What happens if I press P
Discussion in 'Gen 2 Prius Main Forum' started by Pandalover, Apr 27, 2012.
  1. Pandalover
    Pandalover Junior Member
    82
    UK
    Hypothetical question. Driving along the motor way at 70. What happens if I press park?
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    the car beeps at you and pops into "neutral".. simply go back to D.
  3. V8Cobrakid
    3,790
    152
    same with reverse.. it's all electronically controlled (assuming that may be the next question)
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Though I can tell you from personal experience if you hit P by mistake when the car is rolling slowly it will engage and does the classic clank clank clank thing. Not good.
    I got hit in the back once in traffic and limped off the road and was so rattled didn't realize the car was still moving when I hit park.
    But at speed I bet it will not engage. Not sure what the go/no go speed is. Wouldn't try it though. :rolleyes:
  5. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yeah it definitely wont engage at speed, but it will engage below some minimum speed. I think the minimum speed is about 6 or 7 MPH.
  6. ETC(SS)
    6,493
    There's a "P" button????
    Oh yeah....I guess there is.
    I usually don't use it at all.
    Sometimes when I want to keep my HVAC running while I'm wrestling with a gate, I'll press the "P" button, but I usually just hit the Power button.
    As mentioned above, you probably don't want to press it while the vehicle is creeping forward, but I'm presuming that it won't kill the car, otherwise they would have programmed it to be dysfunctional with any forward movement.
  7. NYPrius1
    NYPrius1 Active Member
    1,181
    125
    Middletown, NY
    The Car Will Stop Instantly and You will go through the front window.
  8. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Your MENSA membership gets cancelled.
    2 people like this.
  9. cnschult
    cnschult Active Member
    772
    95
    Michigan
    and you automatically become a member of the democratic party.
  10. theducks
    theducks Junior Member
    Vancouver
    I did it once while pulling up to a US Border crossing. First the Immigration guys says is "so, how much is a new transmission?" *facepalm*
    Let me in though ;)
  11. edthefox5
    10,096
    4,795
    Clearwater, Florida
    OK thanks I was barely rolling so it was somewhere in there.
    Haven't used P since.
  12. uart
    uart Senior Member
    4,215
    1,200
    Australia
    I did it once also. In my case I didn't hit park, I hit the power button instead - same result though. Both of these actions (park or power-off) will just throw you into neutral if you're going over the minimum speed (as will trying to shift to "R"). So at speed the whole thing is pretty much idiot proof, at low speed however you can get a bit of a jolt, as you found out.
    BTW. In my incident I was just moving the car in the driveway and just after I started moving I realized I didn't need the engine to kick-in so I went to hit the EV button, but in the dark I missed and got the power button instead. This slammed it straight into park, and though I was only doing about 6km/hr it still made quite a shudder.
