improved with this simple unit and a vehicle specific
    plug and play harness installation which is connected between the factory accelerator pedal sensor and wiring harness within a few minutes.
    PRODUCT FEATURES
    [ECO Mode]
    There are 3 ECO Mode options. Throttle response time will delay compared to factory throttle simulating the accelerator pedal being pressed gently which can result in fuel economic efficiency due to decreased initial load from the output of the accelerator pedal, in some cases can reduce fuel consumption by up to 10%. The ECO Mode can also be used to desensitize vehicles with abrupt throttle response from the factory, as seen on some vehicles such as the Toyota Tundra Truck.
    [Lo-Throttle Mode]
    Throttle response will delay from normal mode based upon throttle pedal percentage range. Throttle will react to how the user presses on the pedal between idle-to-full throttle range.
    [Boost Mode]
    Throttle response time will become quicker and results in improved accelerator pedal feel. Returns to normal mode once pedal is pressed to fully open throttle.
    [Hi-Throttle Mode]
    Improved throttle response based on throttle percentage range, in this mode throttle will respond as if
    depressing the pedal in full throttle. Returns to normal mode once pedal is pressed to fully open throttle.
    - Reverse-Gear cancel harness is an added safety feature that is an installation option to revert to factory throttle setting when reversing vehicle
    - Full-Color A’PEXi Logo LED Switch in 7 different colors per mode
    #4987 bino, Sep 2, 2014
    ckam1989 likes this.
  8. Accordlayingkit
    1,616
    1,747
    377
    #4988 Accordlayingkit, Sep 2, 2014
  9. Accordlayingkit
    1,616
    1,747
    377
    Looking good man..
  10. priusrick
    priusrick Member
    257
    40
    Sfv41901 is the man . sold me ct200 seats and has worked with me for months on installing them. Finally got them installed, power driver seat working. I couldn't be happier with my dealings with him. Stand up member!
    sfv41901 and Burna J like this.
  11. xliderider
    xliderider Senior Member
    7,901
    3,130
    Honolulu, HI
    I hope you didn't put HIDs in reflector based foglights. :(
    Bad glare using HID in non projector lights because no physical cutoff shield. :eek:
    SCH-I535
  12. kevinb70
    kevinb70 Junior Member
    Atlanta, GA
    Received today from Amazone, a Lukas LK-7900 ARA dashcam with GPS and optional OBD-II module, and a RioRand F30 Dual Dashcam. Thinking the LUKAS will go aim to the front, and the RioRand will mount to the back hatchback glass, with cameras aiming outwards to catch anyone hitting my rear, whether I'm in motion or parked (it starts recording with G-shock) Hopefully will be able to catch a tag number, and defend myself against insurance companies.
    sfv41901 likes this.
  13. priusrick
    priusrick Member
    257
    40
    Didn't know I wanted your exact look. Awesome.
  14. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Not sure exactly what you meant - did you mean ' most likely not because of rotational mass ' ? If your wheel and tire combo is less than OEM...wouldn't that assist with your MPG?
  15. Todd36
    APG Maryland
    Hey thanks for the tip, I see that you have a whole thread on a mod you did to install projectors. My fogs don't appear to be throwing light but perhaps I'll go ahead and convert to projectors as you have done for good times.
  16. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    It is more complex than that. The simple answer is not always. The heaviest portions of the wheel are the center and the rim. Even is you have a lighter 17" wheel than the 15" stock you are moving the one of the heaviest portions of the wheel 1" further from the center of gravity thus increasing the rotational inertia of the wheel. If the 17" wheel is light enough then the rotational inertia could be smaller.
  17. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Filled up reservoir lol
    Accordlayingkit likes this.
  18. Delta Flyer II
    547
    248
    69
    Do you have the part number for the Lexus cover?
  19. kenichols29
    250
    109
    Mckinney, Texas
    I did a few things to mine. I checked the oil for the 4th time since I bought it, cleaned scuff marks off the door panels, vacuumed it, and got an all time best mileage on my way home. I got 59.0 according to the cars estimate, the best I've had before for this leg of my daily trip was 54.5. 2014-09-03 15.31.00.jpg
  20. cheizy
    cheizy Member
    94
    129
    Los Angeles
    Hate how the prius navigation is full of glare during the daytime, so added some shade..
    Also smoked my tail lights yesterday, came out pretty good :)
    #5000 cheizy, Sep 4, 2014
