1. Offline
    soapman New Member
    Start a Conversation
    Jul 28, 2012
    Your Vehicle Year:
    My inverter over heated. Looked at reservor for motion of water saw none. Took car to toyota for pump recall.When I got it back I heard the pump. Never heard it before. I don't think it ever worked. & water is flowing in reservor now. Now I am thinking about the HV bat. fan because I never never ever heard it working. When does it come on and how could I test it?
  2. Offline
    nh7o Off grid since 1980
    Dec 10, 2011
    619
    88
    Hawaii
    Your Vehicle Year:
    I think many people never hear their battery fan come on, although it does run at a very quiet slow speed often enough. It will only run on high under real heat stress. If you drive mainly on the highway, use the A/C, and do not encounter much in the way of big hills, then it will go unnoticed. If, after years, you do hear it, it means battery trouble is brewing, due to the internal resistance of the cells rising, or due to the fan being clogged with dust, hair, etc.
  3. Offline
    2,725
    395
    Greater Vancouver, BC, Canada
    Your Vehicle Year:
    I put a piece of filter material (intended for vacuum cleaner motor filter) in the fan inlet on our 3rd gen, soon after purchase, about 18 months back. FWIW, I've never heard our fan, but periodic checking of that filter shows it's picked up a few things, a bug or two and some lint. So I'd assume the fan's running, just not audible.
  4. Online
    12,348
    1,743
    Your Vehicle Year:
    i never heard my 04 or 08. i think you're climate has something to do with it as well.
  5. Offline
    uart Senior Member
    Sep 7, 2009
    2,770
    478
    Australia
    Your Vehicle Year:
    Any time you get a nice hot summer day and a reasonably long drive, at the end of your trip I guaranty it will be running. Leave the Prius in ready and (with all other fans off, engine off, radio off etc) get out of the car and walk around to the right back door. Place your ear right next to the vent and you'll hear it running. It's whisper quiet on low speed, you really need your ear right there at the vent to hear it.
  6. Offline
    soapman New Member
    Jul 28, 2012
    Your Vehicle Year:
    Thanks It is always hot now in jersey. I will take a ride and check the fan. I am going to clean the fan in the next few days. I heard it can be very dirty after 7 years.
  7. Offline
    soapman New Member
    Jul 28, 2012
    Your Vehicle Year:
    I found my way into the fan. not easy. very hot day too. only found dust on the blades. vaccumed it out. I hope it works, because the dreaded triangle came on & car quit on the highway on a 104 degree day. I still hope the inverter water pump was the problem.
  8. Offline
    uart Senior Member
    Sep 7, 2009
    2,770
    478
    Australia
    Your Vehicle Year:
    That's easy enough to check. Have you had a look to see if the inverter coolant is circulating in the reservoir yet?
  9. Offline
    Mar 27, 2004
    7,634
    838
    United States
    Your Vehicle Year:
    It's worth a look because it's apparently common not to get all the air out of the coolant loop after replacing the pump. A week after mine was replaced the same warnings re-appeared; the cause was just trapped air.
    In eight years in Dallas I've never noticed the battery fan running, so don't panic about never having heard it.
  10. Offline
    Andyprius # 1 Member since 2005
    May 30, 2012
    1,012
    88
    Sacramento
    Your Vehicle Year:
    Very true, for 7 years, I never heard mine.
  11. Offline
    May 30, 2012
    1,012
    88
    Sacramento
    Your Vehicle Year:
    You must have turbulance in the pump AND bleed the air out, if it is not turbulent.
Share This Page
