1. Offline
    Mitchellsprius New Member
    Jul 23, 2009
    Message Count:
    91
    monterey
    In the front sometimes I hear a fairly loud whine, I thought maybe a fan or maybe battery? My first Prius, it jumps on all of a sudden and turns off in a minute. I was thinking of having the dealer check but it just maybe part of a hybrid system.
  2. Offline
    pfreeus New Member
    Aug 8, 2009
    Message Count:
    62
    CA, USA
    Your Vehicle Year:
    Is it when you are driving and applying the brakes? If so it is the regenerative braking and normal. If you received the DVD from your dealer, it explains it and other noises you may hear.
    Read your post again. This noise should not be loud. You may want to take it in to be safe.
  3. Offline
    Bobsprius BobPrius
    Jul 23, 2009
    Message Count:
    679
    79
    Buffalo
    Your Vehicle Year:
    I believe what your hearing is part of the Hybrid System and nothing more. I hear it as well, more so, when in close proximity of cars and or the garage or anything that will let it reverberate. It's totally normal IMO, if you don't have any warning lights your most likely good. This is my 2nd Prius and I noticed a few new noises but they all appear to be normal from the manuals, DVD, and information I have gathered over time.
    The other day I turned off the car, locked the doors and there was a noise at the rear and I believe it's part of the High Volatage system...again all normal.
    But if concerned, by all means take it to your dealer and have them listen.
  4. Offline
    wfolta New Member
    Jun 13, 2009
    Message Count:
    290
    51
    Washington DC
    Your Vehicle Year:
    There are two electric motors under the hood, and the whining you hear is probably associated with them. When braking, it'll sound like a subway car or train coming to a stop, with a winding-down whine sound. THe opposite when speeding up.
    We can't hear your "whine" though and it may not be the same as what we're used to. It could indicate something wrong.
    EDIT: When do you hear the whine? Does it get louder/softer, higher/lower-pitched?
  5. Offline
    pkscout New Member
    Oct 16, 2007
    Message Count:
    44
    Utica, NY
    Your Vehicle Year:
    If you hear it just after turning the vehicle off I think that might be the system pumping some of the engine liquids into a thermos to keep them warm(ish) in case you come right back out and start the car up again. That way you don't waste energy reheating that stuff.
  6. Offline
    jay_man2 jay_man_also
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
    No thermos on the GEN III, no bladder in the gas tank either, and no belts to replace.
    1 people like this.
  7. Offline
    Old Bald Guy Old Bald Guy
    Aug 10, 2008
    Message Count:
    89
    17
    Ft. Worth, TX
    Your Vehicle Year:
    The whine you hear is likely the sound of the two electric motors spinning down under regenerative braking ... and is heard as a decreasing speed whine when you are approacvhing a stop.
    As for the poster who mentioned the pumping of coolant into the thermos bottle ... the 2010 doesn't have that.
  8. Offline
    capek New Member
    Aug 19, 2009
    Message Count:
    78
    Houston, Tx
    Your Vehicle Year:
    Are the lack of these a good thing? As in less things to break down over time and need to replace?
  9. Offline
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
    I would presume so. I never owned a GEN II, so can't comment on the thermos. The bladder was used to get the CARB emissions rating, but it caused refueling issues; Toyota figured out how to get the emissions rating in a more traditional approach. And no belts to break or need to replace is a good thing.
  10. Offline
    SlowTurd I LIKE PRIUS'S
    Aug 22, 2009
    Message Count:
    1,067
    274
    nj
    Your Vehicle Year:
  11. Offline
    • Moderator
    Sep 22, 2005
    Message Count:
    5,905
    1,081
    NY
    Your Vehicle Year:
    I would say so. No thermos but now we have the exhaust gas recovery system which helps with faster warmups during the winter. We'll see how much better it helps mileage in a few months. No baldder means during cold weather we will fit the same amount of gas in our tanks. With the bladder when it was cold out, the bladder wouldn't expand as much and you couldn't fit as much into it. And no belts means one less thing putting friction on the engine and making it work a little harder.
  12. Offline
    bluetwo Relevance is irrelevant
    Aug 22, 2008
    Message Count:
    186
    Augusta, GA
    Your Vehicle Year:
    No... that's positioned slightly above and just behind the front seats.
  13. Offline
    cwerdna New Member
    Sep 4, 2005
    Message Count:
    8,538
    985
    SF Bay Area, CA
    Your Vehicle Year:
    Besides what people suggested here, could it be the electric AC compressor?
    The compressor on the 2nd gen can get pretty loud and does vary in speed. There's also a fairly loud noise when it activates.
  14. Offline
    Aug 22, 2009
    Message Count:
    1,067
    274
    nj
    Your Vehicle Year:
    my salesman told me, when i ordered the car, that the genIII's have a thermos.
    this is why i come here to get the truth.
  15. Offline
    dc202 New Member
    Apr 14, 2009
    Message Count:
    226
    Pacific Northwest
    Your Vehicle Year:
    Does it sound slightly metallic?
  16. Offline
    Jan 17, 2006
    Message Count:
    6,034
    345
    Northern CA
    Your Vehicle Year:
    Well knock me over with a feather! A salesman who doesn't know the product...
    Certainly there is no thermos on the GIII
  17. Offline
    Jul 23, 2009
    Message Count:
    91
    monterey
    This sounds possible something to do with the AC and fan maybe. I didn't hear it today. Maybe like a big box computer whine like a DVD loading or cooling fan with a slight whistle to it. I don't think anything is broken I just like to know whats going on.
  18. Offline
    green curry expert New Member
    Jun 28, 2009
    Message Count:
    109
    Toronto, Canada
    Your Vehicle Year:
    Do you hear it when you open the driver's side door when the car is parked? If so that's the brake pump (to increase the brake fluid pressure so the power brakes work). There's a post by htmlspinnr on this, but I couldn't recall where I read it.
  19. Offline
    Jul 23, 2009
    Message Count:
    91
    monterey
    Thats a sound I was also wondering about so that clears that one up. No I think this sound is when the car is running and driving.
  20. Offline
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,975
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    The reduction gear on the electric drive motor is fairly noticeable - both upon acceleration and deceleration. Other whines will be a rather high pitched (~3kHz) inverter whine, an air-conditioning compressor whine when the A/C is on (it's electric), and a brake pump which you'll hear upon opening the door, as well as occasionally after braking. There's also the engine electric water pump which is more audible when the engine is first started, but at other times in operation as well.
    It's hard to narrow down any one sound unless you can describe exactly "when" it's happening (just started the car, acceleration, deceleration, coasting, braking, at a stop, shut down).
Share This Page
