What tires came with your PiP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by iRun26.2, Mar 19, 2012.
  1. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    The S33D surprisingly is not cheap. It is $107 retail at TireRack and $127? at America's Tire Company. That is Michelin price range!
  2. UCBRUINS
    UCBRUINS Member
    96
    44
    LA
    Goodyear on Advanced.
  3. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Yokohama AVID S33D
  4. iRun26.2
    iRun26.2 New Member
    683
    111
    United States
    It seems odd, to me, that the first bunch of PHVs that Toyota shipped came with three different brand of tires.
    What is up with that??
  5. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    Google search of "tire shortage" yields this article from 6/11:
    Automakers complain about tire shortage
  6. iRun26.2
    iRun26.2 New Member
    683
    111
    United States
    OK, I just checked and I have the Yokohama. How do I know what pressure I can safely pump them up to? I assume they are probably are at 35 psi from Toyota.
  7. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Max pressure is listed on the tire sidewall. It is 44psi for the 15" tire. Most of us recommend keeping it at or below sidewall max pressure and maintaining the front rear pressure difference (35/33psi). So 44/42 is very common.
  8. OilFreedom
    OilFreedom New Member
    79
    25
    San Diego, CA (Carmel Valley)
    Since the Pip is not equipped with a Spare, I was thinking about putting run-flat tires on it. Does anyone have experience or recommendations on this for a Prius? I don't know if run-flats come in a LRR version, and I wonder how much the gas mileage would be affected by switching the tires.
  9. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    This has been standard practice with Prius for several years. It was this way when I bought my 2010. Why they do it is a business decision of some kind -- maybe it minimizes liability, or keeps pricing ultra-competitive, or enables better availability of supply. Hard to say exactly why.
  10. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I've never found a LRR version. They tend to be very heavy so expect a modest mpg drop should you decide to switch. I predict a 4mpg+ loss and a loss of a fee miles of EV range. IMO it's not worth it. Either buy a small spare wheel/tire and carry it with you or stick a can of fix a flat Under your seat.
  11. iRun26.2
    iRun26.2 New Member
    683
    111
    United States
    I have a few more questions for you, if you don't mind:
    1) How much of a gain in gas mileage would you expect to see in going from the standard 35/33 psi to 44/42 psi?
    2) I assume you increase the air pressure (and measure it) when the car has not been driven for a while. Am I correct?
    3) Will also need to reset the tire pressure monitoring system?
  12. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    1) The answer really depends on how you drive the car. The average non-hypermiler may only observe a 1-2mpg gain but a super hypermiler like Wayne Gerdes may observe more. I can only assume there is a good reason he inflates his Goodyear Fuel Max tires to 60psi-65psi (50psi max sidewall). I don't think many tests have been done to quantify the gain but you can expect to get an extra hundred feet of roll during a coast down test. It is especially important for urban driving where the largest resistances opposing vehicle movement are rolling resistance (46.6%) and acceleration resistance (namely weight at 40.9%). Air resistance only accounted for 12.5% at slow speeds.
    See my thread in the Prius c forum regarding urban driving for max mpg.
    http://priuschat.com/forums/prius-c...summer-mpg-vs-winter-mpg-prius-c-version.html
    2) Correct. You check pressure at the coldest part of the day (morning) and set the pressure accordingly. You are attempting to set the pressure when the tire should be at its coldest and therefore this should be the lowest pressure you will ever observe during your daily routine until the wether changes. As temps increase throughout the day tire pressure will increase a bit but it will not go lower than what you set it at. The pressure increase will not hurt the tire and it is barely enough to feel during driving. Now, if you have a cold spell and set your tires at 44psi in the morning with 40F ambient temps the the next day temps raise back up to 100F then you may want to readjust your pressure to the new average daily temps. Assume an approx. 1psi loss for every 10F drop in temperature or 1psi gain for every 10F rise in temperature.
    3) I have never messed with my TPMS. I assumed that if my tires get below the safe limit set by the manufacture then I have a problem. Otherwise I don,t really care to try and set them for a higher pressure. It's up to you. I don't really know much about the system since this is my first car with them (besides the Corvette).
  13. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I have a question for you PIP owners.
    On the standard Prius the manufacture recommends a split in air pressure between front and rear. They call for 35front and 33rear. This is due to weight distribution in the Prius. The PIP has a larger heavier battery system and thus more weight in the rear. Does Toyota recommend the same tire pressure front and rear now?
  14. Kahuna69
    Kahuna69 Junior Member
    43
    Arizona
    Yokohama AVID S33D on base model.
  15. ryogajyc
    985
    165
    Reseda, CA
    It's the same as the Liftback. From the Prius Plug-in Owner's Manual, pg. 619:
  16. CharlesH
    2,783
    1,151
    Roseville, CA
    Goodyear Assurance ( Treadwear 540 Traction A Temp B ) on Advanced
  17. The Critic
    The Critic Resident Critic
    3,193
    2,316
    CA
    The tires have to pass a so-called "blind ride test." The three tires perform near identical as they are built according to Toyota's specifications, not the tire manufacturer's.
    Therefore, the three different brands of tires is merely due to the available supplier at the moment.
  18. Piprius
    Piprius Member of the cult of Prius
    72
    MD
    I also got the yokos. East coast shipment.
  19. denali
    denali Junior Member
    17
    CA
    Goodyears on my Advanced here. From the factory/dealer, I had ~39 psi. I decided to lower it a bit and see what happens with fuel efficiency. I'm running 37 in front and 35 in rear right now and I feel that the ride's improved. The jury's still out on fuel economy, but I figure with the 90 MPG I've been getting so far I'll take the slightly more comfortable ride over the fuel economy.
  20. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    The "cheap" remark is about quality and rating. The cost is remarkably high and not a VALUE. The Advanced model with Goodyears have better 540 Treadwear and better traction and wet ratings. Still CHEAP IMO.
    :spy:
