What if I forget to turn the car off?
Discussion in 'Gen 3 Prius Main Forum' started by mr_mich, Jan 16, 2011.
  1. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Then the car will beep at you when you try to lock it and you'll go back in to turn it off. You'll have to learn to make it a habit. Your house doesn't make any noise before you lock the door when you leave either.
  2. mr_mich
    mr_mich New Member
    MD
    There's no need to be so fussy about it. I acknowledged it's a weird difference coming from a normal car to a hybrid, I was just asking what would happen/what safety measures exist. Some people on here get so defensive the minute someone implies that the Prius isn't perfect...
    The car beeps at me if I try to lock it while it's still on? Doesn't it normally beep if I lock it when it's off?
  3. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    Try it. It will panic and you will be unable to lock it. So much for the perfect Prius.
  4. mr_mich
    mr_mich New Member
    MD
    What do you mean by panic? Does it flash lights/beep differently? Can't run out and check at the moment.
  5. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    Really long annoying beep and you can't lock it at all. Same thing when you attempt to get out of the running car without first putting in park, which is why I recommend skipping the park button when powering off in case you get distracted and forget.
  6. mr_mich
    mr_mich New Member
    MD
    Oh ok, I'll make sure to keep an ear out for that as well. Just a matter of rewiring myself however I can...
  7. bisco
    48,974
    agreed. but there are a lot more old houses out there with garages under (bedroom?) than new houses in our neck o the wood and if you pulled in on a cold night and went to bed with the heat set on, i would rather make sure i shut the car off.
  8. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Attention Toyota Engineers:
    We need a Prius that will when idle for 25 minutes......whenever it's left in the "Ready" mode, in "Park".....with no movements...no one entering or exiting the car.....providing that the key fob is not in the car. Shut down the Prius & lock all the doors.
  9. ETC(SS)
    6,493
    Why do they call it a "smart key" again?
    I forgot. :D
    Anyway, I just learned to hit the power switch when I'm done driving.
    No problems so far.
    If you loose a key fob....THEN you have problems!!!
  10. frankenstein
    frankenstein Junior Member
    17
    Mine doesn't beep. No warning or reminder. Thought I hit the power button hard enough to turn it off, but apparently not because it was still running this morning.
  11. frankenstein
    17
    Actually mine doesn't do that. Left it on all night last night.
  12. frankenstein
    17
    Mine doesn't beep at all. Left it on all night last night. Walked up the driveway last night after I thought I turned the car off and no beeps. Toyota should do something about this.
  13. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    They all beep if left in READY. This isn't an option, it just happens.
  14. bisco
    48,974
    maybe it's not a prius.
  15. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    It will hurt your FE!
  16. Violetdragonfly
    Violetdragonfly New Member
    Philadelphia
    I have noticed that the car will not lock if its running and the key is outside the vehicle.... thought that was a nice feature since sometimes you can't tell if its running or not, LOL
  17. krazypriuslady
    232
    metro Wash DC
    I have a startup routine I go through: check ebrake, lights, Ev mode, look, drive
    When leaving car: park, lights, brake, power.
    I kinda say the words in my mind, and it becomes like a pattern.
    I have the same thing I use for my purse when I leave home. I have gone thru the same checklist every time i leave, for the past few years. Even my friends know it now :)
    Then you just don't forget things or skip a step.
  18. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    I have done this when I went shopping at a small supermarket shortly after I got my 2011. The Prius was new to me and I ran off quickly forgetting to turn the power off. I hit lock on my key fob and nothing happened but heard a chirping and thought nothing of it and kept walking.
    I was in the store for about 30 minutes, came back to the car went to press the button and noticed it was on.
    Another thing I did when I first got the car was hit "Park" while going around 50-55 mph when entering the freeway haha. I went to hit power mode and I hit the park instead.
    The car went into Neutral, thank goodness.
  19. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    If it is parked you CAN not put it into drive if the key is not around .... it happened to me once. Wife's key in her handbag mine somewhere at home (accidentally). So we happily left one key was in the car..... dropped her off and rolled away ... had to stop for another reason (security check) put it in park and then warning sign key is not detected ... car/engine still running but couldn't put it in drive ... thankfully I had my cell and she was still walking distance .... I am not 100% it was only the missing key or I had to step out as well ... so it worth a try one of these days.
    But if you turned everything off except the car engine will not run that much at all. And use very little gas so you may find you prius running even couple of days.
  20. macman408
    macman408 Electron Guidance Counselor
    1,179
    365
    Unless your car is special, just putting it into Park won't leave you stranded if you don't have a key. It will complain that the key isn't detected, yes, but it won't prevent you from shifting.
