What's the best headlight bulb?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mediahound, Jan 21, 2014.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    What's the best and brightest h11 headlight bulbs to get?
    I don't want to go HID and also would like something that is a pure white and not yellowish.
    Any recommendations?
  2. A.Reyes
    A.Reyes Active Member
    270
    178
    Beaufort, 29902
  3. bino
    bino JDM ZVW30
    1,348
    705
    SoCal 91739
  4. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    The best quality (and hence brightest) H11 bulbs available are the Philips xtreme vision and the Osram Nightbreaker.
    All of these bulbs are still Halogen so they will, by definition, have approximately the same color output as that is fixed by the technology and can only be changed by placing a filter over the bulb. The Osram Nightbreaker Unlimited has a blue tint over portions of the bulb (but notably NOT over the filament) which will give some color change off-axis, which is a nod towards market demands while still trying to maintain maximum light output.
    Note that bulbs like this will have significantly less lifetime than your OEM bulbs - as short as 100 hours. I still think the H9 conversion is a far better idea and will get you on average 250 hours with a whole lot more light.
  5. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    +1 for H9 conversion.
    The premium H11 bulbs are overpriced, the H9 are around $8 each.
  6. mediahound
    903
    155
    It just seems like such a PITA to do the H9 conversion though.
  7. mrbigh
    3,686
    699
    Long Island, NY
    But still, H9 are the best choice for the money and they are brighter!!!
  8. xliderider
    7,848
    3,102
    Honolulu, HI
    This is a list of your mods in your signature:
    "TRD Prius Plus: 17" wheels, Toyo Proxes 4 Plus tires, Lowering Springs, Rear Sway Bar"
    And you are moaning about a 10 minute conversion of two bulb bases with some simple tools? I just don't get it.
    32kcolors likes this.
  9. mediahound
    903
    155
    I don't think there is anyone who would say it's not a PITA except you.
  10. lizardskin
    lizardskin Junior Member
    26
    Northeast USA
    don't buy these.
    Philips H11 CrystalVision Ultra Headlight Bulb
    Not only dimmer (but slightly whiter) than my OEMs but I'm on my second one (first one lasted less than 6 months!!). Right side headlight still works after 3.5+ years!
  11. xliderider
    7,848
    3,102
    Honolulu, HI
    Ok, sticking to the thread... Sylvania Silverstar zXe H11 bulbs are pretty good, but shop around for the best price.
    SCH-I535
  12. lizardskin
    26
    Northeast USA
    anyone know what is the OEM brand and model bulb??
  13. xliderider
    7,848
    3,102
    Honolulu, HI
    I believe they are marked H11 Osram, made in Germany.
    SCH-I535
  14. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    It's not a PITA. 5 minutes per side is being really generous.
  15. xliderider
    7,848
    3,102
    Honolulu, HI
    Yeah, that argument makes no sense. It is much harder to access and change the passenger side lowbeam bulbs on the Prius than it is to modify both H9 bulbs.
    Yet, the OP doesn't seem to mind replacing the OEM bulbs with something plug and play.
    SCH-I535
  16. mrbigh
    3,686
    699
    Long Island, NY
    Agree....(y)
  17. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    What's the reasoning behind not wanting to go HID? Output is far superior and you can get kits that cost less than high output halogens that (in my experience) burn out in less than a year.
    Burna J likes this.
  18. GasperG
    GasperG Senior Member
    1,168
    597
    Slovenia
    2018 Prius
    Reason for not going HID? It's not legal, maybe I would get away with 4500K, but definitly not with 6000K, maybe next time.
    Now I have ordered H11 Osram Nightbraker Unlimited, they were just a few euros more, I just hope they will last more than a year, they are supposed to last much longer than the first version of Nigthbrakers.
    First OEM bulb went out after 4 years, the second is still working, I will post some before after pictures with camera in manual mode, when I change them.
  19. mediahound
    903
    155
    HIDs are great but do have some negatives.
    As mentioned, they are not legal in many states although here in California, as long as they are not super blue, you generally are fine.
    The mounting of the ballasts can be a pain, the HID bulbs don't last that long (although a bright H11 or H9 doesn't either). Cheapy HID ballasts can go bad quickly too, although good quality ones should last years.
  20. mediahound
    903
    155
    A true 6000k is not really blue, it looks more white. The issue is if the HID ballast is a cheapy one, those tend to make the bulbs bluer than they should be.
    There's some YouTube video where the guy swaps the same bulb between 2 different brand ballasts and the color goes from a blueish to what looks like a pure white, same bulb!
