What is unique to four-stroke, diesels, or rotary engines?
Discussion in 'Diesels' started by marlinbeachum, Mar 5, 2011.
  1. marlinbeachum
    marlinbeachum New Member
    New York
    I'm writing a program in Java, and I am using different engine types. I need to select 2 variables for each type of engine that I listed that are unique to that engine type. For example, diesel fuel is unique to diesels. Any other suggestions? I need 2 unique characteristics for each engine type. Thanks
  2. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    glow plugs are unique to diesel.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    All rotary engines I am aware of are 4 stroke engines.
    That said, Apex Seals are unique to rotaries, which also have no valve train.
    Rotary engines burn oil by design, like two strokes.
    [ame=http://en.wikipedia.org/wiki/Wankel_engine]Wankel engine - Wikipedia, the free encyclopedia[/ame]
  4. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    diesels don't have spark plugs - combustion is triggered by high compression. Think it's called an adiabatic cycle.
    so no spark plugs, no distributor, no timing.
    rotaries have a rotor instead of pistons
    diesels can be two or four stroke
  5. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Diesels have timing. The start, rate and duration of injection is carefully timed. They run like crap or don't run if it isn't right.
  6. durallymax
    durallymax Member
    142
    Under The Hood
    diesels timing is crucial.
    Other things unique to new diesels are SCR yes it is used at power plants too.
    Algae diesel is unique
    Piezo injectors are uniuque, 30,000psi ++ injction systems are unique. High strength parts are unique, compressions release brake are unique and I can go on and on.
  7. bisco
    48,987
    diesels can run on used cooking earl.
