What Mod to make my Prius increase the mpg?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 10priusII, Jul 30, 2010.
  1. 10priusII
    10priusII Junior Member
    22
    stockton
    I heard there is a mod to make a Prius to run more than 80+ mpg. Are there anyonoe knows what is that about?
    Thanks
    48,946
    you have to remove the seats and any other extraneous parts to reduce the weight. and the upside is, you can sell all the parts for additional cash in your pocket.:D
    AzusaPrius, Robert Holt and GasSaving like this.
  3. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    GO on Ebay - they sell lots of chips that get close to 80 - and most cost $10 or less :rockon:
    Mud flaps can also help - but not to the tune of 30 MPG - just do a quick Priuschat search....
  4. Joe166
    Joe166 New Member
    720
    96
    South Florida
    I think all you need is a computer. Post whatever you want.
  5. Prius42
    Prius42 New Member
    139
    Maryland
    Search the forums for the enginer plug-in conversion. Some folks have had good luck on a genIII, getting like 80 mpg over certain distances:
    http://www.enginer.us/
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    There is a free mod you can do to get 80+ MPG. It is between the steering wheel and the accelerator pedal.
    You can mod your driving behavior to achieve it.
  7. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    By far the biggest improvement you can make is the driver.
    Edit: Drat, USB beat me to it by a minute:D
  8. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    You can try tinting your windows with ceramics so you wont have to turn up the AC. That'll improve your mileage by as much as 10mpg.
  9. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Do the chips work? I understood that they just trick the car into running rich.
    Can mudflaps increase mileage? You sure? If so which ones - the US or European ones?
  10. anonymoususer
    anonymoususer New Member
    63
    honolulu
    Front air dam
    Rear boat tail
    Front and rear wheel skirts...
    OR NOT!... and be satisfied with the Priuses rated MPG :D
    carmody13, Robert Holt and GasSaving like this.
  11. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    The really sad part is that somebody, somewhere has actually spent time doing that! :confused:
  12. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Only the motorized ones that flap like wings to propel the car.
  13. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I can see where this thread is heading!
  14. darelldd
    6,057
    388
    Northern CA
    By far the easiest mod is not one you do to the car... but in WHERE you drive it. Down hill and with the wind will get you 80 mpg or better.
  15. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Now for some more practical advice with high ROI:
    1. Adjust driver's attitude (free)
    2. Inflate tires to at least max sidewall pressure (free unless you need to buy a pump)
    3. Block the grill in cold weather (pipe insulation is cheap)
    4. Buy a ScanGauge so you can see what's happening.
    5. Don't knock that stripped car with the body kit. I've heard it posts phenominal numbers in the rallys. I don't know how much is due to the driver. Have any of our Pro-Am hypermilers experienced this car in action?
  16. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
  17. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    go spend $10,000 on the plugin conversion
  18. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Can you increase the mileage of a Prius? Yes, but if it was economically viable, why would not Toyota make it stock?
    Last I heard, the PHEV Prius will pay for it's extra mileage in 1/2 million miles.
    If I wanted to get 80 MPG in a Prius I would drive 37 MPH.
    "You tell me it's the institution
    Well you know
    You better free your mind instead" - Beatles
  19. Prius42
    Prius42 New Member
    139
    Maryland
    Oh boy. As you know, trying to justify the Prius on the basis of fuel economics is fraught with difficulty. There are lots of contentious arguments on how long it takes the Prius to pay for the delta cost over some comparable vehicle (itself a source of controversy) by fuel savings alone. The same difficulty holds for the PHEV Prius. Why should the PHEV Prius pay for itself any more than the regular Prius? The technology is cool and it seems environmentally friendly. if you can afford a nice toy, you should buy one. If you want to be economical (and minimize your environmental impact), pack four people in your car on your commute or drive a moped (or better a bicycle). Four people in a civic at 35 mpg will cost you less money to buy and will be the equivalent of 140 mpg in a single person car. I don't do these things, i.e. I drive a very fuel efficient vehicle by myself to/from work but I'm not minimizing my environmental impact. I could be called a hypocrite, but I'm having fun...
    BTW I think Toyota is "making it stock" by building the PHEV Prius. The other PHEV conversions, i.e. the enginer system, are for early adopters. Toyota isn't ready to mass market this until they make sure the battery technology will last 10 years so they don't have a recall disaster on their hands. How much battery to add is also really tricky. The larger the battery, the more range in eV, but the car is heavier and the efficiency in hybrid mode will suffer. The battery is also expensive. The Volt has a very heavy battery and GM still won't tell us what the Fuel economy is in serial-hybrid mode. It is probably not good. The volt also costs a lot more than the Prius, even with the tax incentive.
  20. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I drive just over 30,000 miles a year with my current job, so I pay the hybrid penalty in 5 years (versus a Matrix). So I break even in 150,000 miles. Given that my last Toyota (a 1989 Corrola All-trac wagon) is still being driven in the family after 21 years and 330,000 miles, this does not seem all that difficult.
    Ce5ar and GasSaving like this.
