Which 12v battery is the best?
Discussion in 'Generation 1 Prius Discussion' started by baja454, Mar 7, 2010.
  1. a_gray_prius
    2,927
    782
    IL
    Looks like a relatively tight fit - otherwise I would have asked why not use a plastic 'bin' for the battery to sit inside so you don't have to fabricate some sort of plastic cover?
  2. bwilson4web
    15,394
    Hummm, my first thought was 'gut' the OEM battery and put the PC925 inside. <GRINS> Sad to say, I've already recycled my old one but the idea has merit. I might do that with our ZVW30 when the time comes.
  3. OptimaJim
    OptimaJim Member
    74
    Wisconsin
    Hello, I noticed your conversation and wanted to offer some assistance, especially to baja454, who just purchased one of our batteries. Although our batteries are sealed, it is important that any lead-acid battery has proper ventilation. ALL lead-acid batteries can vent gas. Traditional wet batteries do this immediately when recharged, since they are not sealed. Sealed lead-acid batteries like Optimas and all other “dry cell†AGM batteries have safety release valves that should only vent if they are seriously overcharged.
    Under normal operating conditions, an AGM battery will not vent gas. Since alternators or chargers can fail, the safest and correct mounting method for trunks and passenger compartments is to make sure that any possible gas venting will escape to the outside of the vehicle. All vehicles with original equipment battery locations in trunks or passenger compartments will have a vent provision that should be used. If your battery is custom-mounted in the trunk or passenger compartment we recommend venting the battery to the outside of your vehicle as well. Optima group 27, 51, 78, 34C, and 31 batteries all have ports for connecting a vent hose.
    Although people do it anyway, we would never recommend installing an unvented battery in any enclosed space, because there’s a legitimate, albeit unlikely, safety risk involved.
    For example, IF there is a voltage regulator failure, and IF the battery is severely overcharged, and IF this goes unnoticed, and IF the battery vents because the internal pressure exceeds the release pressure of the vents, the gasses are both flammable and toxic. This may sound like a lot of “ifs,†but attorneys and engineers get paid to plan for every worst-case scenario.
    Jim McIlvaine
    eCare Manager, OPTIMA Batteries, Inc.
  4. jk450
    jk450 New Member
    Thank you for taking the time to contribute to this forum. Much appreciated.
  5. bwilson4web
    15,394
    Hi Jim,
    Do you offer vented cases for your batteries?
    I noticed various marine and other sites offer battery boxes:
    Noco Group U1 Battery Box: BatteryMart.com
    Do you have any recommended battery boxes for the Optima batteries?
    I had a voltage regulator on a generator fail many years ago in a Cherokee 140 in flight. By the time I landed and opened up access to the battery, it was venting acidic steam ... not a pretty sight. I pulled the generator circuit breaker and flew home by turning off the master switch and flying VFR.
    It looks like my Odyssey PC925L will fit in a U1 box but I'll check with them to see if they have any other recommendations.
    Thanks,
  6. bwilson4web
    15,394
    Do you have any 'white papers' or experience with installations that include a stiffening capacitor?
    Thanks,
  7. OptimaJim
    OptimaJim Member
    74
    Wisconsin
    Hi Bob,
    Unfortunately, we do not offer vented boxes or other accessories for our batteries and cannot “officially†recommend products manufactured by other companies or offer specific advice on custom applications. I can tell you that any custom application should consider these guidelines-
    · Hood Clearance – There should be at least ¾†clearance between the top of the battery terminals and the underside of the hood. When we do our fitment studies we put a ball of clay on top of the post, and VERY carefully close the hood to make sure that nothing makes contact. By measuring how much the clay is squeezed down when the hood is closed, we can know how much hood clearance we have.
    · Trunk/Interior Mounting – As previously mentioned, if your battery is mounted inside the passenger compartment or trunk, the battery must be vented to the outside of the vehicle. Optima group 27, 51, 78, 34C, and 31 batteries all have ports for connecting a vent hose.
    · Side Terminals – Optima 34/78, D34/78, 75/25 and D75/25 batteries have both top and side terminals. If you are using one of these batteries in a vehicle that uses the top terminals, it is important to ensure that the side terminals can not come into contact with anything metallic (for example, the firewall or fender well), thereby causing a short. We suggest keeping the post protectors on the terminals you are not using. Do not connect a winch to the side terminals.
    · Battery Modifications – Cutting, drilling, trimming or otherwise modifying your Optima battery may present a safety hazard and will void the warranty.
    · Mounting – Your Optima battery must be securely mounted. The terminals are not intended to be used to secure the battery. Using the terminals in this way will damage the battery and void your warranty.
    · Heat – Protect your battery from high heat, such as turbochargers or exhaust manifolds
    If you have any other questions, I’ll do my best to answer them.
    Jim McIlvaine
  8. Kanshome1
    Kanshome1 New Member
    Oxnard, California
    2001 Prius
    We are just now getting into this forum and because we are having issues with our '01 model, I have begun researching several things. As of today I was told by a very qualified mechanic (at an independent garage, not Toyota) that the Prius needs the original style 12 V battery because the internal design works with the slow (low amperage) charging system used on the Prius. The 12v battery is apparently charged through the HV battery. Overlooking the problems with adapting a different sized case, and the wiring concerns, I think I'm going to have to go with the dealer-sold part, because my friend's argument made sense to me. But that's why I signed on to this forum, I'm open to any and all information. Again, forgiving the size issue and assuming the wiring is not rocket science, does another style of battery hold up to the Prius needs? I have several street rods and usually run Optima batteries and knowing how good they are, (I'm still running one that was installed in 1995) I wonder if that capability is masking some pending issue?? As in, is the solid core battery just keeping up with the use and will fail because of charging rates, or is it really living with the Prius electronics as it should?
    Sorry for the long post. Keith
  9. bwilson4web
    15,394
    I've done load testing of our NHW11 as part of installing a 1 kW inverter and it delivers a solid, 1 kW.
    More accurately through the power inverter. Although 'OptimaJim' is concerned about a runaway alternator and I have experienced a runaway generator, there is a quantum leap between those primitive systems and our Prius inverter. I'm not worried about either over voltage nor over loading our liquid cooled, power inverter but I've tested mine to the 1 kW limit.
    My OEM battery lasted about 6 years and yours, 9 years. Given the average USA fleet age is (or was) close to 9 years, this isn't bad at all.
  10. orange4boy
    orange4boy Member
    231
    43
    Vancouver BC
    2003 Prius
    The Prius does not use any exotic charging technology. It charges just like a standard alternator system, by the overall voltage of the 12V supply. In this case it is supplied by the DC-DC converter which has a 100 amp fuse so it is designed to supply up to roughly 80 amps. without too much trouble. It will have no problem charging an Optima.
    The reason the Prius has a small battery is that since it does not need to start an ice a small battery is all that is needed to boot the computer and supply a bit of juice before the ready indicator is lit. Small means light which means better fuel economy. I'm an Optima fan as well. Go for it. They are a much better battery for the money.
    Any car that is used on short commutes will tend to under charge any battery which will lead to stratification in a flooded battery. Optimas do not stratify which is probably one of the reasons they last so long.
  11. Jardonhu
    Jardonhu New Member
    new york
    2012 Aqua
    Optimas do not stratify which is probably one of the reasons they last so long. why did you say that?
  12. ChapmanF
    15,098
    Are you asking why he said Optimas don't stratify the way flooded batteries can, or why he suggested that's an advantage if a car's used for short commutes?
    -Chap
  13. ChapmanF
    15,098
    On the chance someone might later refer to this thread, it's worth mentioning that the battery Toyota now sells as the official Classic part (p/n 28800-21190, Panasonic S55D23L, since 2003) is a pretty good battery at a pretty good price, if you're ok with flooded battery technology. Its capacity, if the 48 amp-hour figure is right on the data sheet mlibanio found, is hard to beat for the money.
    The tray/holddown/cable retrofit kit p/n 04003-23147 is inexpensive and gives you a safe tidy stock installation (stock in the sense that this is the current stock battery for the car). Of course if you're replacing a battery that already says Panasonic, you don't need the fit kit.
    More details are here.
    -Chap
