1. Offline
    DRLeahy New Member
    Feb 22, 2006
    Message Count:
    I just bought the 2010; I had the 2006. On the 2006, it was clear on my dash that I was getting 47.5 miles per gallon. I had the option of resetting this button each time I filled with gas (I did not). How do I see the SAME information on the new dash? Am I an idiot? Thank you.
  2. Offline
    mitchvino New Member
    Nov 13, 2009
    Message Count:
    Pennsylvania
    Your Vehicle Year:
    Use the "Trip" button on the steering wheel. If you press and hold the trip button, it will reset.
  3. Offline
    jdcollins5 New Member
    Aug 30, 2009
    Message Count:
    2,431
    429
    Wilmington, NC
    Your Vehicle Year:
    The MPG is listed as CONS at the bottom of the HSI and Consumption menu screens, about midway. You have a Trip A and a Trip B that is selectable by the TRIP button on the steering wheel. As stated above, if you hold the TRIP button down, it resets the TRIP data that is currently being displayed.
  4. Offline
    DRLeahy New Member
    Feb 22, 2006
    Message Count:
    I still don't see it.
  5. Offline
    bighouse New Member
    Sep 7, 2009
    Message Count:
    798
    121
    Guerneville, CA
    Your Vehicle Year:
    You have to reset a Trip meter to get it to display the MPG I believe. Press the Trip button on your steering wheel to change to Trip B, then press and HOLD the button to reset Trip B. From then it should display your MPG...it'll say something like 51.0 CONS not MPG...that "CONS" stands for "Consumption". You can then switch between different displays with the DISP button. If you get to the 5 minute bar display you can change that to a 1 minute display by holding down the DISP button I believe.
  6. Offline
    lunabelgium New Member
    Oct 13, 2009
    Message Count:
    270
    Belgium (Liège)
    Your Vehicle Year:
    Why don't you read the owner manual - LOL -?
Share This Page
