What is left in the tank is way off?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jack520, Oct 13, 2014.
  1. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    I went from a 2012 Prius to a 2014 PIP recently. My gas gauge is way off compared to the 2012...I had 2 miles to fill up and could only put 8 gallons in it.
    Anyone else have this problem ?
  2. Biking Maniac
    Biking Maniac Five Prius – have not sold one yet!
    58
    Menomonie Wisconsin
    2001 Prius
    We are in a small town, never more than 5 miles from home. I ran the gas gauge down to "empty" and kept the EV battery charged for a few weeks. We went 50 HV miles after that, and took 9.5 gallons to fill. My guess is the warning came on with 100 HV miles to go.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    You do know that the Prius PHV has a 1.3 gallon smaller fuel tank that the Prius liftback, right?
    jack520 likes this.
  4. Biking Maniac
    58
    Menomonie Wisconsin
    2001 Prius
    Ouch. So maybe I was running on fumes...
  5. fuzzy1
    10,010
    It has a smaller tank, so it should take less fuel.
    Most Liftback users get about 9.5 gallons on a standard refill, with the remainder of the claimed capacity as the normal safety margin. Subtract the 1.3 gallon smaller capacity of your tank, and that leaves 8.2 gallons as the equivalent refill.
  6. bisco
    48,862
    mine always takes 8 gallons when the last pip beeps and flashes and 0 dte. you have a 2 gallon cushion, similar to all cars. surprised you didn't notice this on your '12.
  7. john1701a
    john1701a Prius Guru
    12,747
    5,243
    57
    It worked exactly as the design intended. 8 gallons is what the plug-in is calibrated for, which is a different threshold from your 2012.
    I've consistently seen that 8-gallon mark triggering the refuel notice. Fortunately, that amount of gas takes quite a bit longer to consume than it did with my 2010.
  8. bisco
    48,862
    and that's an understatement.;)
    retired4999 likes this.
  9. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    Laughing, red face, okay. I did not know...
    You guys are great !!!!!
    Thanks
  10. uropip
    uropip Member
    138
    38
    S.E. MASS
    2013 Prius Plug-in
    I fill up 9.5 gallons just about every time. Now that's running on fumes
    Galaxy S4 ?
  11. bisco
    48,862
