Where I can get remote key fob other than dealer$$$ ?
Discussion in 'Gen 3 Prius Main Forum' started by us_matrix, Aug 8, 2011.
  1. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Once techstream is running and communicating with your vehicle you will see the different modules you can communicate with.
    I installed ver 9, then driver, then plugged in cable, hooked to car, ran TS, told it what vehicle and options.
  2. Alen Kalati
    Alen Kalati Junior Member
    32
    Dane;
    I'm sorry to be a nag, but:
    Can you specify what do you mean by driver? Is this the Mini VCI driver? So you didn't need to run the TISKEY?
    Thanks.
    48,945
    have you uncrossed them yet?
  4. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Yes the mini VCI driver in the folder marked as such. I did not do the TISKEY, not sure what it is.
  5. Alen Kalati
    32
    Thanks! Finally programmed the key with a new Dclick I ordered. Went smooth.
  6. Mike500
    Mike500 Senior Member
    2,593
    763
    The D-Click off of Amazon works. I found the Fotga to be buggy, and the one I ordered from Amazon NEVER worked.
  7. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    That's what I ordered. I won't receive it for another week or so. I'm kinda glad that all of these questions are being asked, so that I have a reference in case I have trouble. I'm sure I'll have the same issues. Thanks.
    Mike
  8. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    I had two keys cut today at a local locksmith for $20 each. She had machine, but didn't think she could cut a Prius key. Now she knows she can! Key that came with $85 FOB worked like factory, separate key I ordered was a little rough. She had to cut around the triangle tip some and then it was much better.
    So, under $150 for extra FOB and two keys cut!!
  9. David Nguyen
    David Nguyen Junior Member
    Houston
    Did you guys had to get a TechStream Seed Code? I bought a used Prius Key off eBay and I read online that you will need a seed code in order to reprogram any "used" key.
    What website did you guys purchase the Seed Code from?
