What Mod to make my Prius increase the mpg?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 10priusII, Jul 30, 2010.
  1. ajc
    ajc Member
    340
    38
    pa
    I tinted my windows at 20% and no improvement in MPG at all but much cooler.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Just live on top of a really tall hill, and always drive downhill.
    Getting back to the top is your problem!!!
  3. a_gray_prius
    2,927
    782
    IL
  4. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Get one of these for you car. Increases MPG dramatically!
    PS my apologies for blatantly stealing BobWilson4Web's avatar.
  5. teeasal
    teeasal New Member
    420
    50
    ON, Canada
    Seriously, have anybody considered doubling the HV battery's capacity by simpy buying a OEM battery pack from Toyota and connect it to the existing one in parallel?
    Sounds like you'd be able to capture more of the kinetic energy from braking and downhill glides.
    Would that be technically viable? Is there any danger of doing this? Will the manufacturer warranty be voided?
    Final questions: would it help improve mpg? by how much? is it worth doing?
  6. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    You can find your answer here. It's been looked at on an earlier gen. Topic
  7. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi gray..,
    Wont work. The Evo needs those vortex generators because its rear window is so steep, and it shields the air from getting to the wing. They need em to get the wing to work. Its just a fluke they only very very slightly improve wind drag (a .006 change in Cd). Design the rear of the car to be lowest drag shape, like the Prius, and the Vortex generators make things worse!
    Airtabs have been repeatedly tested on cars over on Ecomodder.com with no change, to worse drag. They do redirect the air. But, as they are designed for box trucks, they are much too big for typical cars, and practically monstrous for the boundary layer on a Prius.
    Airtabs have been shown to reliably improve aero-stability in a few applications -specifcally the front of a first generation Prius, (two underneath) .
    For Airtabs, or other vortex generators to work, the vehicle shape has to have radical changes in direction off the air-flow, and then be designed correctly for the application. There is a very fine balance between how much air is deflected, and the drag reduction. Deflect too much air, and any drag reduction is overwhelmed by the drage to deflect the air in the first place.
    For example, the Tubulators I put on my 2006 were only about .06 to .1 inch thick.....
  8. dzawski
    dzawski New Member
    Dunedin, Florida
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    Your emission will probably go up and the catalytic converter may die quicker. It is about $5-6k.
  10. caffeinekid
    caffeinekid Duct Tape Extraordinaire
    334
    44
    Houston
    Better maybe to get one of those cartoon hammers that can pop out of your rear hatch and a broom for the front grill. That way you can smash and sweep away the lane turd in front of you that cannot figure out how fast they want to go and is messing up your nice pace via cruise control.
    They're going 55.....then its 60.....then its 50......BAM!!! Swoosh! :cool:
  11. macmaster05
    macmaster05 Senor Member
    4,050
    728
    What about NOS?
  12. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    in the Subaru world most agree if you want better handling/gas mileage you get rid of the wife or girlfriend
    HeadOfJarg likes this.
  13. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    To date:
    Mud flaps (increased mileage - 2.718 MPG)
    Removing wheel covers (increased mileage 3.14 MPG)
    Helium in tires (increased mileage - also 3.14 MPG)
    While the Muds help on dirt, the helium really also helps handling...
  14. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    mud flaps decrease mileage... by about 2. it's been tested over and over.... it also takes yearly test to really see.
  15. Former Member 68813
    3,524
    981
    US
    It would help to know if you made up those figures or just joking?
    Could you provide more info?
  16. msirach
    msirach Member
    321
    Southern Illinois
    Drive with an egg under your accelerator and brake or place a 6 oz. Glass of water on the dash in front of you.:D
  17. socratesthecabdriver
    283
    31
    greece
    Paint it yellow
    Khezekiah and HeadOfJarg like this.
  18. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    Always drive downhill.
  19. KK6PD
    4,003
    944
    118
    OK Boys and Girls, can you spell F A C E T I O U S ??????
    Sure you can, see, I knew you could!!!
  20. bisco
    48,988
    you're a bad boy!:evil:
