When did your battery fail?
Discussion in 'Gen 2 Prius Main Forum' started by THF, Apr 11, 2014.
  1. 1 - 25,000
    0 vote(s)
    0.0%
  2. 25,001-50,000
    1 vote(s)
    2.4%
  3. 50,001-100,000
    0 vote(s)
    0.0%
  4. 100,001-150,000
    5 vote(s)
    12.2%
  5. 150,001-200,000
    2 vote(s)
    4.9%
  6. 200,001-250,000
    0 vote(s)
    0.0%
  7. 250,001-300,000
    0 vote(s)
    0.0%
  8. 300,001+
    0 vote(s)
    0.0%
  9. No failure yet
    34 vote(s)
    82.9%
Multiple votes are allowed.
  1. THF
    THF Junior Member
    71
    MO Ozarks
    My HV / traction battery just failed, unfortunately, at 192xxx miles. I am wondering what other folks here on Priuschat have experienced. Selection of multiple votes in case you have had multiple failures.
  2. Patrick Wong
    18,199
    6,464
    2004: no failure so far, currently at 170K miles
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Build date - March 2005
    217,500 miles and counting.
    Monitoring HV battery block voltages daily with Torque app for android. No weak blocks (yet). Temperate climate, relatively flat terrain, and 20K miles per year use are helping to prolong HV battery life.
    Of course, the traction battery could fail today. No surefire way of knowing when and where it will croak.
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Bit of a loaded question if ever there was :rolleyes:
  5. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    2010 Prius / purchased new May 2009. approaching 112,000 miles. Oregon has a 150,000
    mile warranty. So far the battery is functioning just like it was the first day we purchased the car.
  6. uart
    uart Senior Member
    4,215
    1,200
    Australia
    If you ruled out (or at least put in a separate category) people how first sought out this site because they *already* had battery related problems, then you might end up with some kind of useful statistics on the current rate of battery failures. Given the loaded nature of the question however, even in that case the results would be extremely questionable.
    If you're just looking for data on the battery lifetime then you have to understand that no matter how the survey is posed you are inherently only considering the earliest few percent of failures.
    So sorry, but I can't see any meaningful statistics ever being drawn from this particular survey.
  7. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Which battery are you talking about ?
    You know that every Prius has TWO......right ??
  8. THF
    THF Junior Member
    71
    MO Ozarks
    How are you doing this? I would be interested in that.
    I appreciate your skepticism, however one can assume that a goodly percentage of the members of this forum are on here for many other reasons. As we see from the poll anyways, several have said no failures.
  9. THF
    THF Junior Member
    71
    MO Ozarks
    Double post.
  10. Former Member 68813
    3,524
    981
    US
    IMHO, if you want to learn anything from a poll on this topic, you should ask about life in years and not miles. Miles are totally irrelevant for HV battery. Case in point: the more hwy miles, the less work for the battery (unless one drives in hilly area).
  11. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    No failure yet, but only at ~75K miles. Car was bought new in January 06.
  12. THF
    THF Junior Member
    71
    MO Ozarks
    I would tend to agree with you, however economics and environmentalism are the only things that sell the Prius. (I do not consider the fancy computers and increased functionality of regular driving the main selling points, although they are points.)
    The economics of the Prius say that the battery should last as long as possible to save as much money as possible per battery lifetime. Premature failures result in an increased amount of time that must be driven in order to recoup losses.
    In the event economics fail, which they usually don't, environmentalism wins, which is why everyone should drive a car with a huge toxic battery, right? (Not putting down Prius in any here, just stating that the battery is not without significant impact.) therefore the battery must collect as many miles as possible in order to gain positive factors such as the reduced amount of fuel needed. Since I do not know the gallons of fuel needed to produce the traction battery, I cannot contrast these points very well. Therefore, I argue that mileage is indeed important and that each battery needs to collect as many miles as possible in order to be beneficial.
  13. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I'd say how many 'hours' the car has been on rather than years or miles. 10 hours a day in slow, crawling traffic is going to be much harder than a 50 mile each way commute at 60 mph. Both cars could cover the same mileage in the same number of months.
    THF, Tony D and uart like this.
  14. bisco
    48,962
    can you give us any data on the 'significan't impact' of the battery? i thought they were being recycled and re used.
  15. cthorsman
    cthorsman Junior Member
    68
    24
    Maryland
    July 9, 2013 at 295,000 miles. Cause - lady ran a red light and TKO'd my 2004 blue prius.
    Actually, the battery still worked, but the car was bent in a variety of unnatural ways.
  16. wjtracy
    wjtracy Senior Member
    11,313
    3,588
    Northern VA (NoVA)
    Here is a link to results of a similar survey recently completed:
    SUMMARY and CONCLUSIONS
    It's time to sum up this Gen2 hybrid batt survey. The survey results are more useful than I first thought, when combined with Consumer Reports 2014 Auto Issue new data on Prius batteries.
    • 126 responders
    • 20 replaced batteries (18.9%)
    • 14 of 20 replaced under 150,000 miles (70%) most of these probably under warranty
    • Next survey we should ask how many of the replacements were under warranty
    (see above post for more details)
    THF likes this.
  17. cthorsman
    68
    24
    Maryland
    Is there any accurate resource on data re the traction battery life of the Gen 2 Prius. It is an interesting topic.
    This week I have been reading in the forum about the battery pack, life of cells ... Way over my head but very appreciative of those with greater knowledge and experience taking the time to share.
    Based on my reading, I did this morning pull out my battery fan and brushed off the accumulated dust and debris. In the next few days I will tape filter material over the vent grate.
  18. wjtracy
    11,313
    3,588
    Northern VA (NoVA)
    Consumer Reports published Gen2 (and Gen1 and Gen3) batt life data a few months ago, which I presented in the prior survey posted above.
  19. cthorsman
    68
    24
    Maryland
    wjtracy, thank you. I had jumped there before, but this time I scrolled down and found your recap of the Consumer Reports info. I am bouncing around threads picking up ideas on ways to treat the battery pack to aviod problems for as long as possible.
    I like my Prius. I like it every time I pull up to a gas pump.
    It is not perfect. I have one issue I intend to attack soon, but what ten year old car doesn't?
  20. THF
    THF Junior Member
    71
    MO Ozarks
    Here is an interesting article concerning batteries and hybrid cars.
    HowStuffWorks "Does hybrid car production waste offset hybrid benefits?"
    The article ultimately concludes that hybrid cars are (duh) more environmental, and that the battery production and technology does cause hybrids to be more energy intensive than regular cars, but cannot be negated by the tremendous gas economy of hybrids.
