What mode is in ScanGauge II for 2007 Prius
Discussion in 'Gen 2 Prius Fuel Economy' started by Halmaden, Mar 10, 2008.
  1. Halmaden
    Halmaden New Member
    I just bought a ScanGauge II for my 2007 Prius, which mode I need to select in set up MORE>MORE>MODE?:)
    Thanks for your!
    Halmaden 3/10/08
  2. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    You will want to select "Hybrid" for fuel type.
  3. Halmaden
    Halmaden New Member
    Thanks,:):wave:
    Halmaden 3/11/08
  4. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    You'll also want to plug in the tank size (maybe you've already done so). The ScanGauge doesn't offer decimals, so put in either 11 or 12. I think most use 11 even though that's rounding down, because the bladder in the tank takes up some room.
  5. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    And don't forget to input the engine size.
  6. Halmaden
    Halmaden New Member
    I have filled up 7 times in last 10 months, but never over 10 galloons due to expander inside the gas tank, will it cause problem when I check tank gauages (such as XXX mile to empty or X.X hours to empty)?:)
    Thanks,
    Halmaden
  7. wesshaw1@mac.com
    [email protected] '08,pkg3,GPS,ScanGaugeII
    30
    Winter Harbor, Maine, USA
    Halmaden, If you carefully followed the SG II manual directions on calibrating the tank in the beginning, you'll find the predictive figures quite accurate. If you didn't, you need to revisit the Manual and "start over" on the calibration. It's really quite easy. Best of luck and you'll love the Gauge... Wes
  8. zeeman
    zeeman Member
    211
    i am thinking of getting scangauge and i was wondering how you guys like it?
    BTW, where is the OBD plug located on 2008 prius?
  9. micheltan
    micheltan New Member
    I just recently got a 2008 Prius package 5, can anyone tell me why I would need the scanguage 2. Doesn't the prius already do what scanguage is capable of doing? Thanks
